Vieux 26/01/2017, 22h33   #61
guyguy307
Avatar de guyguy307
Pouvoir de réputation: 41
Yes and svg viewer
Vieux 31/01/2017, 00h37   #62
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
The solution to this problem was as expected from the beginning, removing or commenting "version=08.xx" in "version.ini" and setting it to "version=07.xx" resolves the issue with Lexia and PP2000, like this:
[APPLICATION]
Version=07.817
This is explained in the DiagBox 8.01 Installation (updated) thread under Versions.
However, there is an interesting point here. When the option "Hide extensions for known file types" in the File Manager menu is checked, then file extensions do not show. In this case the user may be editing a file named "version.ini.txt" which will not work.
Hence, ensure that the option "Hide extensions for known file types" is unchecked so that you see file extensions.
Simple est déconnecté   Réponse avec citation
Vieux 01/02/2017, 20h26   #63
Simple
Avatar de Simple
DiagBox 7.xx ends at 7.77. the rest is made up.. but if you insist, it virtually be 07.102
But you can enter 07.838 and it will work fine and it will give accurate indication of your DiagBox v8.
The Following User Says Thank You to Simple For This Useful Post:
SASIKO (25/11/2018)
Vieux 25/11/2018, 22h25   #64
SASIKO
Avatar de SASIKO
SASIKO is an unknown quantity at this point
Merci pour ce tuto complet
SASIKO est déconnecté   Réponse avec citation
Quoi faire avec le xs evolution sous diagbox , pp2000, lexia ishams2002 LEXIA, PP2000, DiagBox 7 14/11/2014 19h56
cherche logiciels diagbox, lexia et pp2000 originale beka1975 LEXIA, PP2000, DiagBox 1 20/11/2013 23h06
Peugeot/Citroen DIAGBOX PP2000 LEXIA bloker LEXIA, PP2000, DiagBox 7 30/10/2013 07h27
Fuseau horaire GMT +1. Il est actuellement 13h33.
