Vieux 13/11/2016, 11h34   #1
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut Lexia & PP2000 (from DiagBox 8.35)
I have attached the APP folder from DiagBox v8.35, it includes Lexia v500.74 and PP2000 v600.79. This arrangement should work with any DiagBox v7.xx and/or DiagBox 8.xx, I have tried it on my own car and it seems to be working fine.
The attachment within this post includes a link to the "APP" folder and a batch file to kill all DiagBox processes.
If you wish to try it (at your own risk and having taken all precautions!):
1- Use the attached “Kill_DiagBox_Tasks.bat” to stop all DiagBox’s processes.
2- Rename your current “C:\APP” folder to “C:\APP8”
3- Extract the downloaded APP-835.7z to “C:\” so that you have “C:\APP”
4- Restart your computer and run DiagBox as usual.
Have fun!
The language is set to English, if you wish to change it, edit the DICO.TXT file in the EXE folders of LEXIA or OUTILREP (PP2000) and replace "GB" with "FR".
If you wish to revert to your original setup.
- Kill all processes again using the wicked batch file
- Rename the C:\APP folder to anything or delete it
- Rename your C:\APP8 back to C:\APP
- Restart the computer and start DiagBox.
P.S. DiagBox has been running on Firmware 4.3.4 since 7.66/8.02.
Regards, Simple.
Type de fichier : zip APP-835+Kill_DiagBox_Tasks.zip (811 octets, 255 affichages)
Simple est déconnecté   Réponse avec citation
The Following 11 Users Say Thank You to Simple For This Useful Post:
ElTurco (09/12/2018), Evasion_Td12 (07/02/2019), jardini (04/10/2017), marianro2007 (24/11/2016), maskcoto (23/08/2017), maxer (30/09/2018), mik@ (16/05/2020), REDZONE31 (02/11/2017), sivestiano (31/12/2021), tatel (02/02/2018)
Vieux 22/11/2016, 19h03   #2
nikita
Avatar de nikita
nikita is a jewel in the roughnikita is a jewel in the roughnikita is a jewel in the roughnikita is a jewel in the rough
thanks bro
nikita est déconnecté   Réponse avec citation
Vieux 24/11/2016, 07h33   #3
nikita
Avatar de nikita
tester il me redemande une activation maintenant
Vieux 24/11/2016, 09h17   #4
Simple
Avatar de Simple
I have tried this on a number of machines without a problem. I hope you did not make changes in "AWRoot".
Restore your backup copy of "APPDIAG.SYS", if it still does not work, then restore the old APP folder and restore APPDIAG.SYS.
Please provide me with your setup details and what did you try, I will try to replicate what you have done to see what is the problem.
Vieux 24/11/2016, 09h33   #5
Simple
Avatar de Simple
By the way, make sure you are running DiagBox as Administrator.
Vieux 24/11/2016, 09h37   #6
DIAGAUTO33
Avatar de DIAGAUTO33
DIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant future
Merci pour ton partage Simple.
J'ai la version 8.18 de Maitresox, je peux installer la tienne sans probleme ?
Tu as testé télécodage avec ?
Merci pour ton aide l'ami.
DIAGAUTO33 est déconnecté   Réponse avec citation
Vieux 24/11/2016, 10h12   #7
Simple
Avatar de Simple
I have few test installations, but only one Citroen C8 car.. I did test update 8.35 on my car on Windows XP, 7 and 10.. and I have no problem..
I do not know if other cars like Peugeot 207 have problems or not, but other users can try.
Vieux 24/11/2016, 10h59   #8
DIAGAUTO33
Ok.
Je vais testé dès que je peux et je tiens au courant.
Merci encore.
Vieux 25/11/2016, 07h55   #9
DIAGAUTO33
Salut, j'ai testé sur C8 CAN ok.
Après la manip décrite par notre ami simple pour mettre lexia et pp2000 en FR, tout est ok.
Test télécodage sur abs ou bsi ok.
Par contre, j'aimerai savoir si cette mise à jour mets seulement pp2000 et lexia à jour ou ça mets également diagbox à jour ?
Avant, l'appli ne se connecté plus à internet et maintenant, diagbox cherche à se re connecter souvent. C'est pas trop grave mais c'est lassant. J'ai tenté avec le tlcd.fix de notre ami scary mais c'est pareil.
Je continu les test puis je vous tient informé.
Merci encore simple !
Vieux 25/11/2016, 08h41   #10
Simple
Avatar de Simple
Thank you DIAGAUTO33 for your effort and reporting back. The update only updates Lexia + PP2000 and all associated engines such as SIM, JAVA etc...
There may be one issue, which is relevant to language coding from 2 to 5 characters (FR or fr_FR), this may be a concern specific installations and only affects DiagBox not Lexia or PP2000.
I found the best way is to install DiagBox 8.xx then update APP to 8.35. This way every thing works well together and all your files are original and not manipulated or changed.
Vieux 25/11/2016, 09h50   #11
DIAGAUTO33
Ok l'ami mais impossible d'installer une version 8 il me semble ...
J'ai la version 7.82 de notre ami maitresox.
Si tu as la solution pour installer et activer la version 8.xx fonctionnelle, je veux bien tenter l'ami.
Merci encore.
Vieux 25/11/2016, 10h19   #12
Simple
Avatar de Simple
No it is not impossible to install DiagBox v8.xx, I already wrote how to do that, it is much tidier on other sites because I can edit and update my posts (which I cannot do on this site).
However, v7.82 should not have problems with this APP folder update..
Vieux 26/11/2016, 12h02   #13
maitresox
Avatar de maitresox
Pouvoir de réputation: 69
maitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond repute
La version 8.36 est sortie avec le nouveau 5008
maitresox est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to maitresox For This Useful Post:
DIAGAUTO33 (27/11/2016), SASIKO (25/11/2018)
Vieux 26/11/2016, 13h34   #14
Simple
Avatar de Simple
Thanks maitresox,
I am not sure I understand PSA's procedure with respect to updates and their availability.
I downloaded "inter8_36.rar" last week, the French site announced it on Tuesday while it is still not announced on the English site!!!
However, for the past 3 days, it is no longer available for download. I hope they did not discover a bug that necessitated pulling it back.
Type de fichier : jpg inter8_36.jpg (99,7 Ko, 87 affichages)
Vieux 28/11/2016, 10h31   #15
DIAGAUTO33
Merci pour les infos les gars.
Tu tournes avec la 8.36 maitresox ou c'est le pc de ton taf ?
Quoi faire avec le xs evolution sous diagbox , pp2000, lexia ishams2002 LEXIA, PP2000, DiagBox 7 14/11/2014 19h56
cherche logiciels diagbox, lexia et pp2000 originale beka1975 LEXIA, PP2000, DiagBox 1 20/11/2013 23h06
Peugeot/Citroen DIAGBOX PP2000 LEXIA bloker LEXIA, PP2000, DiagBox 7 30/10/2013 07h27
Fuseau horaire GMT +1. Il est actuellement 12h43.
