Précédent   Tlemcen Car electronics > Categorie principale > Café du forum > Section for english users
Section for english users English talking about cars, problems and solutions ...
Vieux 23/12/2014, 18h37   #1
sauzee1
Avatar de sauzee1
sauzee1 is an unknown quantity at this point
Par défaut Kangoo 1.5dci Egr
Hi i wonder if anyone has had the same problem with an egr fault i have error codes
DF027 - EGR solenoid valve circuit, at minimum limit
- Permanent
DF084 - EGR valve position sensor circuit, above maximum limit
- Permanent
I have changed the egr for a working one and still the same codes The problem is the van has no power 25mph up hill and 40mph down hill there is no eml on the dash .I have plugged it into Autocom and when i activated the egr when it is removed the solenoid operates up and down so it shouldn't be wiring or egr can it be a air leak or something else or am i better buying a blanking plate for egr
Thanks for any info
sauzee1 est déconnecté   Réponse avec citation
Vieux 23/12/2014, 23h03   #2
nowen
Avatar de nowen
Pouvoir de réputation: 66
Hi, having replaced egr it is necessary to make an adaptive deletion egr. you made it?
The Following User Says Thank You to nowen For This Useful Post:
sauzee1 (24/12/2014)
Vieux 24/12/2014, 01h01   #3
sauzee1
Avatar de sauzee1
Envoyé par nowen Voir le message
Hi why would i have to make an adaptive deletion of the egr if it was replaced i thought that was only if i blanked it off
What code reader or software would i need if i was to have the egr deleted
can you tell me what is the definition of the codes present (ie) egr not opening,closing or wiring fault
I did change the egr on this van before over a year ago with a used one and never had any fault codes
Thanks for your help
emplacement calculateur air bag kangoo tolé 2012 1.5dci bmfrep Airbag 2 20/03/2019 11h18
rech info sur reparation UCH kangoo 1,5DCI tony2552 Réparation & Programmation 8 10/10/2014 22h25
Kangoo 1,5dci fume noir sam93 Renault, Dacia, Nissan 10 20/11/2012 19h53
les moteurs K9K 1.5DCI auquartdetour Mécanique générale 6 01/06/2012 15h41
Clio 1,5dci lari95400 Chiptuning 1 10/08/2010 23h04
Fuseau horaire GMT +1. Il est actuellement 07h44.
