Banned
slt tlm
je viens de acheter une leon et j trouver c erreur c grave ???? Wednesday,04,October,2017,20 50:05533VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 14.10.2.0 Data version: 20150311 www.Ross-Tech.com VIN: VSSZZZ1PZDR031528 License Plate: 05/10/2017 Mileage: 106160km-65964mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1P (7N0) Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72 VIN: VSSZZZ1PZDR031528 Mileage: 106160km-65964miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CLCB) Labels: None Part No SW: 03L 906 018 GM HW: 03L 906 018 FJ Component: R4 2,0L EDC H25 1008 Revision: 42H25--- Serial number: Coding: 00190012042400080000 Shop #: WSC 06402 785 00200 ASAM Dataset: EV_ECM20TDI01103L906018GM 003004 ROD: EV_ECM20TDI01103L906018GM.rod VCID: 7BF5A630F2F0FDF93BD-802E No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL Component: ESP MK60EC1 H31 0152 Revision: 00H31001 Coding: 113B4012092500FB881002E690210042350800 Shop #: WSC 04941 000 00000 VCID: 7DF1A828E4E4F3C9059-8028 1 Fault Found: 02214 - Tire Pressure Warning 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 0 Mileage: 106169 km Time Indication: 0 Date: 2017.10.04 Time: 20 19Freeze Frame: Count: 3 Count: 2 Count: 12800 Count: 397 Count: 49408 Count: 65024 Count: 254 Count: 0 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: ----------- HW: ----------- Component: Climatronic 0909 Revision: -------- Coding: 0000004002 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_Climatronic A01010 ROD: EV_ClimaAutoBasis_SE35.rod VCID: 6FED8260B6889159875-803A 2 Faults Found: 9472021 - Temperature Sensor for Right Vent B1088 15 [009] - Open or Short to Plus Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 0 Mileage: 106169 km Date: 2017.10.04 Time: 20 569479185 - Signal Line for Air Quality Sensor B10A4 11 [009] - Short to Ground Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 0 Mileage: 106169 km Date: 2017.10.04 Time: 20 56------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 5K0 937 087 R HW: 5K0 937 087 R Component: BCM PQ35 H 021 0068 Revision: BE021001 Coding: 46180A3E80250CC042080080950089C442550008627D816000 8040000040 Shop #: WSC 00011 888 77253 VCID: 44871DCCC78E42010A7-8011 Subsystem 1 - Part No: 1P0 955 119 D Component: Wischer 30101 26 0611 Coding: 00DB90 1 Fault Found: 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 0 Mileage: 106169 km Time Indication: 0 Date: 2017.10.04 Time: 20 31Freeze Frame: Term 15 On Voltage: 13.75 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 10: Park/Steer Assist Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA Component: J234__A0A VW10 HI 2118 Revision: 24017000 Serial number: 003L7PNS0T18 Coding: 0012353 Shop #: WSC 06402 785 00200 VCID: 7CF7A52C3FFEFAC1327-8029 Subsystem 1 - Serial number: 6332MTS615842952 Subsystem 2 - Serial number: 6342MTS621242952 Subsystem 3 - Serial number: 6351HTS616O5FBKR Subsystem 4 - Serial number: 6361HTS686DHHBKJ Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E Component: LENKS.MODUL 014 0140 Revision: FF010041 Serial number: 20121103200295 Coding: 1082140002 Shop #: WSC 06402 785 00200 ASAM Dataset: EV_SMLSNGVOLWSXS A01004 ROD: EV_SMLSNGVOLWS.rod VCID: 79F9BC38F8CCCFE9291-802C Multi Function Steering Wheel Control Module: Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB Component: E221__MFL-TAP H02 0103 Coding: E20000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 1P0 920 850 N HW: 1P0 920 850 N Component: KOMBI H03 0705 Serial number: 00000000000000 Coding: 110E01 Shop #: WSC 131071 1023 2097151 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716 ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod VCID: 377D7A008E5819999F5-8062 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 1P0 920 850 N HW: 1P0 920 850 N Component: KOMBI H03 0705 Serial number: 00000000000000 Coding: 110E01 Shop #: WSC 131071 1023 2097151 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716 ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod VCID: 377D7A008E5819999F5-8062 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF Component: J533 Gateway H52 1634 Revision: H52 Serial number: 211012F2000865 Coding: 350202 Shop #: WSC 04941 000 00000 VCID: 74E78D0CD7AEB2817A7-8021 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H03 0705 Serial number: Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709 ROD: EV_Immo_UDS_VDD_RM09_SE25.rod VCID: 6ADB93748D6A7471D0B-803F No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl Part No SW: 5N0 035 342 F HW: 5N0 035 342 F Component: SG EXT.PLAYER H18 0546 Revision: A1001003 Serial number: 7663690733 Coding: 010100 Shop #: WSC 04941 000 00000 VCID: 2A5B537445EAB47110B-807F No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb Part No SW: 3C8 959 701 HW: 3C0 959 793 C Component: TUER-SG FT 002 0507 Revision: 12110009 Serial number: 0005681203 Coding: 0010B0 Shop #: WSC 06402 785 00200 ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001 ROD: EV_TSGFPQ35BRFVW46X.rod VCID: 6DD19868BC846349B59-8038 Slave Driver: Subsystem 1 - Part No SW: 3C0 959 703 E HW: 3C0 959 795 E Component: J388__TSG-HL 008 1501 Serial number: 00000007307959 Coding: 000090 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K0 909 144 P Component: EPS_ZFLS Kl. 142 3305 Revision: 00H22000 Shop #: WSC 06402 785 00200 VCID: 377D7A00465819999F5-8062 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb Part No SW: 3C8 959 702 HW: 3C0 959 792 C Component: TUER-SG BT 002 0507 Revision: 14110009 Serial number: 0005737605 Coding: 0010B0 Shop #: WSC 06402 785 00200 ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001 ROD: EV_TSGBPQ35BRFVW46X.rod VCID: 6ED39F64B18298518C3-803B Slave Passenger: Subsystem 1 - Part No SW: 3C0 959 704 E HW: 3C0 959 794 E Component: J389__TSG-HR 008 1501 Serial number: 00000007314963 Coding: 000090 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0148 Revision: 00H04000 Serial number: Coding: 2556933 Shop #: WSC 06402 785 00200 VCID: 34674D0C572EF281BA7-8061 Subsystem 1 - Part No: 7L6 941 329 C Component: AFS-Lst.-Modul l 0004 Coding: 00000039 Subsystem 2 - Part No: 7L6 941 329 C Component: AFS-Lst.-Modul r 0004 Coding: 00000039 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb Part No SW: 5P0 035 186 B HW: 5P0 035 186 B Component: Media2.0 004 0082 Revision: 01000001 Serial number: SEZ1Z3M5089824 Coding: 01060400040000 Shop #: WSC 04941 000 00000 VCID: 2E535F647902D851CC3-807B No fault code found. End-------------------------(Elapsed Time: 02:59)-------------------------- |
T'inquiète rien de méchant dans ces défauts, mais essai d'abord d'effacer. |
| The Following User Says Thank You to hakimov For This Useful Post: | hichemok (05/10/2017) |
Y a t il un soucis avec la voiture ? Si pas de soucis, efface les défauts et te prend pas la tête avec. Tu verras ensuite avec le temps. Il s'agit peut être d'anciennes pannes. |
| The Following User Says Thank You to Pilouf For This Useful Post: | hichemok (05/10/2017) |
Banned
bjr
merci tlm de ma voire repende mais la je vien de sup les defaut mais les defaut ne ce surprime pas |
Pouvoir de réputation: 19 ![]() ![]() ![]() ![]() |
pas de soucis !! tu effaces tt et c bon ;)
jedes Problem hat eine Lösung. |
| The Following User Says Thank You to formator2 For This Useful Post: | hichemok (05/10/2017) |
Banned
j essaye de les efface mais son suces
salut hichemok
regardes ici : http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes je travaille toujours avec , et sa ma résolus mille problème c'est excellent !!!!!!!!!!! ---------- Post added at 11h20 ---------- Previous post was at 11h17 ---------- concernant effacement vcds un tuto : http://vag-repair.com/vcds-vas-pc/va...-codes-defaut/ |
| The Following User Says Thank You to zenata For This Useful Post: | hichemok (05/10/2017) |
Banned
bjr tlm
je suis entrain de sup erreur 01520 et tjr rien es ce que je peu faire une remise a 0"restauration dorigine" ou copier un ficher "DUMP"dun autre voiture la meme bien sur et le insère dans la main pq je pence que le propriétaire a fait un faut codage merci |
bonjour hichemok
donnes plus d'explications et des détails prends le temps d'écrire !!!!!!!! je comprend pas !!!!!! |
#10 | |
Un mauvais codage est possible mais il y a des contrôles à faire avant, http://wiki.ross-tech.com/wiki/index.php/01520 Bien sur contrôler les options réelles qui équipe cette voiture. |
01520 => Capteur de reconnaissance de pluie et de lumière (G397): signal introuvable Le pare-brise n'a pas été remplacé par hasard et le capteur obstrué ? |
Banned
Banned
#15 |
Banned
je viens de le régler il me reste 9472021 - Temperature Sensor for Right Vent 9479185 - Signal Line for Air Quality Sensor 01520 - Rain and Light Recognition Sensor (G397) |
| SEAT Leon EDC16 PIN | AMINEBOT | Transponder, code pin | 16 | 15/04/2026 16h35 |
| SOS seat leon 2014 fr | formator2 | VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche | 4 | 19/02/2018 13h46 |
| Seat leon | omar1980 | Electronique | 5 | 05/09/2017 18h53 |
| seat leon 2.0 2013 | jardini | VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche | 3 | 21/09/2016 21h45 |
| Seat leon | barto_95 | Tableau de bord (Dashboard) | 8 | 28/04/2010 00h21 |
