| Vente, Achat, Echange achat, vente ou echange de matériel, logiciel ...ect passez par ici. |
Guest
Messages: n/a
Salut les pro
Je met en vente Renault Ecu Tool Dispo seulement pour la France Prix 565 euro laivraison inclus pour la France Merci |
il est neuf ou d'occaz? |
Guest
Messages: n/a
est 'il toujours dispo? |
Guest
Messages: n/a
Merci infiniment samb4064 pour son aide pour le transfert a l'un de nous membre
Sinon y'en as encore disponible pour le même prix |
Salut l'ami Toujours disponible renault ecu tool?
Si je t'apporte mon aide n'oubli pas le bouton thanks |
Guest
Messages: n/a
Oui toujours disponible
Pouvoir de réputation: 18 ![]() ![]() ![]() ![]() |
Salut poste les fonction qu il peut faire stp
AUTOCOM CLIP DIGBOX KTAG FGTECH VAS XPROG ABRITUS VCDS |
Pouvoir de réputation: 62 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Renault CAN/K-line ToolRenault CAN/K-line ECU Tool OBDII tool with various Renault car electronic control unit internal memory modification functions, such as Read/Write EEPROM or FLASH, Clear Immobilizer Code, Read Immobilizer Status and Program Cards. There is no need to open control unit, de-solder memory IC or connect any wires directly to it. All functions works by OBDII connector, but any supported control unit can be connected "on the bench" using Connection Manual. Clear Immobilizer Code function is fully automated - just press button and control unit will be cleared. ECU is ready to accept new immobilizer code after previously programmed code is cleared - no future programming is required. Software V2.49 supports: EDC15C3 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code EDC15C13 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 31H - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 32[N] (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 34 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SIRIUS 35 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code EMS3132 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code EMS3134 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code SID301 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code, Clear IMPACT DETECTED, Read stored mileage SIM32 - Read/Write EEPROM, Read/Write FLASH from HD64F7055, Clear Immo Code SAFIR / SAFIR2 / SFR200 (35 / 55 pin connector) - Read TMS374 EEPROM, Clear Immo Code (car runs without immobilizer code) IAW 6R.20 - Read/Write TMS370 EEPROM IAW 6R.30 - Read TMS370 EEPROM, Clear Immo Code (car runs without immobilizer code) VALEO BII for ESPACE III - Read/Write (9)08AZ60 EEPROM, Read/Write mileage, Clear for Replacement, Read transponder data, Emergency Startup VALEO IMMOBILIZER for LAGUNA I Ph2 (1998-2000) - Read transponder data, Configure, Reset to VIRGIN INSTRUMENT CLUSTER for ESPACE III (1998-2002) - Reset odometer, Erase RF remote programming by instrument cluster connector SIEMENS IMMOBILIZER for ESPACE III Ph1 (1996-1998) - Read/Write 68HC05B16 EEPROM, read transponder data SIEMENS UCH for MEGANE/SCENIC ('98-'02) - Read/Write 705B32 EEPROM, Read/Write configuration, Learn Keys LAGUNA II, ESPACE IV, VELSATIS, LAGUNA II Ph2, ESPACE IV Ph2, VELSATIS Ph2 - KeyCard Programming, Change VIN MEGANE II, SCENIC II, MEGANE II Ph2, SCENIC II Ph2 - KeyCard Programming, Change VIN, Reset UCH to VIRGIN INSTRUMENT CLUSTER for SCENIC II ('04-'08) - Wake-Up by CAN-BUS for repair or to check mileage, Change language and units, Change VIN CLIO II Ph2, KANGOO, TRAFIC, MASTER, VIVARO, MOVANO (-'07) - Read/Write EEPROM 93C66, Key Learning, Change VIN KANGOO I, TRAFIC, MASTER, VIVARO, MOVANO ('07-) - Key Learning, Change VIN KANGOO II (2007-2012) - Key Programming, Change VIN MODUS / CLIO III ELECTRIC POWER ASSISTED STEERING (TRW DAE/PAS) - Clear Immo Code, Change VIN by OBDII MEGANE/SCENIC III ELECTRIC POWER ASSISTED STEERING (NSK DAE/PAS) - Clear Immo Code, Change VIN by OBDII LAGUNA III (2007-2015) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN LATITUDE (2010+) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN CLIO III / MODUS - Key Programming, Change VIN, Learn ECM in protected mode CLIO III - Card Programming, Change VIN, Reset UCH to VIRGIN MASTER III (2010-) - Key Programming, Change VIN WIND (2010-2013) - Key Programming, Change VIN, Learn ECM TWINGO II (2007-2013) - Key Programming, Change VIN, Learn ECM TWINGO (2001-2006), LOGAN (2004-2008), SANDERO I, THALIA, SYMBOL - Key Programming, Change VIN LOGAN, SANDERO, THALIA, SYMBOL (2008-2012), Duster (2010-2012) - Key Programming, Change VIN MEGANE III / SCENIC III (2009-2015) - Card Programming, Change VIN, Reset BCM to VIRGIN
Pas de participation = pas de réponse !!! EP+ |
| The Following User Says Thank You to r1lef For This Useful Post: | samigravano (07/06/2016) |
C'était dur, merci Google ....
| The Following User Says Thank You to r1lef For This Useful Post: | Mathieu35500 (31/05/2016) |
Guest
Messages: n/a
toujours disponible
![]() Date d'inscription: février 2013
slt! tjr dispo ton matos?
Pouvoir de réputation: 16 ![]() |
toujours dispo ?
#15 |
Pouvoir de réputation: 19 ![]() ![]() |
Slt, tjrs en vente? Tu l envoies vers la Belgique?
| Renault Ecutool (Renault tool) | tizi94 | Outils de diagnostique | 16 | 29/04/2016 16h46 |
| Renault ecu tool | Maybach | Outil de programmation | 7 | 02/04/2016 22h56 |
| Renault ECU TOOL | tintin421 | Vente, Achat, Echange | 6 | 09/03/2016 16h28 |
| renault ecu tool | beonce | Vente, Achat, Echange | 10 | 25/12/2015 10h14 |
| Renault decoding tool | Formator | Immobilizer dumps/solutions | 2 | 18/10/2010 19h11 |
