Vieux 17/03/2014, 22h04   #1
diagprog
Avatar de diagprog
diagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond repute
Par défaut immo 96080 DCU3R KANGOO
salut tt
est ce que quelq'un peut me faire un immoff dump kangoo D65 CALUCLATEUR lucas ddc3R
merci d'avance
Type de fichier : rar 95080 or.rar (500 octets, 17 affichages)
diagprog est déconnecté   Réponse avec citation
Vieux 17/03/2014, 22h27   #2
nowen
Avatar de nowen
Pouvoir de réputation: 66
Salut diagprog, test celui là et tiens nous au courant
pass et + dans ta boite
Type de fichier : rar 95080 DCU3R D65 KANGOO total.rar (392 octets, 8 affichages)
The Following User Says Thank You to nowen For This Useful Post:
diagprog (21/03/2014)
Vieux 17/03/2014, 22h27   #3
danyparis
Avatar de danyparis
danyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud of
Voila test ça mon ami
Type de fichier : rar 95080 DCU3R D65 KANGOO mod.rar (390 octets, 21 affichages)
danyparis est déconnecté   Réponse avec citation
The Following User Says Thank You to danyparis For This Useful Post:
Vieux 18/03/2014, 18h12   #4
BAZBOZ
Avatar de BAZBOZ
BAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of light
Envoyé par danyparis Voir le message
avec quel soft?
BAZBOZ est déconnecté   Réponse avec citation
Vieux 18/03/2014, 18h14   #5
danyparis
Avatar de danyparis
Envoyé par BAZBOZ Voir le message
avec quel soft?
Immokiller pourquoi cette question ?
Vieux 18/03/2014, 18h21   #6
BAZBOZ
Avatar de BAZBOZ
Car j'ai fait un imooff avec immokiller d'une kongoo 2008 mais la dae hors service.
Vieux 20/03/2014, 23h05   #7
diagprog
Avatar de diagprog
désolé pour le retard
les deux fichier du Monsier nowen, et danyparis sont identique
Alors
1 j'ai injecter le fichier mais pas avec écriture "write protect activé " avec xprogm
2 elimination pin 20
3 montage dans la voiture
3 contact mis " temoins ok inculs le témoin préchaffage normal
la voiture a demaré seulement la premiere fois mais aprés y'a plus de demarage
Alors j'ai monter le calculateur mais sans eprom la voiture a demare mais il n'a plus de préchaffge.
c'est quelq'un a une idée pour ce probleme et merci d'avance
Vieux 21/03/2014, 08h43   #8
ajmi_gsm
Avatar de ajmi_gsm
ajmi_gsm will become famous soon enoughajmi_gsm will become famous soon enough
Envoyé par diagprog Voir le message
Alors
il te faut un emulateur
ajmi_gsm est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to ajmi_gsm For This Useful Post:
diagprog (21/03/2014), reda75 (21/03/2014)
Vieux 21/03/2014, 20h42   #9
diagprog
Avatar de diagprog
Merci Les amis pour ce soutien
Alors je pense que la solution il faut mettre un Emulateur
Ou bien il y a une autre solution?
Vieux 21/03/2014, 20h58   #10
Ben29200
Avatar de Ben29200
Ben29200 is just really niceBen29200 is just really niceBen29200 is just really niceBen29200 is just really nice
Salut.
Effectivement avec un émulateur + dump vierge ça fonctionne a 100%.
Ton off est bon si ça démarre au premier essais, par contre si tu écrit ce dump et applique le Wprotect ça ne peut que fonctionner.
Ton calculateur à un processeur infineon et le dump est modifier apres le premier demarrage, compare les fichiers tu verra.
Bon courage
Ben29200 est déconnecté   Réponse avec citation
Vieux 24/03/2014, 20h44   #11
diagprog
Avatar de diagprog
Merci les amis pour votre réponse
en ce que concerne la question mafiak1fry061 il a raison cette voture a un réseau can multiplixé
alors je pense que la soulution et de faire un emulateur
on attendant que je commande des emulateur spécialement pour ce type de calculateur.
Merci bien les amis pour votre soutien
la discussion peut etre ferme
Immo off dcu3r MEDELAS Immobilizer dumps/solutions 26 31/03/2014 19h32
DCU3R Kangoo antidem vérrouillé Mica64 Immobilizer dumps/solutions 24 17/07/2013 19h04
Immo vierge DCU3R kangoo EPIC Formator Immobilizer dumps/solutions 43 01/06/2012 21h03
DCU3R EPIC Kangoo Formator Renault, Dacia, Nissan 16 07/08/2010 14h54
Fuseau horaire GMT +1. Il est actuellement 06h47.
