Pouvoir de réputation: 29 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() This is full version, Just run setup.exe and that's all The TecDoc Catalog (4Q/2012) is a flexible information systems, which allows you several personal settings to ease your daily work. TecDoc supplies the free vehicle spare parts market with current and comprehensive data for identifying and ordering parts – for both, PC as well as CV – directly from the databases of the cooperating automotive aftermarket manufacturers in a standardised catalogue form. You are only a few clicks away from the right part! Accurate identification of the right spare part! Quick customer service thanks to reliable part identification! TecDoc Catalog is an electronic parts catalogues from standardised data records original data of parts manufacturers on DVD * more than 2,892,000 articles * over 1,500,000 illustrations * more than 45,000 PC types * 36,000 real existing CV types * with technical additional information * updated every 3 months * multilanguage: 23 languages The Information System TecDoc is the information source for the vehicle repair market with the original data of the parts manufacturers. Founded in 1994 by companies of the automotive aftermarket industry and the German Association for Spare parts (GVA), TecDoc Informations System GmbH has established itself as the leading supplier of electronic spare parts information on the European market. Data search can be filtered by the following criteria (from the TecDoc manual): 1. General: - Engine Code: the engine code - Engine Type: then engine type TecDoc supplies the free vehicle spare parts market with current and comprehensive data for identifying and ordering parts – for both, PC as well as CV – directly from the databases of the cooperating automotive aftermarket manufacturers in a standardised catalogue form. 2. by Model Year (from/to): - the engine was/is constructed during this period - Engine Number: the engine number as defined by TecDoc 3. by Technical Data: - Output in kW: engine output in kW - Output in HP: engine output in HP - Capacity (technical): engine capacity in technical terms - Cylinder: number of cylinders - Valves: number of valves - Torque in Nm: the maximum torque - Compression: the engine compression - Bore: engine cylinder bore - Stroke: piston stroke of the engine - Main Bearings: the number of crankshaft main bearings - Engine Block Design: the engine block design, i.e. straight or V - Fuel Type: the required fuel type - Charging: the type of charging, i.e. turbo- or supercharger - Cylinder Head Design: the cylinder head design, i.e. OHC or OHV - Engine Control: the type of engine control, i.e. timing belt or chain - Valve Control: the type of valve control - Cooling Type: the type of engine cooling, i.e. water or air. Liens torrent par MP |
| The Following 12 Users Say Thank You to TAGRART For This Useful Post: | Albi (07/04/2013), arnaud4211 (27/01/2013), autodiagauto (27/12/2012), Breizhelec (27/12/2012), mesrine_29 (16/01/2013), mounirflash (25/12/2012), natouss225 (27/12/2012), neocol (13/03/2013), newfree (27/12/2012), nyonsais (25/01/2013), prodiag (25/12/2012), rabahclim (31/12/2012) |
Pouvoir de réputation: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Bonne fête
français ou pas merci |
| The Following 2 Users Say Thank You to autodiagauto For This Useful Post: | natouss225 (27/12/2012), nyonsais (25/01/2013) |
Pouvoir de réputation: 17 ![]() ![]() ![]() |
je veux le lien svp ..
Never too old to learn ? There is always a way even if there is non.. do not forget THANKS button. |
Merci.
je veux le lien SVP |
![]() Date d'inscription: décembre 2012
[QUOTE=autodiagauto;93034]Bonne fête
français ou pas merci[/QUOTE C'est indiqué dans la description du logiciel du post MULTILANGUES. Bonne année. |
Merci.
Pouvoir de réputation: 22 ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
merci si tu peux faire suivre le lien.
merci si tu peux me passer le lien
bonjour,
j'ai installé TecDoc 4-2012 au lancement il me dit : application expired ( # 8500) que faire? |
Personnellement je ne l'ai pas essayé car ma connexion internet ne me permet pas de télécharger un soft aussi volumineux mais essaye de désinstaller avec "total unistaller" et réinstalle de nouveau
Salut peux tu me donner le lien d'avance merci
cordialement |
| Citroen service box 5.2012 TORRENT | Scanworld2020 | PSA Group Peugeot, Citroën | 0 | 23/12/2012 19h00 |
| TecDoc 2Q 2012 | Mecatec | Logiciel & autres documentations général | 1 | 06/09/2012 12h10 |
| la nouvelle version du tecdoc 3Q.2012 | Mecatec | Logiciel & autres documentations général | 3 | 03/08/2012 20h54 |
