Vieux 03/05/2025, 20h06   #16
ECU diag
Avatar de ECU diag
Pouvoir de réputation: 65
J’ai oublié de dire c’est un ALLSPACE je sais pas si ça change quelque chose
Vieux 11/05/2025, 11h50   #17
ECU diag
Avatar de ECU diag
Personne sais où sa se trouve ?
Vieux 27/05/2025, 21h54   #18
ECU diag
Avatar de ECU diag
Up svp si quelqu’un a une idée
Vieux 27/05/2025, 23h32   #19
POCOYO
Avatar de POCOYO
Pouvoir de réputation: 66
Envoyé par ECU diag Voir le message
Salam le all Space est il 7 places si oui
C’est une sécurité pour éviter des pincements de doigts quand des personnes sont sur les derniers sièges
---------- Post added at 20h31 ---------- Previous post was at 20h29 ----------
Possible de tenter coding
Original Coding:
(1)-Activation using rear lid opening button in remote key - Touch function for opening: not active
(2)-Activation using rear lid opening button in remote key - Tap function for opening: active
(3)-Activation using rear lid opening button in remote key - Touch function for closing: active
(4)-Activation using rear lid opening button in remote key - Tap function for closing: not active
(1)-Activation using rear lid remote unlocking switch - Touch function for opening: not active
(2)-Activation using rear lid remote unlocking switch - Tap function for opening: active
(3)-Activation using rear lid remote unlocking switch - Touch function for closing: active
(4)-Activation using rear lid remote unlocking switch - Tap function for closing: not active
New Coding:
(4)-Activation using rear lid opening button in remote key - Tap function for closing: active
(4)-Activation using rear lid remote unlocking switch - Tap function for closing: active
---------- Post added at 20h32 ---------- Previous post was at 20h31 ----------
Original Coding:
New Coding:
module 6D (Trunk Electrics), security access and enter security code "12345". Then still in Module 6D, click Adaptation, channel
ECU diag (02/06/2025), Fastdiag (28/05/2025)
Vieux 28/05/2025, 08h53   #20
Fastdiag
Avatar de Fastdiag
Fastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond reputeFastdiag has a reputation beyond repute
Salam
Bien vu pour la sécurité. Du coup as tu essayer avec les 2 derniers siege rabbatu ? Au cas ou
Cordialement
Il ne faut pas perdre son temps à avancer des arguments de bonne foi face à des gens de mauvaise foi
Fastdiag est déconnecté   Réponse avec citation
Vieux 28/05/2025, 10h51   #21
POCOYO
Avatar de POCOYO
Envoyé par Fastdiag Voir le message
Salam
Cordialement
Vu que c’est essentiellement des petites places enfants pour éviter de prendre leur petites mains dans le cisaillement j’aurai laissé comme ça 🫨
Vieux 28/05/2025, 11h51   #22
Fastdiag
Avatar de Fastdiag
Oui bien sure mais juste pour voir si ya un capteur quand les siege sont rabbatu.
Vieux 02/06/2025, 20h21   #23
ECU diag
Avatar de ECU diag
Slm oui allspace 7 place
J’ai pas penser a sa
Mais bon ils auront qu’à garder leur sur les genoux lol
Je vais regarder le coding
Merci les gars
Vieux 03/06/2025, 06h46   #24
a3pughjolu
Avatar de a3pughjolu
Pouvoir de réputation: 23
a3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud of
salut essaie ca..
Fermeture assistée du hayon
Appuyez sur le bouton du hayon lorsqu'il est ouvert
​tire l'interrupteur de la portière conducteur vers le haut lorsque le contact est mis jusqu'à ce que le hayon soit fermé.
Sur les véhicules avec accès sans clé avec démarrage par bouton-poussoir : appuye brièvement sur le bouton de la clé du véhicule et maintient-le enfoncé. La clé du véhicule à télécommande doit être près du hayon pour utiliser cette fonction.
OU : commence à fermer le hayon à la main jusqu'à ce qu'il se ferme tout seul.
PMH tiguan 2l 140 tdi OILC93 Mécanique générale 11 01/03/2024 14h39
EGR off Tiguan 2l TDI CR slklite Chiptuning 5 20/10/2021 19h56
tiguan edc 17 Meziane93 Immobilizer dumps/solutions 11 02/09/2019 23h23
edc17cp14 tiguan egr.off/fap.off magic abdou Chiptuning 10 07/07/2019 13h35
Fap tiguan Meziane93 VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 3 05/02/2014 08h03
Fuseau horaire GMT +1. Il est actuellement 05h08.
