Pouvoir de réputation: 0 ![]() ![]() |
Delphi 2020 (que je trouve plus ergonomique qu'autocom) avec le nouveau keygen sans remettre le pc avant le13-12-2021
| The Following 124 Users Say Thank You to Truckers_Diag For This Useful Post: | abdel93 (24/01/2022), ABDESLAM (23/01/2022), AbouRayene (04/04/2022), adiago (23/01/2022), adilalioua (04/08/2022), aigle459 (24/01/2022), al1962 (31/01/2022), alex13105 (26/02/2022), anastronic (24/01/2022), Antoine73 (05/07/2022), aurelien07 (20/03/2022), autodiagauto (23/01/2022), bascoland (25/01/2022), bladi (16/03/2022), Bollide (24/01/2022), boukrama (24/01/2022), carpo63 (23/02/2022), claude.n (24/01/2022), Cougark (30/03/2022), daho22 (27/03/2022), dart (07/07/2022), dede83 (23/01/2022), devildante007 (05/04/2022), DIAGAUTO33 (13/03/2022), diagreprog123 (29/01/2022), djedy2 (23/01/2022), DOUDOU (24/01/2022), dre28 (20/02/2022), drone (18/03/2022), E46 (24/01/2022), Evasion_Td12 (25/01/2022), FABRICE56 (23/01/2022), fedge (15/08/2022), fredelek (23/01/2022), freeuser (24/01/2022), funkykarim (07/02/2022), G00 (24/01/2022), GERALDIHNO (11/03/2022), Geri (30/07/2022), gringo783 (29/01/2022), guillaume9820 (24/01/2022), HAKIMDACHE (11/03/2022), hercules2014 (06/04/2022), Hibernatus (19/02/2022), Honda (24/01/2022), ICARES62 (23/01/2022), imadeb13 (05/04/2022), inthewind (09/03/2022), jaglo (11/08/2022), jeager13 (26/03/2022), jean-marc 10 (26/03/2022), jeremy72 (23/01/2022), Jock66 (23/01/2022), joelectronic (23/01/2022), Jojo55 (28/03/2022), juju64 (05/04/2022), julie.long (23/01/2022), kalagane (23/01/2022), kamilwlkp (05/03/2022), karimus (23/01/2022), kevin22 (02/02/2022), klif26 (23/01/2022), Legrizzly (23/01/2022), lpmlpm (25/01/2022), mahfoud lichani (23/01/2022), Malfra90 (24/01/2022), manudiag (17/02/2022), maximin (23/01/2022), mb74700 (06/02/2022), Mécano 32 (13/07/2022), mecano1 (16/07/2022), MECASOLUTION (26/03/2022), MECAUTO (28/03/2022), Med1387 (24/01/2022), Michelange37 (24/01/2022), Mickajifu (23/01/2022), Miika31 (05/07/2022), mirage47 (01/04/2022), mohaalba (23/01/2022), Mohamed tech (09/03/2022), Momo44 (24/01/2022), newbam (29/01/2022), Nico76 (23/01/2022), Notixnorix (29/01/2022), passemoi (31/01/2022), pattaya2001 (26/01/2022), Pelican (23/01/2022), pp08 (23/01/2022), raimond52 (24/01/2022), raptor95 (22/07/2022), redou28 (15/03/2022), sami47 (30/01/2022), Scholes (23/07/2022), Sebos (23/01/2022), Seev59 (22/07/2022), Selim70 (09/03/2022), smith78 (27/01/2022), stef56100 (31/01/2022), steph06000 (12/03/2022), sundancer (06/04/2022), tazabenz (04/03/2022), thierry du58 (23/01/2022), thomasleovan2011 (30/01/2022), Tmontigny (26/01/2022), tomawak (23/01/2022), toniodcgaj (27/03/2022), ToNy68 (24/01/2022), toto014 (24/01/2022), toze60 (23/01/2022), TR-DELIGHT (06/04/2022), turbo (26/01/2022), uncleseb (25/01/2022), verbatime (24/01/2022), vince11 (30/01/2022), vortex (23/01/2022), Will410 (06/07/2022), yann3 (23/01/2022), YomGui (24/01/2022), yoyomartin2003 (13/03/2022), zav_ze_best (23/01/2022), Zozoouf (25/01/2022), zrom69 (24/03/2022) |
Slt
Merci pour ton partage. Installation ok. Activation clé ok. Mais au lancements, ceci comme message (voir photo). Pc netbook qui fonctionne sous AMD 1.20 GHZ avec Windows 7 stater. ![]() Envoyé de mon SM-G960F en utilisant Tapatalk |
Merci pour le partage, mon ancien était de 2017 et à ma connaissance je penser qu'on trouver trouver seulement le 2018. Je vais le tester. Encore merci.
Pouvoir de réputation: 10 ![]() ![]() ![]() |
parmi ceux qui l'on testé, la description des codes défaut est elle en français ?
pas de clic thank's , pas de clic sur réputations, pas d'aide ! |
Pouvoir de réputation: 10 ![]() ![]() ![]() ![]() |
Je ne l'ai pas encore pris, je voulais savoir si il y a une mise à jour au niveau des véhicules ?
Envoyé de mon HMA-L29 en utilisant Tapatalk |
#6 | ||
oui sur cette version, tu as bien du 2020 comme véhicule . A+ ---------- Post added at 12h09 ---------- Previous post was at 12h01 ---------- Citation:
oui sur cette version, tu as bien du 2020 comme véhicule . A+ |
| The Following 2 Users Say Thank You to VroumVroum For This Useful Post: | Creazy78 (24/01/2022), DIAGAUTO33 (16/03/2022) |
pour moi il ne se lance pas, j'ai bien mis le dossier sur c et les raccourci sur le bureau, meme si j'essaye de lancer a partir de le Main.exe rien ne se passe |
#8 | |
Pouvoir de réputation: 9 ![]() ![]() ![]() ![]() |
Merci encore à Truckers_Diag pour le partage. J'ai pensé au début qu'il s'agissait d'un pack visuel mais Delphi ne s'installe pas dans /programmes comme autocom. Pour ma part sur windows 10 pro x64, autocom 2023 déjà installé et activé. J'ai juste copié le dossier Delphi dans la racine C: copié les deux raccourcis sur le bureau et en les lançant çà configure et active Delphi. Je ne l'ai pas encore comparé à autocom en diag mais j'ai remarqué que le fw n'est pas le 3201. Est-ce que quelqu'un connait la version fw recommandée pour cette version ? Au pire je pense que la même version que pour autocom (3201) fera l'affaire. À vérifier. Merci d'avance pour vos infos. |
| The Following User Says Thank You to Sebos For This Useful Post: | pp08 (26/01/2022) |
#9 | |
J'ai le même problème : https://www.tlemcen-electronic.com/f...d.php?p=912793 Envoyé de mon SM-G960F en utilisant Tapatalk |
#10 | |
![]() Date d'inscription: décembre 2018
Pouvoir de réputation: 21 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
https://youtu.be/CzgnDhC8Eik Envoyé de mon ELE-L29 en utilisant Tapatalk |
#11 | ||
---------- Post added at 10h59 ---------- Previous post was at 10h57 ---------- Citation:
| The Following User Says Thank You to kalagane For This Useful Post: | toze60 (26/01/2022) |
Du coup la version est full française ? Quelqu'un a un retour après plusieurs Essay ? Envoyé de mon PRA-LX1 en utilisant Tapatalk |
Pouvoir de réputation: 66 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| The Following 4 Users Say Thank You to POCOYO For This Useful Post: |
Slt
Tester aujourd'hui avec le firmware de mon câble car impossible de le mettre à jour. Fonctionne bien sur mon A3 . Encore merci pour le partage. Envoyé de mon SM-G960F en utilisant Tapatalk |
#15 |
Pouvoir de réputation: 8 ![]() ![]() |
Hello,
Fonctionne visiblement bien sur BMW (contrairement à Autocom 2020). Bonne journée Le golfiste |
| Pack Xentry Passthru 09-2020 + keygen | SaTouF | Mercedes Benz | 36 | 31/07/2026 07h58 |
| Keygen Autocom (SuperActivator.2020.23) | ToNy68 | Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel | 9 | 08/03/2024 23h51 |
| Keygen final autocom 2020 gratuit | omarzoro | Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel | 0 | 30/12/2021 10h13 |
| VMWare Keygen Autocom 2020.23 | julie.long | Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel | 13 | 24/12/2021 11h42 |
