Vieux 24/10/2026, 16h20   #1
maximin
Avatar de maximin
maximin is a name known to allmaximin is a name known to allmaximin is a name known to allmaximin is a name known to allmaximin is a name known to allmaximin is a name known to all
Par défaut Carte non reconnue clio 4
salut ,
J’ai ma carte clio 4 non reconnue - existe t il un moyen de la réparer ?
maximin est déconnecté   Réponse avec citation
Vieux 24/10/2026, 18h33   #2
mo3ad
Avatar de mo3ad
mo3ad is an unknown quantity at this point
la maladie c'est la carte en elle meme tu en achète une en chine et tu la reprogramme avec renolink ou autre
mo3ad est déconnecté   Réponse avec citation
The Following User Says Thank You to mo3ad For This Useful Post:
maximin (25/10/2026)
Vieux 24/10/2026, 18h55   #3
MrRorry
Avatar de MrRorry
MrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond repute
Attention, renolink te fume le HFM (=> vierge) sur clio 4 apres 2015
a eviter!
MrRorry est déconnecté   Réponse avec citation
The Following 6 Users Say Thank You to MrRorry For This Useful Post:
a3pughjolu (24/10/2026), chipshop (24/10/2026), jean-marc 10 (24/10/2026), matt978 (25/10/2026), maximin (25/10/2026), phil1 (24/10/2026)
Vieux 24/10/2026, 19h14   #4
a3pughjolu
Avatar de a3pughjolu
Pouvoir de réputation: 23
a3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud of
Salut ça ne reparera pas ta carte, mais si tu es vraiment embété pour le demarrage en attendant es ce que tu as essayé de glisser entre ta carte et le lecteur quelque chose de plat et de metallique pour essayer de voir un eventuel default d'antenne de la carte...
The Following User Says Thank You to a3pughjolu For This Useful Post:
Vieux 24/10/2026, 19h30   #5
chipshop
Avatar de chipshop
Pouvoir de réputation: 52
Bien-sûr que ça ce répare
pas d'aides sans les thanks !!!
chipshop est déconnecté   Réponse avec citation
The Following User Says Thank You to chipshop For This Useful Post:
phil1 (24/10/2026)
Vieux 24/10/2026, 20h58   #6
phil1
Avatar de phil1
Pouvoir de réputation: 109
Envoyé par chipshop Voir le message
slt yess le souci tu te retrouve avec une coque renew plus épaisse autant refaire une 4a ml y en a de bonne qualité pas trop épaisse coince moins ds le hfm.
---------- Post added at 20h58 ---------- Previous post was at 20h55 ----------
Envoyé par mo3ad Voir le message
mouais déjà vu des made in china tu la retire et ta que la lame ds la main le reste es dans le hfm....lol
les fous ne comprennent rien. moi je pense qu' ils sont devenus fous parce qu' ils ont tout compris
jean-marc 10 (25/10/2026), maximin (25/10/2026)
Vieux 25/10/2026, 08h28   #7
maximin
Avatar de maximin
Salut les amis,
J’ai réussi à la réparer en suivant une méthode sur la chaîne .
Il fallait être patient pour l’ouvrir.
La panne venait d’un composant dessoudé , deux pattes ne faisaient plus contact sur trois.
Un petit coup de soudure ok.
Elle ne fait pas main libre. J’aurais aimé en appairer une mais si avec renolink ça risque de bloquer , je laisse comme ça .
The Following 2 Users Say Thank You to maximin For This Useful Post:
matt978 (25/10/2026), MrRorry (25/10/2026)
Vieux 25/10/2026, 10h23   #8
matt978
Avatar de matt978
Envoyé par maximin Voir le message
Salut les amis,
bien joué
bon dimanche
If you want to touch the sky, f**k a duck and try to fly!
matt978 est connecté maintenant   Réponse avec citation
Vieux 25/10/2026, 13h28   #9
MrRorry
Avatar de MrRorry
Bien joué pour la reparation
Oui, attention a renolink, il pretend faire des choses qu'il ne fait pas!
Conseil a ceux qui voudraient tenter leur chance
Lire le HFM (avec par exemple Orange5) avant de s'aventurer avec des outils de ce genre
Comme ca en cas de virginisation / brickage,
possible de le restaurer, recuperer PIN et ISK avec RET
Lire Clio 4 HFM avec Orange5
The Following 2 Users Say Thank You to MrRorry For This Useful Post:
Vieux 25/10/2026, 17h42   #10
maximin
Avatar de maximin
Merci Mr Rorry.
Avec orange5 ça aide en cas de mauvaises manipulations .
Je le saurais.
Megane 3 carte non reconnue Abbed Renault, Dacia, Nissan 12 02/09/2024 17h03
carte non reconnue pp08 programmation & synchronisation de clé 33 26/03/2023 19h16
Carte non reconnue Scenic 1.9 dci freeuser Renault, Dacia, Nissan 8 16/02/2022 15h03
Laguna 2 2.2dci carte non reconnue samnguen Renault, Dacia, Nissan 11 06/10/2016 22h34
Fuseau horaire GMT +1. Il est actuellement 09h43.
