Vieux 04/03/2018, 19h48   #31
joe_isma
Avatar de joe_isma
joe_isma will become famous soon enoughjoe_isma will become famous soon enough
P0340 - Vilebrequin et arbre à cames, synchronisation ; aucun signal du vilebrequin
capteur pmh, accessible facilement
joe_isma est déconnecté   Réponse avec citation
The Following User Says Thank You to joe_isma For This Useful Post:
fred974 (04/03/2018)
Vieux 04/03/2018, 19h52   #32
DIAGSYSTEM25
Avatar de DIAGSYSTEM25
Pouvoir de réputation: 44
Capteur pression differenciel en court circuit...
The Following User Says Thank You to DIAGSYSTEM25 For This Useful Post:
Vieux 04/03/2018, 20h00   #33
joe_isma
Avatar de joe_isma
si ta voiture demarre au start pilote et que tu arrive a roulé sans problème, regarde ton filtre a gasoil si il n'y a pas de limailles. si ca serai le capteur pmh elle ne demarrerai pas du tout.
Vieux 04/03/2018, 20h09   #34
fred974
Avatar de fred974
fred974 will become famous soon enough
il n'y as pas de F
---------- Post added at 20h08 ---------- Previous post was at 20h07 ----------
Il n'y as pas de FAP sur ce modèle
---------- Post added at 20h09 ---------- Previous post was at 20h08 ----------
Donc pas de capteur de differenciel
fred974 est déconnecté   Réponse avec citation
Vieux 04/03/2018, 20h10   #35
rotax
Avatar de rotax
Pouvoir de réputation: 36
rotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond repute
type moteur RHS elle as un FAP
rotax est déconnecté   Réponse avec citation
The Following User Says Thank You to rotax For This Useful Post:
fred974 (05/03/2018)
Vieux 05/03/2018, 10h33   #36
zatazk
Avatar de zatazk
zatazk is just really nicezatazk is just really nicezatazk is just really nicezatazk is just really nicezatazk is just really nice
bonjour refait l'apprentissage du bsi surement de programmé
zatazk est déconnecté   Réponse avec citation
The Following User Says Thank You to zatazk For This Useful Post:
Vieux 05/03/2018, 10h46   #37
adiago
Avatar de adiago
Pouvoir de réputation: 35
le RHZ n'a pas de FAP
il est sorti une 307 2.0 Hdi 110cv avec FAP et une 307 2.0 Hdi 110cv sans FAP .
The Following 2 Users Say Thank You to adiago For This Useful Post:
fayssal2017 (05/03/2018), fred974 (05/03/2018)
Vieux 05/03/2018, 13h45   #38
rotax
Avatar de rotax
Envoyé par adiago Voir le message
adiago si tu regarde son premier message tu verra qu'il indique que son véhicule est une 307 RHS donc (2.0hdi 110 FAP)
si il as fait une erreur de type moteur avec son outils de diag ..
je pense qu'il peu recommencer son diag depuis le début et la liste de défauts sera différente...
bon courage..
The Following 3 Users Say Thank You to rotax For This Useful Post:
dingo307 (05/03/2018), fred974 (05/03/2018), stef848 (05/03/2018)
Vieux 11/03/2018, 02h54   #39
fred974
Avatar de fred974
Bonjour ,
j'ai changer le capteur AAC ainsi que le capteur vilebrequin et toujours même résultat
ensuite j'ai changer le capteur de pression de rampe et a ce moment la elle a démarre au quart de tour mais après avoir laissé tourner un moment je l’éteint et même scène elle ne démarre plus
les défauts qui restent sont
P1614 - Court-circuit à la batterie du circuit de capteur d'alimentation
Vieux 11/03/2018, 04h59   #40
danyparis
Avatar de danyparis
danyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud of
Envoyé par fred974 Voir le message
Bonjour ,
débranche la pédale d'accélérateur, pression clim, egr si pas pneumatique, electrovannes et tu as un capteur normalement sur le GO en haut (fiche rouge), capteur AAC, Pression turbo, pression diff et essaye de démarrer à ce moment la
tout ça c'est du 5V
Si ça démarre au quart de tour dans ce cas rebranche les 1 par 1 jusqu'a ce qu'elle merdouille
ZA KRALJA I OTADZBINU, SLOBODA ILI SMRT
danyparis est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to danyparis For This Useful Post:
fayssal2017 (11/03/2018), Pilouf (11/03/2018)
Vieux 11/03/2018, 12h01   #41
rotax
Avatar de rotax
Envoyé par rotax Voir le message
fait attention aussi au faisceau intermédiaire qui va au capteur de pression rail
tu as contrôler le faisceau du capteur pression rail ??
démonte le directement c'est assez rapide ce faisceau fait environ 30cm et il cause souvent problème.
tu touche au capteur pression rail et ca remarche puis le probléme revient ...................
la panne ces le faisceau du capteur de pression rail ou faisceau principal moteur au niveau de la gouttière plastique qui passe devant la pompe hp !!
AP56 (12/03/2018), fayssal2017 (11/03/2018), jah83 (11/03/2018)
Vieux 11/03/2018, 12h26   #42
rotax
Avatar de rotax
tien une simple recherche google sur le faisceau pression rail.
The Following 2 Users Say Thank You to rotax For This Useful Post:
adiago (01/06/2022), fayssal2017 (11/03/2018)
Vieux 12/03/2018, 19h53   #43
LACRAPS
Avatar de LACRAPS
LACRAPS is on a distinguished road
Slt
un RAZ des defauts ensuite test du capteur vilebrequin
LACRAPS est déconnecté   Réponse avec citation
Vieux 12/03/2018, 21h28   #44
rotax
Avatar de rotax
LACRAPS essaye de lire le sujet !!!!!!
Vieux 12/03/2018, 21h53   #45
Pouvoir de réputation: 279
Contrôle le calage tu met une pige au démarreur je suis sur dans aac la pige rentre pas..
806 hdi ne demarre plus bounechada abdel PSA Group Peugeot, Citroën 39 14/04/2016 22h10
307 hdi démarre pas mbn30 PSA Group Peugeot, Citroën 26 18/06/2015 22h57
306 ne démarre plus looping8910 PSA Group Peugeot, Citroën 18 04/10/2013 21h43
Fuseau horaire GMT +1. Il est actuellement 21h55.
