Vieux 19/04/2019, 19h28   #1
tarik_electronic
Avatar de tarik_electronic
Pouvoir de réputation: 40
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
Par défaut Immo off edc16c34
SALUT
je cherche un immo off ok
PEUGOET EXPERT 2010
edc16C34 BOCSCH 0 281 013 869
DEJA ESSAYER AVEC SOFT EDC16C34 IMMO OFF MAIS PAS OK
QUEL Q1 PEUX M AIDE ??
Type de fichier : bin EDC16C34 ORI.BIN.bin (2,0 Ko, 27 affichages)
oublié pas le petit " thanks "
tarik_electronic est déconnecté   Réponse avec citation
Vieux 19/04/2019, 19h55   #2
Tof02770
Avatar de Tof02770
slt lami voila pout toi fais un retour svp merci
Type de fichier : rar immooff tarik EDC16C34 ORI.rar (974 octets, 10 affichages)
tarik_electronic (20/04/2019)
Vieux 19/04/2019, 21h18   #3
nacerweb
Avatar de nacerweb
nacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud of
salut pas de off la dessus.
nacerweb est déconnecté   Réponse avec citation
The Following User Says Thank You to nacerweb For This Useful Post:
Vieux 19/04/2019, 21h35   #4
Tof02770
Avatar de Tof02770
Bien-sûr que oui déjà testé ça existe mon ami
The Following 2 Users Say Thank You to Tof02770 For This Useful Post:
Alilouf (20/04/2019), tarik_electronic (20/04/2019)
Vieux 20/04/2019, 00h06   #5
nacerweb
Avatar de nacerweb
ca n'existe pas mon ami edc16c34 nouvelle generation avec reference bosch 0281013 ou 0281014 pas de off ,ce que tu peut faire vierge et autocoding la dessus.
The Following 3 Users Say Thank You to nacerweb For This Useful Post:
Alilouf (20/04/2019), labiadh adel (20/04/2019), tarik_electronic (20/04/2019)
Vieux 20/04/2019, 06h43   #6
tarik_electronic
Le code pin ????
Vieux 20/04/2019, 07h25   #7
WJon
Avatar de WJon
Pouvoir de réputation: 59
Envoyé par tarik_electronic Voir le message
Le code pin ????
Salut Tarik,
Le pin est TTTX
Et voila pour toi.
en MP
Type de fichier : rar Desktop.rar (2,1 Ko, 1 affichages)
alexvin (20/04/2019)
Vieux 20/04/2019, 08h07   #8
j-sky
Avatar de j-sky
Pouvoir de réputation: 143
Voici le décodage de ton dump
Refroidissement moteur :Groupe motoventilateur 2 vitesses (avec air conditionné)
Capteur de pression climatisation :Pas de climatisation
Boîte de vitesses :Boîte de vitesses manuelle courte
Classe alternateur :Classe 8
Carrosserie :Pompe HP CP1H (connecteur droit)
Chauffage additionnel :Pas de chauffage additionnel
Contrôle de stabilité (ESP) :Absent
Régulation de vitesse véhicule :Absent
Boîtier de servitude intelligent (BSI) :Relié au calculateur contrôle moteur par liaison multiplexée
Liaison avec la boîte automatique :Non applicable
Antiblocage de roues (ABS) :Présent
Limitation de vitesse véhicule :Absent
Type d'injecteur: Bosch CRI 2.1
Injecteur cylindre n° 1: FC014090
Injecteur cylindre n° 2: 04213DB0
Injecteur cylindre n° 3: FA205CD0
Injecteur cylindre n° 4: 0230A1B0
Code PIN : TTTX
et ton fichier mis en off (pass dans ta boite)
Type de fichier : rar EDC16C34 ORI.BIN-immo off.rar (975 octets, 5 affichages)
Rappel des règles du forum
The Following 7 Users Say Thank You to j-sky For This Useful Post:
alexvin (20/04/2019), Alilouf (20/04/2019), bkprog13 (20/04/2019), nacerweb (20/04/2019), tarik_electronic (20/04/2019), Tof02770 (20/04/2019), WJon (20/04/2019)
Vieux 20/04/2019, 09h22   #9
bkprog13
Avatar de bkprog13
vraiment on aura tout entendu « edc16c34 nouvelle génération « loool.
c’est sur fiat mazda volvo et j’en passe ou il n’y a pas de off...
nacerweb tu as du essayer sur genre un nemo qui n’est pas une citroen...
The Following 5 Users Say Thank You to bkprog13 For This Useful Post:
Alilouf (20/04/2019), INVICTUS (20/04/2019), j-sky (20/04/2019), tarik_electronic (20/04/2019), WJon (20/04/2019)
Vieux 20/04/2019, 12h05   #10
tarik_electronic
merci les amis
merci j-sky immo off ok
The Following 3 Users Say Thank You to tarik_electronic For This Useful Post:
Alilouf (20/04/2019), j-sky (20/04/2019), nacerweb (20/04/2019)
Vieux 20/04/2019, 13h29   #11
tarik_electronic
la voiture en mode degrade il ya un solution ??
Vieux 20/04/2019, 13h39   #12
nacerweb
Avatar de nacerweb
j'ai repondu un peu rapidement ,c'est vrai le pin est defini alors le off pass sans probleme .
Vieux 20/04/2019, 13h39   #13
j-sky
Avatar de j-sky
Quels sont les défauts mémorisés ?
On ne peut pas tout deviner !
Il faut donner le max d’infos si tu veux de l’aide...
The Following 3 Users Say Thank You to j-sky For This Useful Post:
tarik_electronic (20/04/2019), Tof02770 (20/04/2019), WJon (08/07/2022)
Vieux 20/04/2019, 13h48   #14
Tof02770
Avatar de Tof02770
Je vien envoie email à l'instant a tarik pr demande si il as pas voyant allumé et si il as pas défaut lol
Vieux 20/04/2019, 14h31   #15
tarik_electronic
LUNDI INCHALAH JE POSTE LES INFOS
je cherche le off parce que J'ai perdu les clés de voiture
Immo off edc16c34 407 Malfra90 Immobilizer dumps/solutions 5 01/04/2017 12h25
immo off ecu edc16c34 nas33 Immobilizer dumps/solutions 4 06/03/2017 19h12
Immo off edc16c34 MEDELAS Immobilizer dumps/solutions 13 11/05/2016 22h37
Immo Off C4 HDI edc16C34 Nextrick Immobilizer dumps/solutions 9 29/03/2014 15h17
immo off edc16c34 207 dump974 Immobilizer dumps/solutions 9 24/04/2012 11h38
Fuseau horaire GMT +1. Il est actuellement 15h17.
