Discussion fermée
Vieux 12/07/2014, 16h32   #1
television
Avatar de television
television has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond repute
Par défaut fiat doblo 1.3
j ai mon fiat boblo 1.3 diesel
filtre a particule surcharger ,mode dégrader.
mais le véhicule quand il démarre,se coupe quelques seconde après ,cela peut t il venir du filtre colmater .
pas d autres defauts a la valise a part le filtre a particule ..
merci de m aider
cordialement
amicalement
television est déconnecté
Vieux 12/07/2014, 16h45   #2
redpoker
Avatar de redpoker
redpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant future
controle ton taux d encrassemant du FAP au diag et tu aura ta reponse je pense
redpoker est déconnecté
The Following 2 Users Say Thank You to redpoker For This Useful Post:
diagnosis29 (12/07/2014), television (12/07/2014)
Vieux 12/07/2014, 16h50   #3
diagnosis29
Avatar de diagnosis29
Pouvoir de réputation: 184
Essaye aussi de mesurer la valeur de contre pression FAP avant que sa cale si possible !
___________________________
www.123diagauto.com
diagnosis29 est déconnecté
Vieux 12/07/2014, 17h45   #4
fresk
Avatar de fresk
fresk is on a distinguished road
ouvre l'échappement avant le fap et si ça cale pas il est vraiment bien bouché
fresk est déconnecté
The Following User Says Thank You to fresk For This Useful Post:
Vieux 12/07/2014, 19h22   #5
television
oui ok merci de vos reponse,mais le moteur démarre et s arrêt au bout de quelques secondes ,osque le fap boucher peut provoquer cette panne
cordialement
Vieux 12/07/2014, 19h52   #6
redpoker
Avatar de redpoker
completement boucher oui comme un cata,
controle au diag,tu va voir ton taux d encrassement et post la valeur,c la premiere chose a faire et ca t prend 5 minutes.
MecaTech (13/07/2014), television (12/07/2014)
Vieux 12/07/2014, 20h28   #7
television
ok merci ,mais je vais le defaper ,je vous tiens au courant ,après le defapage ,du résulta ma carto est prête .
cordialement
Vieux 13/07/2014, 14h07   #8
television
après réinjection de la nouvelle carto mémé problème .le vehiculez depasse pas les 2000 t/mn .par controle ne cale plus .
la mécanique n est pas encore defaper .
a votre avis !!!!!!!
Vieux 13/07/2014, 17h39   #9
r1lef
Avatar de r1lef
Pouvoir de réputation: 62
comme cela ta déjà été dit , depose ton FAP maintenant que ta fait l'electronique et tu verras bien , mais tu vas un peu vite en besogne , une interprétaion des valeurs réelles et une vraie recherche de panne avant de supprimer un FAP m'aurait paru mieux , mais bon chacun fait comme il l'entend ...
r1lef est déconnecté
The Following 4 Users Say Thank You to r1lef For This Useful Post:
diagnosis29 (13/07/2014), MecaTech (13/07/2014), redpoker (13/07/2014), television (13/07/2014)
Vieux 13/07/2014, 17h45   #10
diagnosis29
Envoyé par television Voir le message
Ton problème est probablement mécanique (FAP) , ce n'est donc pas en supprimant la gestion électronique de celui-ci que les gaz passeront mieux et te feront dépasser les 2000 t/m
Post les valeurs qu'on ta demandé dans un premier temps.
www.123diagauto.com
Dernière modification par diagnosis29 ; 13/07/2014 à 17h47.
The Following 4 Users Say Thank You to diagnosis29 For This Useful Post:
MecaTech (13/07/2014), r1lef (13/07/2014), redpoker (13/07/2014), television (13/07/2014)
Vieux 13/07/2014, 18h34   #11
television
hello bonne nouvelle
âpres defapage mécanique tous et ok ,j ai retrouver toute la puisance .
le filtre a particule et cata ,qui étais bien bouché.
plus defaut au tableau de bord.
le véhicule démarre très bien
merci a tous .
The Following User Says Thank You to television For This Useful Post:
Vieux 13/07/2014, 19h25   #12
television
Par défaut panne resolu fiat boblo 1.3
merci a tous
panne résolu
cordialement
The Following 2 Users Say Thank You to television For This Useful Post:
Discussion fermée
fiat doblo ecu mjd 6f3.d4 immo off trycktill Immobilizer dumps/solutions 1 27/06/2016 16h46
code fiat doblo kams20040 Autoradio et Navigateur GPS 11 12/07/2013 23h02
fiat doblo 2012 FPS ON zidane autodiag Fiat, Alfaromeo, Lancia, Ferrari 5 09/05/2013 13h55
fiat doblo 1.3 cdti formator2 Fiat, Alfaromeo, Lancia, Ferrari 2 20/01/2013 20h07
kit fiat doblo ALI CHABI Vente, Achat, Echange 0 10/06/2012 13h19
Fuseau horaire GMT +1. Il est actuellement 11h31.
