je vous propose tecdoc v 1 - 2014 avec crack
fichier torrent tester, marche 100% pass par MP, n'oubli pas le bouton magic (Thanks) ^_^ |
| The Following 112 Users Say Thank You to Scanworld2020 For This Useful Post: | سعدان (28/03/2014), abdou07 (13/03/2014), abdouu (15/08/2014), abidou0110 (21/04/2014), Adrien13 (06/02/2014), aladinno (30/12/2014), allal123 (27/04/2019), ammar21 (21/01/2014), andrew (09/04/2015), autodiag34 (15/03/2014), autodiagauto (05/01/2014), AZIRA (03/02/2014), BELL (20/02/2014), BERU89 (09/02/2014), BOD69 (22/02/2014), Breizhelec (05/01/2014), bugsternc (17/05/2014), Carsshop (08/01/2014), CED300482 (28/01/2014), chacalx (11/03/2014), chocotom (12/02/2014), chouaib (25/01/2015), cletek (05/01/2014), davidf52 (24/01/2014), dell 66 (13/01/2014), depress (31/03/2014), Diag2014 (29/06/2014), digimotion (11/03/2014), djallalagg (27/05/2014), DJBoost69 (21/01/2014), dnano12 (10/03/2014), drone (07/03/2014), EDD89 (23/04/2014), electro_bordeaux1 (24/03/2014), franck22 (09/03/2014), fred83 (31/01/2014), fredflor95 (05/04/2014), Funnyboy (19/02/2014), ghosts.sylar (15/11/2014), Heineken (03/04/2014), Helpful (24/01/2014), hunter27 (11/03/2014), hydrofrein (07/04/2014), islamnet (16/11/2014), jéjé (01/02/2014), jerome83000 (09/02/2015), juju13fr (15/01/2014), justinyours (20/02/2014), kamal59500 (09/02/2014), karera 1 (29/01/2014), Karim47 (09/07/2014), karimdif18 (15/03/2014), KARIMIVECO (26/02/2014), kevin22 (10/01/2014), kiki auto (02/06/2014), kilog (23/11/2014), kokkinelle32 (05/03/2014), lazhar101 (02/12/2014), mamadoukaita (10/05/2014), MAXYBOOM (01/02/2014), MCNexo94 (09/01/2014), MecaTech (05/01/2014), medimagh (23/01/2015), mohamed1 (09/10/2014), mohhizbar (18/07/2014), momoh-93 (05/01/2014), montebellonet (06/06/2015), Mourad95 (20/01/2014), myabdel (11/11/2014), NAJIBBB (20/02/2014), natouss225 (13/07/2014), Nico66 (05/04/2014), nimbus (05/01/2014), oliverfox (06/01/2014), omar-dia (21/03/2014), omarha (02/03/2014), omarzoro (07/01/2014), pakorabais (10/02/2014), pas95 (22/02/2014), pepite (16/01/2014), PILOTE (04/06/2014), Pilouf (07/05/2014), piloupou (11/03/2014), polomanpolo (02/03/2014), portugallands (27/04/2014), RAHMANIA AMMAR (26/03/2014), RTEDAMAC31 (09/06/2019), SAFARI (14/02/2014), salimalouane (17/01/2014), san-style95 (12/01/2014), sawadogo2 (12/01/2014), selouan (24/01/2014), sfbi (22/02/2014), sfiorentina (02/04/2014), sofiane68e (18/09/2014), soumoud (29/04/2014), sylkas (25/02/2014), TAGRART (06/01/2014), test-telcem (11/03/2014), tevalio (17/01/2014), TlemcenDZ (13/02/2015), tonio5766 (31/03/2014), vortex (12/01/2014), walid_h_2000 (05/04/2014), War (25/11/2014), YoKo57 (22/03/2014), youcef_trik (11/03/2014), zerocool (21/02/2014), zoulien (29/03/2014) |
Pouvoir de réputation: 183 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Hello,
Si vous avez l'erreur du DVD4 : Pour faire au plus simple, il vous faut UltraIso ou un logiciel similaire capable de modifier un ISO (Daemon Tool Lite ne le permet pas mais la version Pro Oui) Une fois que vous avez votre logiciel, il vous faut monter/ouvrir le DVD4. ceci fait, il vous faut créer à la racine du DVD4 le dossier nommé DB . Vous devez maintenant sélectionner l'intégralité des fichiers du DVD4 et les déplacer dans le Dossier DB que nous venons de créer. Une fois que le déplacement est terminé, il vous suffit de sauvegarder la modification de l'ISO dans UltraIso. A partir de cette instant vous pouvez finaliser l'installation du DVD4 ;) ++ Ced Dernière modification par cedrsan ; 17/01/2014 à 14h17. |
| The Following 11 Users Say Thank You to cedrsan For This Useful Post: | ghosts.sylar (15/11/2014), jéjé (01/02/2014), KARIMIVECO (26/02/2014), MecaTech (11/03/2014), myabdel (11/11/2014), nimbus (23/02/2014), pepite (18/01/2014), Scanworld2020 (22/01/2014), TAGRART (09/03/2014), tonio5766 (23/01/2014), youcef_trik (11/03/2014) |
voila une petite aide pour modifier le DVD4
- lancé ultraiso - allé dans "fichier", "ouvrir" eet vous choisissez le "dvd4" de tecdoc -vous faite un clic droit avec la sourie dans la partie en haut à droite où se trouve les fichiers du dvd et vous créé un nouveau dossier que vous nommez "DB" - ensuite vous déplacé tous les fichiers dans le dossier "DB" - puis vous cliquet sur "enregistré sous", vous renommez le nom du fichier "DVD4" le fichier et le logiciel va créé un nouveau fichier iso du DVD4 et vous l'utiliserais pour installé tecdoc. |
| The Following 2 Users Say Thank You to juju13fr For This Useful Post: | KARIMIVECO (26/02/2014), MecaTech (11/03/2014) |
Hello
Quelqu'un aurait un tuto en image pour faire la modification du dvd4, j'ai téléchargé ultraiso mais là je suis complètement largué. Existe-t-il aussi un tuto pour l'installation? D'avance un grand merci !! Antoine |
| The Following User Says Thank You to tonio5766 For This Useful Post: | KARIMIVECO (26/02/2014) |
C'est une bonne idée un tuto en images pour nous les débutants. |
Dernière modification par cedrsan ; 24/01/2014 à 22h56. |
| The Following 15 Users Say Thank You to cedrsan For This Useful Post: | Amine-TE (25/01/2014), bmpower30 (28/06/2021), goti2014 (25/01/2014), jéjé (01/02/2014), jphp (24/01/2014), KARIMIVECO (26/02/2014), kevin22 (09/03/2014), lokher (24/07/2014), MecaTech (24/01/2014), nimbus (23/02/2014), Scanworld2020 (26/01/2014), skymoon (30/01/2014), TAGRART (09/03/2014), tonio5766 (27/01/2014), youcef_trik (11/03/2014) |
Merçi pour ton travail,c'est une réaction rapide qui mérite d'etre soulignée,bon week-end à toi.
| The Following User Says Thank You to goti2014 For This Useful Post: | cedrsan (05/03/2014) |
je possède tectoc 2007 je voudrais bien télécharger tecdoc 2014 pour être a jour pouvez vous m envoyer les codes accès et m expliquer comment le telecharger et un grand merci !! |
Salut les gars comment l'activer le crack ne marche pas
Pouvoir de réputation: 17 ![]() ![]() ![]() ![]() |
salut cedrsan,
a propos de tecdoc 2014 ! comment faire pour l'installation ? je me heurte à un souci, lorsque je l'installe sur ordinateur individuel, il me demande de localiser le serveur DB TECDOC CD1 2014 ! (le serveur TECDOC CD1 2014 indiqué n'a pas pu être trouvé ! pardon ! petite rectification j'ai refais et choisi, l'installation complète et il n'arrive pas a trouver le dvd2 ! comment dois je faire pour qu'il trouve le dvd en question ? merci Dernière modification par cedrsan ; 09/03/2014 à 19h57. |
salut branci2008,
aurais tu la procédure d'installation de tecdoc ? il me demande d’insérer le cd/dvd n°2. merci par avance |
| The Following User Says Thank You to kevin22 For This Useful Post: | baker (03/05/2014) |
pourquoi tu montes pas le DVD 2 ?? |
#15 |
bonsoir,
quelqu'un pourrait-il m'aider à installer tecdoc 2014 ou s'il vous plait me fournir un tuto d'installation le programme d'installation affiche : rom21.zip ne contient pas la RFILE017.000 Veuillez insérer le cd/dvd, n° :[2] toute aide sera le bien venue ! merci |
| Tecdoc 1. 2013 torrent | Scanworld2020 | Automobile en général | 8 | 21/11/2013 21h46 |
| TecDoc 1.2013 + Crack sur Torrent | TAGRART | Logiciel & autres documentations général | 5 | 23/05/2013 14h50 |
| TecDoc 4.2012 Torrent | TAGRART | Logiciel & autres documentations général | 10 | 07/04/2013 15h29 |
