Vieux 23/09/2020, 12h36   #46
sadna
Avatar de sadna
Pouvoir de réputation: 36
Capteur pression de Rampe HS
YomGui (24/09/2020)
Vieux 23/09/2020, 13h21   #47
SaTouF
Avatar de SaTouF
SaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond repute
essais un petit coup de start pilote ou nettoyant frein
si elle démarre c'est que t'a les joints du régulateur de pression qui sont HS
c'est courant sur les hdi.
SaTouF est déconnecté   Réponse avec citation
The Following User Says Thank You to SaTouF For This Useful Post:
YomGui (24/09/2020)
Vieux 23/09/2020, 14h04   #48
maitresox
Avatar de maitresox
Pouvoir de réputation: 69
maitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond repute
Bon ba çà avance. Tu peux faire des tests actionneurs dans l'item antidémarrage.
Test des clés ....
maitresox est déconnecté   Réponse avec citation
The Following User Says Thank You to maitresox For This Useful Post:
YomGui (24/09/2020)
Vieux 23/09/2020, 20h02   #49
YomGui
Avatar de YomGui
YomGui has a brilliant futureYomGui has a brilliant futureYomGui has a brilliant futureYomGui has a brilliant futureYomGui has a brilliant futureYomGui has a brilliant futureYomGui has a brilliant futureYomGui has a brilliant futureYomGui has a brilliant futureYomGui has a brilliant futureYomGui has a brilliant future
Oui je vais tester les clés. Pour moi c'est lié maintenant avec presque certitude que c'est l’antidémarrage car j'ai du courant partout et j'ai fais des tests croisés avec les capteurs
Plus on est uni et moins on est seul(e) :)
YomGui est déconnecté   Réponse avec citation
Vieux 23/09/2020, 20h11   #50
Slt l ami y n aurais pas couper les fil de l autoradio sur cette voiture ..
YomGui (23/09/2020)
Vieux 23/09/2020, 21h17   #51
YomGui
Avatar de YomGui
Non les fils autoradio bleu et rouges sont ensembles sertis si tu veux savoir :-)
49627 km la voiture du papi.
Je vais essayer un autre com2000 demain si j'ai le temps et je vais essayer de la tracter pour voir si elle démarre
The Following User Says Thank You to YomGui For This Useful Post:
akasa67 (23/09/2020)
Vieux 23/09/2020, 21h35   #52
Envoyé par YomGui Voir le message
Le com 2000 ok les phare ne reste pas allumé etc.. jai regarder au dessus au tous début du poste tu dit immo OK et la non dans le bsi le papi a pas ouvert la cle je suppose que tu a essayer le double de la voiture la dernière fois jai fais un partner ok dtc il avais ouvert la cle changer la coque 3 jours avant j'avais 0 bar ensuite jai ouvert la cle car ecm verrouillée il avais rien ..
---------- Post added at 07:35 PM ---------- Previous post was at 07:29 PM ----------
si l immo et bloquer tu peu faire 20 tours dans le village jamais elle demarre..pour moi probleme de cle ou de com 2000
Dernière modification par akasa67 ; 23/09/2020 à 21h38.
The Following 4 Users Say Thank You to akasa67 For This Useful Post:
fedge (24/09/2020), Micka1115 (24/09/2020), Pilouf (24/09/2020), YomGui (24/09/2020)
Vieux 24/09/2020, 06h54   #53
Micka1115
Avatar de Micka1115
Pouvoir de réputation: 9
Micka1115 will become famous soon enoughMicka1115 will become famous soon enough
+1 avec Akasa, c'est pas faute d'avoir insisté dès le début sur l'état de l'antidémarrage
Micka1115 est déconnecté   Réponse avec citation
The Following User Says Thank You to Micka1115 For This Useful Post:
YomGui (24/09/2020)
Vieux 24/09/2020, 07h59   #54
Axid
Avatar de Axid
Axid is on a distinguished road
Salut l'amI
La voiture est elle arrivé roulante ou en panne au garage?
Voir si tu n'a pas inversé 2 fiches de capteur en changeant tes tuyau .
Axid est déconnecté   Réponse avec citation
The Following User Says Thank You to Axid For This Useful Post:
YomGui (24/09/2020)
Vieux 24/09/2020, 07h59   #55
salim-diad13
Avatar de salim-diad13
salim-diad13 is on a distinguished road
débranche ta batterie et rebranche
salim-diad13 est déconnecté   Réponse avec citation
The Following User Says Thank You to salim-diad13 For This Useful Post:
YomGui (24/09/2020)
Vieux 24/09/2020, 08h24   #56
Pilouf
Avatar de Pilouf
Pouvoir de réputation: 80
Envoyé par salim-diad13 Voir le message
BONJOUR...
A lire tes messages, apparemment tu connais pas les formules de politesses !!!
Il y a un règlement sur le forum, au lieu de poster n'importe quoi sans lire les sujets, tu devrais le prendre en compte et l'appliquer !!
---------- Post added at 06h24 ---------- Previous post was at 06h19 ----------
... Le moteur se lance mais ne veut pas démarrer comme si c'était une panne antidémarrage alors que tout va bien de coté la.
Salut YomGui,
Tu avais contrôlé l'anti démarrage au départ ??
Le calculateur moteur était déverrouillé ??
fedge (24/09/2020), YomGui (24/09/2020)
Vieux 24/09/2020, 12h31   #57
YomGui
Avatar de YomGui
La voiture est arrivée sur plateau je ne l'ai jamais vue démarrée.
Je pense que je vais faire un immo off car j'ai l'impression que le calculo moteur est bloqué
Vieux 24/09/2020, 15h04   #58
YomGui
Avatar de YomGui
Par défaut Immo off Bosch 16C34
Petite confirmation que l'option que j'ai choisi est la bonne ?
Type de fichier : jpg Immo off 206 EDC16C34.jpg (96,3 Ko, 29 affichages)
Vieux 24/09/2020, 16h54   #59
fedge
Avatar de fedge
Salut.
Oui c est la bonne.
Vieux 24/09/2020, 16h55   #60
fedge
Avatar de fedge
Sinon tu fais avec ca
Type de fichier : rar EDC16C34.rar (144,2 Ko, 4 affichages)
The Following User Says Thank You to fedge For This Useful Post:
neoamtrixe (24/09/2020)
ford c max 2007 demarre pas repcles Ford, Mazda, Land Rover, Jeep, Jaguar 30 26/05/2022 12h46
expert 2.0 hdi année 2007 demarre et cale tom077 Mécanique générale 193 16/03/2015 13h33
Saab 9.3 1,9 tid de 2007 ne démarre plus nicocar Mécanique générale 0 07/01/2014 21h53
vw caddy 2007 démarre pas parfois verdi VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 3 24/12/2013 15h29
sprinter 2007 mode degrade dollarbill Mercedes Benz 5 27/11/2013 22h42
Fuseau horaire GMT +1. Il est actuellement 00h43.
