Vieux 25/11/2015, 12h39   #1
nas33
Avatar de nas33
Par défaut codage injecteur polo 1.6 tdi
bonjour je cherche a rentrer code injecteur car je viens de les changer avec vcds .j ai ecu simos pcr 2.1 et j ai pas envie de le flinguer car ils sont tres cher.si qlq 1 connait la procedure exact pour reprogrammer ca . mon defaut c que j entend un petit claquement au ralenti c leurs defaut a ses nouvelle polo merci
Vieux 25/11/2015, 16h01   #2
doud77
Avatar de doud77
salut Nas33, voici la réponde à ta question:
C'est copié/collé du wiki.ross-tech
C'est en anglais mais assez simple pour etre compris une fois digéré pargoogle traduction:
The IMA-ISA values need to be adapted when:
One or more injection valves have been replaced. Make sure not to adjust the valves which have not been changed!
The engine control module has been replaced.
Do NOT adapt these values when you did not replace one of the above parts, also not for training or demonstration purposes.
The adjustment code can be found on the injector itself, it is a 7-digit value and does only use the following chars: 1,2,3,4,5,6,7,8,A,B,C,D,E,F,G,H,K,L,M,N,O,P,R,S,T, U,V,W,X,Y,Z. A value of AAAAAAA is also not valid.
Prerequisites:
Ignition ON
Engine OFF
[Select]
[01 - Engine]
[Adaptation - 10]
Channel 071: IMA-ISA Value for Cylinder 1
Channel 072: IMA-ISA Value for Cylinder 2
Channel 073: IMA-ISA Value for Cylinder 3
Channel 074: IMA-ISA Value for Cylinder 4
Enter the ****** values from each fuel injector as needed.
[Test]
[Save]
[Done, Go Back]
Switch Ignition OFF, wait 10 seconds and switch Ignition ON again. The values should be saved now, please verify them by double checking the adaptation values.
The Test value shows "AAAAAAA" if you have entered an implausible value. If the IMA-ISA value on the new injector is difficult to read, consider scanning the QR code with a smart phone app.
We have had success with BB, Android and iOS platform mobile devices running i-nigma's free app.
Vieux 28/11/2015, 19h08   #3
nas33
Avatar de nas33
salu c sont pas les meme injecteur moi c les dernier siemens avec 6 chiffre et lettre et ils faut rajouter un zero pour faire 7 .faut il code acces ou code pin pour pouvoir y acceder car c ecu pcr 2.1
Vieux 29/11/2015, 18h35   #4
seadoo831
Avatar de seadoo831
Pouvoir de réputation: 124
Salut geronimoindien je t ai demander sur ce lien de te mettre en regle avec le forum avant de poster et tu post a nouveau sans etre en regle !!
donc a dans 3 jours crdl
http://www.tlemcen-electronic.com/fo...ad.php?t=46780
Pas de Thank's plus d aides
Vieux 29/11/2015, 18h42   #5
justinyours
Avatar de justinyours
Bonsoir pour programer tes code avec vcds il faut passer par accès securisé puis entre le code après tu vas dans adaptation et tu change le code .
justinyours est déconnecté   Réponse avec citation
Vieux 30/11/2015, 07h49   #6
doud77
Avatar de doud77
Nas33,
pourquoi veux tu rajouter un zero?
Pour être sûr tu peux aussi vérifier tes codages en faisant une lecture de blocs, regarde comment l'injecteur est codé avec VCDS et compare avec ce qui est gravé sur l'injecteur.
Ensuite tu codes ton nouvel injecteur sur le meme schema.
Codage injecteur clio 1.5 dci impossible YUMBO Renault, Dacia, Nissan 8 18/10/2015 21h14
codage injecteur dv6 edc16c34 alexisraynaud PSA Group Peugeot, Citroën 8 17/10/2015 13h56
codage injecteur ford Ecomouv Ford, Mazda, Land Rover, Jeep, Jaguar 11 25/09/2015 12h52
Probleme codage injecteur scenic 2 1.5 Verdun Mécanique générale 11 21/10/2014 00h12
codage injecteur 206 1.4 hdi smt PSA Group Peugeot, Citroën 5 29/04/2012 16h10
Fuseau horaire GMT +1. Il est actuellement 03h07.
