Vieux 23/08/2018, 10h35   #1
sami_b
Avatar de sami_b
sami_b is an unknown quantity at this point
Par défaut Aide pour log erreurs
Bonjour Je viens de faire un scan complet et voici le log des erreurs
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AK HW: 3C0 614 109 AK
Component: J104 C4 440 V2 0027
Revision: --025--- Serial number: 00000705619431
Coding: 0035311
Shop #: WSC 00028 790 00002
VCID: 67DA60DE56F6947948-8032
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 71
Mileage: 166828 km
Time Indication: 0
Date: 2013.01.06
Time: 1154
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 11.50 V
Bin. Bits: 00011111
Count: 163
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000003
Shop #: WSC 00028 028 00022
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 7DF622B6EC6A2EA982-8028
1 Fault Found:
13701968 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 22
Reset counter: 43
Mileage: 166424 km
Date: 2018.06.26
Time: 1133
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 3C8 919 475 A HW: 3C8 919 475
Component: PARKHILFE 8K H07 0009
Revision: -------- Serial number: 08791012036875
Coding: 100002
Shop #: WSC 00028 028 00001
VCID: 326CC18A6DB421D12F-8066
2 Faults Found:
02070 - Rear Parking Aid Sensors
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 166424 km
Time Indication: 0
Date: 2012.11.16
Time: 10:23:56
Freeze Frame:
Temperature: 31.0�C
02069 - Front Parking Aid Sensors
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 166424 km
Time Indication: 0
Date: 2012.11.16
Time: 10:23:56
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C0 920 872 G HW: 3C0 920 872 G
Component: KOMBI H03 0305
Serial number: 00000000000000
Coding: 160F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 295E26E6486262099E-807C
1 Fault Found:
9453330 - Outside temperature sensor
B103F 1B [008] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Mileage: 166424 km
Date: 2018.06.26
Time: 11:09:00
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 7AFC29AA35441991A7-802E
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 2
Reset counter: 47
Mileage: 166427 km
Time Indication: 0
Date: 2012.11.25
Time: 00:00:43
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 A HW: 3C0 959 793 A
Component: TUER-SG FT 002 0305
Revision: 12101005 Serial number: 0000871874
Coding: 0210B7
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 26442DDA597C4D71B3-8072
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0402
Serial number: 00000001461478
Coding: 000090
2 Faults Found:
66048 - Motor for Front Window Regulator
B11EC 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 74
66561 - Motor for mirror fold-in
B11F6 01 [008] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 70
Mileage: 166337 km
Date: 2018.06.04
Time: 07:34:03
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.147 0703
Revision: 1AH03726 Serial number: 00101230108101
Coding: 0000258
VCID: 3A7CE9AA75C4D991E7-806E
1 Fault Found:
01288 - Terminal 30; Steering Assist
Freeze Frame:
Fault Priority: 9
Fault Frequency: 1
Reset counter: 45
Mileage: 166425 km
Time Indication: 0
Date: 2012.11.25
Time: 00:00:01
Freeze Frame:
Term 15 On
RPM: 0 /min
Speed: 0.0 km/h
(no units): 2.0
Voltage: 12.30 V
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 A HW: 3C0 959 792 A
Component: TUER-SG BT 002 0305
Revision: 14101005 Serial number: 0000864696
Coding: 0210B6
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 275A20DE5E76547988-8072
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0402
Serial number: 00000001459122
Coding: 000090
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 74
Envoyé de mon SM-N9005 en utilisant Tapatalk
---------- Post added at 09h35 ---------- Previous post was at 09h33 ----------
Je suis encore bleu et je m adresse a vous pour m aider a décrypter les erreurs
sami_b est déconnecté   Réponse avec citation
Vieux 26/08/2019, 02h45   #2
m.initial
Avatar de m.initial
m.initial is on a distinguished road
Bonjour sami
en diag tu as des défauts permanents et certain intermittents
Ces événements sont stockés en mémoire
Tes défauts date de 2018 voir même de 2012
Le premier message est un défauts abs
Il s se peut qu ils est été réparé et pas effacé de la mémoire
Certain préfèrent garder les défauts pour savoir l historique du véhicule
Mais parfois il faut effacer les défauts faire un essai du véhicule
et voir ceux qui réapparaissent
Une simple panne de batterie ou panne sèche peuvent faire apparaître une multitude de défaut
Quelle est le problème sur ton véhicule et quelle modèle
Voila si ca peut t aider
---------- Post added at 02h45 ---------- Previous post was at 02h41 ----------
efface les défauts et vois si ils reviennent
m.initial est déconnecté   Réponse avec citation
Lecture code erreurs BMW 525D E39 bemoz BMW, Mini, Rolls-Royce 23 08/06/2015 21h59
C5II '05 - Erreurs perm. FC02 retro, FC07 clim Hygrom. et F702 capteur angle volant go_modem_go PSA Group Peugeot, Citroën 1 02/03/2015 19h37
Liens pour erreurs ODB Goqu Logiciel & autres documentations général 1 29/03/2014 17h01
Trouver les 3 erreurs TOP du TOP Amine-TE Café du forum 14 23/02/2014 18h26
Codes erreurs peugeot citroen sidj PSA Group Peugeot, Citroën 14 17/06/2009 22h49
Fuseau horaire GMT +1. Il est actuellement 02h22.
