Vieux 30/10/2019, 15h40   #16
lufy93
Avatar de lufy93
lufy93 will become famous soon enough
Salut pareil mm souci j’ai changer le verrou de Cologne par un neuf g labrites et elle ne l’adapte pas
Donc case Renault obligatoire je pense
lufy93 est déconnecté   Réponse avec citation
Vieux 30/10/2019, 16h27   #17
bel27
Avatar de bel27
bel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond repute
Salut Renault.net
bel27 est déconnecté   Réponse avec citation
Vieux 30/10/2019, 16h39   #18
Inductance974
Avatar de Inductance974
Inductance974 is a jewel in the roughInductance974 is a jewel in the roughInductance974 is a jewel in the rough
Salut, avec abrites ca marche nickel.
J'en ai fait un la semaine dernière.
Mais il te faut le pin que tu sort avant la dépose.
---------- Post added at 17h39 ---------- Previous post was at 17h37 ----------
j'ai la version 7.4 dacia/renault, tu as quelle version?
Inductance974 est déconnecté   Réponse avec citation
The Following User Says Thank You to Inductance974 For This Useful Post:
ggvaniou (30/10/2019)
Vieux 30/10/2019, 16h44   #19
ggvaniou
Avatar de ggvaniou
Pouvoir de réputation: 88
Renolink le fais
BAZBOZ (30/10/2019)
Vieux 30/10/2019, 18h41   #20
BAZBOZ
Avatar de BAZBOZ
BAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of light
Renolink le fais
Bonsoir, c'est quelle version renolink? La 182?.
BAZBOZ est déconnecté   Réponse avec citation
Vieux 13/06/2020, 18h56   #21
rokho
Avatar de rokho
Pouvoir de réputation: 9
rokho has a spectacular aura aboutrokho has a spectacular aura about
Envoyé par BAZBOZ Voir le message
J'avais le v1.84 renolink !j'ai fais une lecture code pin et isk pour ma clio 4 ph1!
rokho est déconnecté   Réponse avec citation
Vieux 13/06/2020, 19h34   #22
rokho
Avatar de rokho
Envoyé par rokho Voir le message
J'ai vu qu'il a un apprentissage colone vierge pour clio4! mais il faut avoir le code Apv!
Vieux 25/01/2022, 17h41   #23
aurelien
Avatar de aurelien
aurelien will become famous soon enoughaurelien will become famous soon enough
Bonsoir est ce que quelqu un pourrait me donner la procedure pour adapter un verrou colonne d occasion clio 4 ph 1 avec l abrites ?
Merci d avance
aurelien est déconnecté   Réponse avec citation
Vieux 25/01/2022, 19h17   #24
tdipower11
Avatar de tdipower11
tdipower11 is a jewel in the roughtdipower11 is a jewel in the roughtdipower11 is a jewel in the rough
Envoyé par aurelien Voir le message
Merci d avance
Il faut faire vierge d’abord est après apprentissage.
tdipower11 est déconnecté   Réponse avec citation
Vieux 25/01/2022, 19h41   #25
aurelien
Avatar de aurelien
T es sur ?
J ai recuperer le pin dans apprentissage clé
J ai ete dans adaptation ESL
Rentré le pin
Adaptation reussi
Mais j ai toujours le meme default dtca051 "composant installe incorrect"
Verrou de colonne espace IV 2.2 dci Malfra90 Renault, Dacia, Nissan 57 14/08/2020 15h30
dump verrou de colonne clio 3 Meziane93 programmation & synchronisation de clé 7 15/04/2019 08h38
A6 ,verrou de colonne passion-auto VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 3 28/10/2017 18h32
verrou colonne serie 1 nimbus Immobilizer dumps/solutions 2 07/10/2016 18h18
Verrou colonne laguna 3 sam93 Renault, Dacia, Nissan 7 05/09/2015 22h49
Fuseau horaire GMT +1. Il est actuellement 05h22.
