Vieux 22/06/2017, 20h40   #1
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut Lexia & PP2000 updates (DiagBox v8.47)
The software provided and the procedures proposed are intended for personal, educational and experimental use to install DiagBox 8.xx related updates. I hold no responsibility for any illegal or improper usage. Carry out this procedure at your own risk.
Links are provided in the attachments for 3 compilations "APP_Update_817-837.EXE", "APP_Update_835-838.EXE"و "APP_Update_838-842.exe", "APP_Update_842-846.exe" and "APP_Update_846-847.rar". Those executables are intended to update Lexia and PP2000 components of DiagBox from versions 8.17+ or 8.35 respectively, to the latest 8.42 and will bring Lexia v500.74 and PP2000 v600.80 to latest fixes or support level.
APP_Update_817-837.EXE update should be attempted if you have a working DiagBox v8.17 / v7.81 installation or higher, or if you have a working "APP-835.7z" implementation.
APP_Update_835-838.EXE update should be attempted if you have updated to 8.37 or a working "APP-835.7z" implementation. Update APP_Update_838-842.exe can then be installed.
Procedure:
1- Ensure you have a backup copy of the file "C:\AWRoot\bin\fi\APPDIAG.SYS" before you start.
2- Download and execute the appropriate file for your own setup. The process will copy all necessary files to the updt folder, it will then automatically kill all associated processes to enable overwriting without conflicts.
3- Run DiagBox to start the update process and wait until DiagBox is operational. Close DiagBox and restart your computer to ensure all processes are running.
Done..! you may run DiagBox as usual.. Notice that DiagBox version will NOT be changed by these updates..
Have fun!
Lexia language is set to English and PP2000 to french, if you wish to change them, edit the DICO.TXT file in the EXE folders of LEXIA or OUTILREP (PP2000) and replace "GB" with "FR" or vise versa.
P.S. DiagBox has been running on Firmware 4.3.4 since 7.66/8.02.
If you wish to change Lexia and PP2000 language, edit the DICO.TXT file in the EXE folders of LEXIA or OUTILREP (PP2000) and replace "GB" with "FR" or vise versa. For a more detailed process and other languages, review this link:
http://www.lesamisdudiag.com/diagbox/83513-diagbox-7-77-8-13-update-francais.html
Regards, Simple.
Type de fichier : rar Kill_DiagBox_Tasks.rar (223 octets, 94 affichages)
Type de fichier : txt Lexia-PP2000_update-817-847.txt (1,7 Ko, 205 affichages)
Simple est déconnecté   Réponse avec citation
The Following 19 Users Say Thank You to Simple For This Useful Post:
adiago (22/06/2017), al1962 (23/06/2017), autodiagauto (23/06/2017), DIAGAUTO33 (27/06/2017), elie (26/06/2017), guyguy307 (26/06/2017), kam306 (22/07/2017), lazizouille (21/01/2018), manudiag (01/11/2017), maskcoto (26/06/2017), mustaphcl (12/11/2017), nikita (27/06/2017), sadna (22/06/2017), samii1955 (21/07/2017), scanflo (21/07/2017), tatel (02/02/2018), taxi5114 (25/06/2017), vortex (26/06/2017), yoyomartin2003 (12/11/2017)
Vieux 26/06/2017, 19h30   #2
maskcoto
Avatar de maskcoto
maskcoto is on a distinguished road
Je testé cette nouvelle mise à jour et plus de soutien pour le nouveau moteur nous Téléchargements.
Je ne communiquaient avant et maintenant si elles ont la communication.
maskcoto est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to maskcoto For This Useful Post:
guyguy307 (26/06/2017), vortex (26/06/2017)
Vieux 19/07/2017, 23h50   #3
Shadows93
Avatar de Shadows93
Shadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to behold
Bonsoir a tous,
Se post est tres interessent
Donc si j'ai bien compris il permet d'avoir la derniere version de diagbox
Je me demande pourquoi les chinois n'ont pas encore mis en vente des VI avec cette version ?
Est elle stable ?
Merci d'avance
Shadows93 est déconnecté   Réponse avec citation
Vieux 01/11/2017, 16h50   #4
tomsy10
Avatar de tomsy10
tomsy10 is on a distinguished road
Par défaut diagbox 8.17
boujour je voudrais savoir si je peux installer sur mon diagbox 8.17/7.81 la mise a jour lexia pp 2000 v8.47 ou je doit installer autre chose avant et a part sauvegarder le appdiag.sys . je ne doit pas sauvegarder lexia pp 2000 au cas ou? mon diag et fontionnel sauf bien sur les langues comme tout le monde je crois merci d avance pour les reponces bonne journee a tous le forum
tomsy10 est déconnecté   Réponse avec citation
Vieux 01/11/2017, 19h40   #5
manudiag
Avatar de manudiag
manudiag is just really nicemanudiag is just really nicemanudiag is just really nicemanudiag is just really nicemanudiag is just really nice
Envoyé par tomsy10 Voir le message
salut Simple te donne le lien des amis du diag pour remettre en francais ton lexia et ton diagbox si besoin
je te joint le fichier exe de Maitresox pourla manip tu le lance et il va te changer la langue en francais tu n aura rien a l ecran qui t indique que c est fait c est normal merci a toi Maitresox pour cette exe
Type de fichier : rar Modif LEXIA Francais.rar (85,0 Ko, 47 affichages)
manudiag est déconnecté   Réponse avec citation
The Following User Says Thank You to manudiag For This Useful Post:
Vieux 01/11/2017, 19h50   #6
zenata
Avatar de zenata
Pouvoir de réputation: 175
bonsoir manudiag
tu as déjà essaye cet exécutable ???
Vieux 01/11/2017, 20h15   #7
manudiag
Avatar de manudiag
oui quand il l as sortie ça fonctionne nickel , mais on ne voit rien a l écran quand tu lance l exe , tu te rend compte que ça as fonctionner quand tu relance ton diagbox
zenata (01/11/2017)
Vieux 01/11/2017, 20h20   #8
zenata
Avatar de zenata
tu veux dire , quand tu redémarres le pc , le soft ?????
Vieux 02/11/2017, 06h43   #9
tomsy10
Avatar de tomsy10
Par défaut diagbox8.17
merci a manudiag pour la langue du lexia en francais fontionne
maintenant Est-ce que je peux faire cette mise a jour 8.47 de simple ou d abort autre chose avant celle si (pour la langue lexia fontionne en fr mais pour les autres langues dans diagbox sa continue de planter je crois normal toujour pas de correctif merci encore )diagbox
The Following User Says Thank You to tomsy10 For This Useful Post:
manudiag (04/11/2017)
Vieux 02/11/2017, 06h48   #10
guyguy307
Avatar de guyguy307
Pouvoir de réputation: 41
bonjour tout est bien expliquer par simple
"La mise à jour APP_Update_817-837.EXE doit être tentée si vous avez une installation de DiagBox v8.17 / v7.81 ou supérieure, ou si vous avez une implémentation "APP-835.7z" fonctionnelle.
La mise à jour APP_Update_835-838.EXE doit être tentée si vous avez mis à jour vers la version 8.37 ou une implémentation "APP-835.7z" opérationnelle. Mise à jour APP_Update_838-842.exe peut ensuite être installé.
Le langage Lexia est réglé sur l'anglais et le PP2000 sur le français, si vous souhaitez les changer, éditez le fichier DICO.TXT dans les dossiers EXE de LEXIA ou OUTILREP (PP2000) et remplacez "GB" par "FR" ou vice versa.
Vieux 02/11/2017, 06h57   #11
tomsy10
Avatar de tomsy10
Par défaut re
qu est ce que vous appeller "APP-835.7z" fonctionnelle.je suis en diagbox 8.17 :7.81 je ne fait pas la difference merci encore
Vieux 02/11/2017, 08h53   #12
Simple
Avatar de Simple
Thanks guyguy307 for help and concise explanation.
@tomsy10, when it comes to Lexia and PP2000; DiagBox 7.xx and 8.xx are NOT the same, because the engines are different!!!
If your DiagBox is 7.xx, you need to change the APP folder to be based on 8.xx, which will take you to 8.35, here it is:
http://www.tlemcen-electronic.com/fo...ad.php?t=60274
But if you are on 8.xx, you need to follow guyguy307 instructions or my posts.
Good luck. Simple
The Following 2 Users Say Thank You to Simple For This Useful Post:
adiago (02/11/2017), manudiag (04/11/2017)
Vieux 02/11/2017, 12h25   #13
zenata
Avatar de zenata
BONJOUR TOUS LE MONDE
JE FAIS UNE TRADUCTION DE Simple , parce qu'il y a beaucoup de gens
qui ce mélange les pinceaux
Par défaut Lexia & PP2000 mises à jour (DiagBox v8.47)
Le logiciel fourni et les procédures proposées sont destinés à un usage personnel, éducatif et expérimental pour installer les mises à jour relatives à DiagBox 8.xx. Je ne suis pas responsable de toute utilisation illégale ou inappropriée. Effectuez cette procédure à vos risques et périls.
Les liens sont fournis dans les pièces jointes pour 3 compilations "APP_Update_817-837.EXE", "APP_Update_835-838.EXE" "APP_Update_838-842.exe", "APP_Update_842-846.exe" et "APP_Update_846-847.rar". Ces exécutables sont destinés à mettre à jour les composants Lexia et PP2000 de DiagBox à partir des versions 8.17+ ou 8.35 respectivement, jusqu'à la version 8.42 et apporteront les correctifs ou le niveau de support Lexia v500.74 et PP2000 v600.80 les plus récents.
Procédure:
1- Assurez-vous d'avoir une copie de sauvegarde du fichier "C: \ AWRoot \ bin \ fi \ APPDIAG.SYS" avant de commencer.
2- Téléchargez et exécutez le fichier approprié pour votre propre configuration. Le processus va copier tous les fichiers nécessaires dans le dossier updt, il va alors automatiquement tuer tous les processus associés pour permettre l'écrasement sans conflits.
3- Exécutez DiagBox pour démarrer le processus de mise à jour et attendez que DiagBox soit opérationnel. Fermez DiagBox et redémarrez votre ordinateur pour vous assurer que tous les processus sont en cours d'exécution.
Terminé..! vous pouvez exécuter DiagBox comme d'habitude. Notez que la version de DiagBox ne sera pas modifiée par ces mises à jour.
S'amuser!
P.S. DiagBox fonctionne sous Firmware 4.3.4 depuis le 7.66 / 8.02.
Si vous souhaitez changer la langue Lexia et PP2000, éditez le fichier DICO.TXT dans les dossiers EXE de LEXIA ou OUTILREP (PP2000) et remplacez "GB" par "FR" ou vice versa. Pour un processus plus détaillé et d'autres langues, consultez ce lien:
http://www.lesamisdudiag.com/diagbox...-francais.html
Cordialement, simple.
Type de fichier: rar Kill_DiagBox_Tasks.rar (223 octets, 41 occurrges)
Type de fichier: txt Lexia-PP2000_update-817-847.txt (1,7 Ko, 85 occurrges)
Merci guyguy307 pour l'aide et l'explication concise.
@ Tomsy10, quand il s'agit de Lexia et PP2000; DiagBox 7.xx et 8.xx ne sont pas les mêmes, car les moteurs sont différents !!!
Si votre DiagBox est 7.xx, vous devez changer le dossier APP pour être basé sur 8.xx, ce qui vous portera à 8.35, le voici:
Mais si vous êtes sur 8.xx, vous devez suivre les instructions de guyguy307 ou mes messages.
Bonne chance. Simple
Simple (02/11/2017)
Vieux 04/11/2017, 08h48   #14
tomsy10
Avatar de tomsy10
Par défaut re diagbox
bonjour j ai quelque difficulter a comprendre diagbox 8.17:7.81 je peux donc effectuer la app 8.35 de simple avant fe faire les autres c est bien sa? ou je me trompe? MERCI de m eclairer encore un peu
Lexia & PP2000 updates (Up-to DiagBox v8.37) Simple LEXIA, PP2000, DiagBox 61 29/11/2018 20h09
Lexia & PP2000 (from DiagBox 8.35) Simple LEXIA, PP2000, DiagBox 63 25/11/2018 22h25
Diagbox pp2000 lexia YomGui PSA Group Peugeot, Citroën 35 16/06/2017 13h12
Lexia & PP2000 updates (DiagBox v8.35-8.38) Simple LEXIA, PP2000, DiagBox 7 03/05/2017 18h07
mises à jour Lexia & PP2000 (Up-to DiagBox v8.47) 3atman LEXIA, PP2000, DiagBox 1 14/02/2017 23h26
Fuseau horaire GMT +1. Il est actuellement 06h50.
