Vieux 08/03/2022, 11h01   #1
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Lightbulb Xentry OpenShell 12.2021 HHT (+C3) WIS EPC Vediamo Monaco (Acronis L+UEFI) - Mega
Xentry OpenShell 12.2021 HHT (+C3) WIS EPC Starfinder Vediamo Monaco (Acronis L+UEFI) - Mega
Computer requirements:
  • HDD or SDD 480 Gb
  • RAM 4 Gb
  • Processor with support for virtualization technology (enable virtualization in BIOS).
VHD image with Windows 10 LTSC x64 Rus (by default) + English.
This version is a revision and modification of the 09.2021 image, it is fully configured for offline, all offline patches are applied and additional ones are activated. functions for DAS. A patch for Xentry Offline login has been applied. XUS 6.8.0.0 configured and activated! The data map in WIS and EPC has been configured, shortcuts for direct launch are also made, and the transition from Xentry and DAS to WIS is activated (WIS must already be launched before starting Xentry or DAS).
Why VHD and not Acronis? - VHD is a more universal format, you can immediately boot from it without expanding the image by making a couple of clicks in the Easy BCD program. Can be connected to virtual machines. You can deploy it as an acronym or other programs to disk (it is recommended to use VHD2DISK). In two clicks it is mounted in the system and you can take any information from there. Added Strelec WINPE and Rufus to create a bootable USB flash drive for image recovery.
Programs in the image:
  • Xentry OpenShell 12.2021
  • DAS SCN offline coding (SDFlash 07.2018)
  • Xentry OpenShell 09.2014 (virtual machine for SD Connect С3 and direct connections to ECU from DAS to HHTwin)
  • Xentry Update Service 6.8.0.0
  • Vediamo 05.01.01 + configured for С6, Xentry VCI, VCX SE
  • DTS Monaco v8.14.016 + projects 2019 (8.16.015 with my activation) + configure for С6, Xentry VCI, VCX SE
  • EPC 11.2018
  • WIS 10.2020
  • StarFinder 2016 (with wiring diagrams) + 2020 (without)
  • COMANDDownloadManager login: DLM password: DLM
  • HTTwin на Hyper-V password: 111
  • FDOK
  • MBSeedKey + DLLs 2020
  • Seed Calculator + DLLs 2020
  • DisassembyAssistant
  • Regio ECU 09.2014
  • VGSNAG2 Manager v1.6
  • SDmedia
  • Vediamo and DTS Monaco manuals
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following 43 Users Say Thank You to Aleksey-MS For This Useful Post:
abdel2stif (20/10/2023), agentghost (23/09/2026), alyot62 (13/04/2023), AME (03/09/2023), AnarkiaII (09/04/2023), anastronic (09/10/2024), Anouaros93 (05/01/2024), attefco (06/11/2024), aujibe (24/01/2024), Bahoutator (04/11/2022), baso123 (30/01/2024), BILEL1111 (05/04/2026), chipshop (19/09/2025), dalco (28/10/2023), espi (10/01/2024), FLeO101 (04/11/2024), Gregof45 (20/11/2022), Guidel37 (15/06/2025), hicham075 (20/12/2023), jeanalitre (09/06/2025), karimus (02/06/2022), Kev159 (26/03/2025), laurentk (25/12/2022), leon69 (18/06/2023), LEX85 (26/07/2022), matt978 (21/01/2025), MecaTech (08/04/2025), mecatronique (27/04/2022), mnaouar (04/06/2023), mxxauto (22/10/2022), Népal62 (01/10/2022), NewSmart (01/06/2022), PixL (09/03/2022), raptor95 (02/06/2022), sandromadruga (03/08/2022), Selim70 (07/12/2022), sigli (14/09/2022), stounolog (12/03/2024), SWALK (19/02/2023), taha2013 (05/02/2025), Yassu18 (12/06/2022), Yolit (04/06/2023), zenata (17/09/2022)
Vieux 01/06/2022, 19h58   #2
NewSmart
Avatar de NewSmart
NewSmart will become famous soon enough
merci pour le partage
je pensais que le C3 était vouait a aller a la déchèterie car je suis sur une vielle version de Xentry 2012 et j'ai également le 2014 qui semblait être la dernière version compatible avec le C3 !
Est ce qu'il faut une configuration spécifique pour l'ordinateur ? ( i3, i5 ou i7 )
ou le D630 core 2duo 4go SSD suffirait ?
merci beaucoup
bonne fin de soirée
Le partage d'une passion commune : l'automobile
NewSmart est déconnecté   Réponse avec citation
Vieux 02/06/2022, 00h50   #3
ToNy68
Avatar de ToNy68
ToNy68 is a splendid one to beholdToNy68 is a splendid one to beholdToNy68 is a splendid one to beholdToNy68 is a splendid one to beholdToNy68 is a splendid one to beholdToNy68 is a splendid one to beholdToNy68 is a splendid one to behold
Salut, oui ca suffit
ToNy68 est déconnecté   Réponse avec citation
The Following User Says Thank You to ToNy68 For This Useful Post:
NewSmart (02/06/2022)
Vieux 02/06/2022, 07h31   #4
Aleksey-MS
Envoyé par NewSmart Voir le message
merci beaucoup
bonne fin de soirée
Hello, that's right, C3 is an old soft from before 2014, but in this image I placed a virtual machine with C3 for those who want to experiment, maybe I can get it to work.
As for the image, it is better to use at least i3 + 4-6 Ram + 480 SSD for it
The Following 4 Users Say Thank You to Aleksey-MS For This Useful Post:
laurentk (25/12/2022), MecaTech (08/04/2025), NewSmart (02/06/2022), zenata (17/09/2022)
Vieux 02/06/2022, 18h25   #5
NewSmart
Avatar de NewSmart
Envoyé par Aleksey-MS Voir le message
Merci beaucoup pour votre réponse, ducout je pense dans les mois a venir acheter un C6
Passer une bonne journée
Vieux 02/06/2022, 18h37   #6
Aleksey-MS
Welcome my friend !
The Following User Says Thank You to Aleksey-MS For This Useful Post:
Vieux 07/06/2022, 16h51   #7
Aleksey-MS
Par défaut Xentry OpenShell 06.2022 HHT (+C3) WIS EPC Vediamo Monaco (Acronis L+UEFI) - Mega
The Following 3 Users Say Thank You to Aleksey-MS For This Useful Post:
MecaTech (08/04/2025), NewSmart (07/06/2022), zenata (17/09/2022)
Vieux 12/09/2022, 11h27   #8
Aleksey-MS
Added new image Xentry OpenShell 09.2022 HHT (+C3) WIS EPC Starfinder Vediamo Monaco (Acronis L+UEFI)
The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post:
MecaTech (08/04/2025), zenata (17/09/2022)
Vieux 07/12/2022, 10h08   #9
Aleksey-MS
Added new image Xentry OpenShell 12.2022 HHT (+C3) WIS EPC Starfinder Vediamo Monaco (Acronis L+UEFI)
jeanalitre (09/06/2025), MecaTech (08/04/2025), NewSmart (18/07/2023), Selim70 (07/12/2022)
Vieux 05/04/2023, 08h07   #10
nouroudji
Avatar de nouroudji
nouroudji is an unknown quantity at this point
je peux accéder au lien partager par les collègue merci
nouroudji est déconnecté   Réponse avec citation
Vieux 12/04/2023, 10h49   #11
Aleksey-MS
Added Xentry OpenShell 03.2023 HHT (+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis L+UEFI)
The Following 5 Users Say Thank You to Aleksey-MS For This Useful Post:
alyot62 (13/04/2023), jeanalitre (09/06/2025), MecaTech (08/04/2025), mnaouar (04/06/2023), NewSmart (18/07/2023)
Vieux 22/06/2023, 14h27   #12
Aleksey-MS
Added Xentry OpenShell 06.2023 XUS HHT DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis)
Vieux 18/07/2023, 19h05   #13
NewSmart
Avatar de NewSmart
Pour nouvelle version il faut désinstaller l'ancienne ou c'est une mise a jour ?
Vieux 28/09/2023, 12h18   #14
Aleksey-MS
Added Xentry OpenShell 09.2023 HHT (+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis L+UEFI)
Vieux 24/10/2023, 15h10   #15
Aleksey-MS
The link was updated
Xentry OpenShell 09.2020 HHT DAS SCN WIS EPC STARFINDER VEDIAMO MONACO Image Acronis PATAROUCI Mercedes Benz 9 20/11/2022 00h27
Xentry Passthru OpenShell 2021.12 boukrama MBStar, Xentry, DAS 13 11/07/2022 21h59
Xentry Passthru 09.2021 (Mega) Ossion MBStar, Xentry, DAS 14 26/02/2022 07h02
Xentry Passthru OpenShell 2021.06 boukrama MBStar, Xentry, DAS 1 09/06/2021 19h51
ODX & CBF 03/2017 pour vediamo et dts monaco car83 Mercedes Benz 0 31/01/2020 15h18
Fuseau horaire GMT +1. Il est actuellement 11h30.
