Vieux 02/10/2024, 19h47   #106
Pouvoir de réputation: 113
Mouais me penche de plus en plus vers le swap ecu de 6.3 à 6.1 mdr
seadoo831 (02/10/2024)
Vieux 03/10/2024, 18h22   #107
apol
Avatar de apol
apol is just really niceapol is just really niceapol is just really niceapol is just really nice
Possible with some pin swap :) on the loom
apol est déconnecté   Réponse avec citation
The Following User Says Thank You to apol For This Useful Post:
fils (04/10/2024)
Vieux 04/10/2024, 08h29   #108
Yes on paper seems possible
Do you have an advice to make SW compatibility like something that works Fsave or other better ?
Vieux 07/10/2024, 00h11   #109
apol
Avatar de apol
You have old ecu upgraded or new ecu ?
fils (07/10/2024)
Vieux 07/10/2024, 08h05   #110
No study case for moment.
Just I think how make the best SW compatibility.
To have a 100-100 working car
akasa67 (07/10/2024)
Vieux 07/10/2024, 10h23   #111
apol
Avatar de apol
I did programing for a guy with a citroen dispatch ecu euro6.4 2023 swap to >> euro6.2 2018
there needed to be found sw for dispatch with 6.2 and reprogram ecu , source ecu was from r8 2018 :)
after all there need to rewire pins for fuel heater as 2 differ ecus but at the end worked well :) with adblue off
The Following 2 Users Say Thank You to apol For This Useful Post:
Fastdiag (07/10/2024), youcar (10/10/2024)
Vieux 07/10/2024, 10h35   #112
apol
Avatar de apol
The Following 6 Users Say Thank You to apol For This Useful Post:
DIAGAUTO33 (07/10/2024), djardo42 (11/10/2024), elmostro (07/10/2024), fils (10/10/2024), fufounet (07/10/2024), youcar (10/10/2024)
Vieux 10/10/2024, 13h36   #113
DGPERFORMANCE26
Avatar de DGPERFORMANCE26
DGPERFORMANCE26 is an unknown quantity at this point
Ola, toujours bloquer sur la V9?
Je réfléchis pour un client a un swap calculateur, c'est possible?
J'ai vu que apol était caler la dessus, et qu'il y aurait des fils à inverser...
Merci ;)
---------- Post added at 13h36 ---------- Previous post was at 13h35 ----------
DGPERFORMANCE26 est déconnecté   Réponse avec citation
Vieux 10/10/2024, 17h40   #114
Avant de s occupe des fils faut gérer compatibilité sw
Gros dossier malheureusement pas donné à n importe qui :-)
jah83 (24/10/2024), seadoo831 (10/10/2024)
Vieux 11/10/2024, 10h40   #115
apol
Avatar de apol
Envoyé par DGPERFORMANCE26 Voir le message
Merci ;)
No one have simple can log what's is happens here....and what data is send to server????
khoums (06/11/2024)
Vieux 11/10/2024, 14h23   #116
Serveur is autotuner politics
Log nothing interesting ecu directly respond nack to SA
apol (11/10/2024), jah83 (24/10/2024)
Vieux 11/10/2024, 19h28   #117
apol
Avatar de apol
But that's the interesting part :) if anyone have would like to the log but pure can log not the what soft doo. :)
fils (23/10/2024)
Vieux 12/10/2024, 10h31   #118
Ok will make you can log
Vieux 23/10/2024, 19h12   #119
Sorry
Have try with 3 different loggers ( listen mode on off, multiple bauds ) always the flasher detect it or bus error :-(
If you know exactly what config is necessary to pass under detection let me know.
Vieux 24/10/2024, 12h19   #120
mathinen25
Avatar de mathinen25
mathinen25 is an unknown quantity at this point
Effectivement je les lis sans problème en BENCH avec mon KESS3 mais aujourd'hui pas de lecture calculateur protegé.
Je vais ouvrir un ticket chez alientech
mathinen25 est déconnecté   Réponse avec citation
Codage nouvelle batterie (pas VW) avec vcds Dorvel VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 16 02/03/2023 04h51
md1CS003 karera 1 Programmateur de composant (flasher) 35 01/11/2022 19h22
Protection des cartes (PCB) avec ESD Suppresseur ElTurco Electronique 5 14/05/2019 16h50
Nouvelle clé Clio 4 avec RET Miidjyy programmation & synchronisation de clé 10 14/02/2019 15h01
Fuseau horaire GMT +1. Il est actuellement 16h52.
