Vieux 01/04/2015, 09h15   #1
stephane
Avatar de stephane
Pouvoir de réputation: 121
Par défaut code nav clio4
Salutation
Quelqu'un pourrait m indiqué comment récupéré le code qui c est effacé suite changement de batterie je n ais pas la carte pass
Et t il possible de l extraire via clip comme un isk par exemple ?
merci d avance pour vos réponses
The Following User Says Thank You to stephane For This Useful Post:
riad3131 (09/04/2015)
Vieux 01/04/2015, 09h52   #2
yvespapou
Avatar de yvespapou
yvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond repute
salut Stefano sort ton poste tu trouve l étiquette avec les numéros tu décode comme les ancien poste renault
yvespapou est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to yvespapou For This Useful Post:
nimbus (03/04/2015), stephane (01/04/2015)
Vieux 01/04/2015, 09h54   #3
yvespapou
Avatar de yvespapou
ou envoi moi l étiquette bye
The Following User Says Thank You to yvespapou For This Useful Post:
Vieux 01/04/2015, 10h15   #4
stephane
Avatar de stephane
Cool je pensait qu'il avais changé leurs systèmes merci yves
Vieux 01/04/2015, 10h27   #5
foulques
Avatar de foulques
foulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud of
tu trouveras le precode via clip sans demontage.
foulques est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to foulques For This Useful Post:
BAZBOZ (05/04/2015), nimbus (03/04/2015), stephane (01/04/2015)
Vieux 01/04/2015, 10h42   #6
stephane
Avatar de stephane
Ta la manip foulques ?
Parce que las à démonté c'est misère faut démonté la moitié du tableau de bord
Dernière modification par stephane ; 01/04/2015 à 10h55.
Vieux 01/04/2015, 11h40   #7
foulques
Avatar de foulques
tu vas en radio, identification calculateur, ID007 cle apprentissage radio et tu auras ton precode ATTENTION ce n'est pas le code.
BAZBOZ (05/04/2015), Scanworld2020 (06/04/2015), stephane (01/04/2015)
Vieux 02/04/2015, 13h52   #8
stephane
Avatar de stephane
Petit retour merci foulques effectivement
Radio> info calculateur> clef precode
nimbus (03/04/2015)
Vieux 04/04/2015, 11h14   #9
BAZBOZ
Avatar de BAZBOZ
BAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of light
Et quand ont aura le précode, quel soft utilisé pour avoir le code?
BAZBOZ est déconnecté   Réponse avec citation
Vieux 04/04/2015, 11h23   #10
stephane
Avatar de stephane
Renault precode calculator a l ancienne ......
BAZBOZ (05/04/2015)
Vieux 04/04/2015, 11h25   #11
stephane
Avatar de stephane
Je peut te le posté dans l après midi si tu veut
BAZBOZ (05/04/2015)
Vieux 05/04/2015, 09h56   #12
BAZBOZ
Avatar de BAZBOZ
BONJOUR
Oui bien sur si c'est possible.
Cordialement
Vieux 05/04/2015, 15h56   #13
stephane
Avatar de stephane
Voilà msieux pas d install a faire
Tu lance le le prog tu tape ton precode extrait via clip> entrer et il te donne ton code a 4 chiffres
Type de fichier : rar RENAULT PRE-CODE CALCULATOR.rar (208,4 Ko, 43 affichages)
Vieux 05/04/2015, 15h58   #14
stephane
Avatar de stephane
Par défaut pass renault code calculator
Pass en mp
Dernière modification par stephane ; 05/04/2015 à 16h00.
krimmo (05/04/2015)
Vieux 05/04/2015, 16h08   #15
krimmo
Avatar de krimmo
krimmo is an unknown quantity at this point
svp mp et merci.
krimmo est déconnecté   Réponse avec citation
airbag clio4 avec carprog yvespapou Airbag 3 27/09/2015 16h45
Médinav clio4 Omareves Autoradio et Navigateur GPS 7 19/02/2015 12h49
Clio4 Qui peut nous informer ? Amine-TE Automobile en général 6 12/12/2012 09h42
Fuseau horaire GMT +1. Il est actuellement 07h12.
