Vieux 30/01/2016, 19h38   #1
tintin421
Avatar de tintin421
tintin421 has a spectacular aura abouttintin421 has a spectacular aura abouttintin421 has a spectacular aura about
Par défaut Renault ECU TOOL
Bonsoir à tous
je propose à la vente le renault ecu tool original,avec mise à jour gratuite.
produit neuf vendu 600 €.contacte en MP.http://www.tlemcen-electronic.com/fo...smilies/50.gif
voici la liste des différentes applications :
EDC15C3 (both CAN-BUS and WIRE immo systems).
Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EDC15C13 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 31H - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 32[N] (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 34 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 35 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3132 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3134 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SID301 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code, Clear IMPACT DETECTED, Read stored mileage
SIM32 - Read/Write EEPROM, Read/Write FLASH from HD64F7055, Clear Immo Code
SAFIR / SAFIR2 / SFR200 (35 / 55 pin connector) - Read TMS374 EEPROM, Clear Immo Code (car runs without immobilizer code)
IAW 6R.20 - Read/Write TMS370 EEPROM
IAW 6R.30 - Read TMS370 EEPROM, Clear Immo Code (car runs without immobilizer code)
VALEO BII for ESPACE III - Read/Write (9)08AZ60 EEPROM, Read/Write mileage, Clear for Replacement, Read transponder data, Emergency Startup
VALEO IMMOBILIZER for LAGUNA I Ph2 (1998-2000) - Read transponder data, Configure, Reset to VIRGIN
INSTRUMENT CLUSTER for ESPACE III (1998-2002) - Reset odometer, Erase RF remote programming by instrument cluster connector
SIEMENS IMMOBILIZER for ESPACE III Ph1 (1996-1998) - Read/Write 68HC05B16 EEPROM, read transponder data
SIEMENS UCH for MEGANE/SCENIC ('98-'02) - Read/Write 705B32 EEPROM, Read/Write configuration, Learn Keys
LAGUNA II, ESPACE IV, VELSATIS, LAGUNA II Ph2, ESPACE IV Ph2, VELSATIS Ph2 - KeyCard Programming, Change VIN
MEGANE II, SCENIC II, MEGANE II Ph2, SCENIC II Ph2 - KeyCard Programming, Change VIN, Reset UCH to VIRGIN
INSTRUMENT CLUSTER for SCENIC II ('04-'08) - Wake-Up by CAN-BUS for repair or to check mileage, Change language and units, Change VIN
CLIO II Ph2, KANGOO, TRAFIC, MASTER, VIVARO, MOVANO (-'07) - Read/Write EEPROM 93C66, Key Learning, Change VIN
KANGOO I, TRAFIC, MASTER, VIVARO, MOVANO ('07-) - Key Learning, Change VIN
KANGOO II (2007-2012) - Key Programming, Change VIN
MODUS / CLIO III ELECTRIC POWER ASSISTED STEERING (TRW DAE/PAS) - Clear Immo Code, Change VIN by OBDII
MEGANE/SCENIC III ELECTRIC POWER ASSISTED STEERING (NSK DAE/PAS) - Clear Immo Code, Change VIN by OBDII
LAGUNA III (2007-2015) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
LATITUDE (2010+) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
CLIO III / MODUS - Key Programming, Change VIN, Learn ECM in protected mode
CLIO III - Card Programming, Change VIN, Reset UCH to VIRGIN
MASTER III (2010-) - Key Programming, Change VIN
TWINGO (2007-2013) - Key Programming, Change VIN
TWINGO (2001-2006), LOGAN (2004-2008), SANDERO I, THALIA, SYMBOL - Key Programming, Change VIN
LOGAN, SANDERO, THALIA, SYMBOL (2008-2012), Duster (2010-2012) - Key Programming, Change VIN (NEW!)
MEGANE III / SCENIC III (2009-2015) - Card Programming, Change VIN, Reset BCM to VIRGIN.
tintin421 est déconnecté   Réponse avec citation
Vieux 31/01/2016, 00h39   #2
mecanodiag93
Avatar de mecanodiag93
mecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant future
très bon outille je le recommande
pour renault c'est le top
ne fais pas à autrui ce que tu n'aimerais pas qu'on te fasse !!
mecanodiag93 est déconnecté   Réponse avec citation
Vieux 31/01/2016, 12h25   #3
bouzi002
Guest
Avatar de bouzi002
Messages: n/a
En cherchant sur internet j'ai trouvé que cet outil il est en deux version, un gris et un autre bleu, c'est le quel le tiens?Tu peux me laisser le prix en MP stp?
Vieux 31/01/2016, 12h31   #4
S-keys
Avatar de S-keys
Pouvoir de réputation: 141
Envoyé par bouzi002 Voir le message
la bleu est boite origine
gris boite de MBE
interieure 100% identique
Vieux 31/01/2016, 12h39   #5
bouzi002
Guest
Avatar de bouzi002
Messages: n/a
Merci selim95 pour l'info
Vieux 31/01/2016, 18h41   #6
S-keys
Avatar de S-keys
allé, je vais dire que je vend le mien a 100euros !!( je decone )
pourquoi pollué sujet de notre ami
seadoo831 a toi de jouer !!
Vieux 09/03/2016, 16h28   #7
tintin421
Avatar de tintin421
Envoyé par tintin421 Voir le message
Bonsoir à tous
bonjour à tous
il me reste un renault écu tool ORIGINAL à vendresuite à désistement
le prix est toujours de 600 € TTC et frais de port inclus (France metropolitaine).
Avis au personnes intéressées...premier arrivé premier servi!!!!
renault ecu tool beonce Vente, Achat, Echange 10 25/12/2015 10h14
renault tool probleme aimanj750 Immobilizer dumps/solutions 0 09/09/2015 14h17
renault tool renseignement nico31520 Renault, Dacia, Nissan 4 23/04/2015 14h02
Renault can/k-line tool opc Vente, Achat, Echange 9 26/07/2014 22h18
Fuseau horaire GMT +1. Il est actuellement 04h32.
