#16 |
J’ai oublié de dire c’est un ALLSPACE je sais pas si ça change quelque chose
#17 |
Personne sais où sa se trouve ?
#18 |
Up svp si quelqu’un a une idée
#19 | ||
Pouvoir de réputation: 66 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Salam le all Space est il 7 places si oui C’est une sécurité pour éviter des pincements de doigts quand des personnes sont sur les derniers sièges ---------- Post added at 20h31 ---------- Previous post was at 20h29 ---------- Citation:
Possible de tenter coding Original Coding: (1)-Activation using rear lid opening button in remote key - Touch function for opening: not active (2)-Activation using rear lid opening button in remote key - Tap function for opening: active (3)-Activation using rear lid opening button in remote key - Touch function for closing: active (4)-Activation using rear lid opening button in remote key - Tap function for closing: not active (1)-Activation using rear lid remote unlocking switch - Touch function for opening: not active (2)-Activation using rear lid remote unlocking switch - Tap function for opening: active (3)-Activation using rear lid remote unlocking switch - Touch function for closing: active (4)-Activation using rear lid remote unlocking switch - Tap function for closing: not active New Coding: (1)-Activation using rear lid opening button in remote key - Touch function for opening: not active (2)-Activation using rear lid opening button in remote key - Tap function for opening: active (3)-Activation using rear lid opening button in remote key - Touch function for closing: active (4)-Activation using rear lid opening button in remote key - Tap function for closing: active (1)-Activation using rear lid remote unlocking switch - Touch function for opening: not active (2)-Activation using rear lid remote unlocking switch - Tap function for opening: active (3)-Activation using rear lid remote unlocking switch - Touch function for closing: active (4)-Activation using rear lid remote unlocking switch - Tap function for closing: active ---------- Post added at 20h32 ---------- Previous post was at 20h31 ---------- Citation:
module 6D (Trunk Electrics), security access and enter security code "12345". Then still in Module 6D, click Adaptation, channel |
#20 |
![]() Date d'inscription: octobre 2021
Salam
Bien vu pour la sécurité. Du coup as tu essayer avec les 2 derniers siege rabbatu ? Au cas ou Cordialement
Il ne faut pas perdre son temps à avancer des arguments de bonne foi face à des gens de mauvaise foi |
#22 |
Oui bien sure mais juste pour voir si ya un capteur quand les siege sont rabbatu.
#23 |
Slm oui allspace 7 place
J’ai pas penser a sa Mais bon ils auront qu’à garder leur sur les genoux lol Je vais regarder le coding Merci les gars |
#24 |
![]() Date d'inscription: décembre 2018
Pouvoir de réputation: 23 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
salut essaie ca..
Fermeture assistée du hayon Appuyez sur le bouton du hayon lorsqu'il est ouvert tire l'interrupteur de la portière conducteur vers le haut lorsque le contact est mis jusqu'à ce que le hayon soit fermé. Sur les véhicules avec accès sans clé avec démarrage par bouton-poussoir : appuye brièvement sur le bouton de la clé du véhicule et maintient-le enfoncé. La clé du véhicule à télécommande doit être près du hayon pour utiliser cette fonction. OU : commence à fermer le hayon à la main jusqu'à ce qu'il se ferme tout seul. |
| PMH tiguan 2l 140 tdi | OILC93 | Mécanique générale | 11 | 01/03/2024 14h39 |
| EGR off Tiguan 2l TDI CR | slklite | Chiptuning | 5 | 20/10/2021 19h56 |
| tiguan edc 17 | Meziane93 | Immobilizer dumps/solutions | 11 | 02/09/2019 23h23 |
| edc17cp14 tiguan egr.off/fap.off | magic abdou | Chiptuning | 10 | 07/07/2019 13h35 |
| Fap tiguan | Meziane93 | VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche | 3 | 05/02/2014 08h03 |
