![]() Date d'inscription: juin 2021
Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Xentry OpenShell 12.2021 HHT (+C3) WIS EPC Starfinder Vediamo Monaco (Acronis L+UEFI) - Mega
Computer requirements:
This version is a revision and modification of the 09.2021 image, it is fully configured for offline, all offline patches are applied and additional ones are activated. functions for DAS. A patch for Xentry Offline login has been applied. XUS 6.8.0.0 configured and activated! The data map in WIS and EPC has been configured, shortcuts for direct launch are also made, and the transition from Xentry and DAS to WIS is activated (WIS must already be launched before starting Xentry or DAS). Why VHD and not Acronis? - VHD is a more universal format, you can immediately boot from it without expanding the image by making a couple of clicks in the Easy BCD program. Can be connected to virtual machines. You can deploy it as an acronym or other programs to disk (it is recommended to use VHD2DISK). In two clicks it is mounted in the system and you can take any information from there. Added Strelec WINPE and Rufus to create a bootable USB flash drive for image recovery. Programs in the image:
![]() Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
| The Following 43 Users Say Thank You to Aleksey-MS For This Useful Post: | abdel2stif (20/10/2023), agentghost (23/09/2026), alyot62 (13/04/2023), AME (03/09/2023), AnarkiaII (09/04/2023), anastronic (09/10/2024), Anouaros93 (05/01/2024), attefco (06/11/2024), aujibe (24/01/2024), Bahoutator (04/11/2022), baso123 (30/01/2024), BILEL1111 (05/04/2026), chipshop (19/09/2025), dalco (28/10/2023), espi (10/01/2024), FLeO101 (04/11/2024), Gregof45 (20/11/2022), Guidel37 (15/06/2025), hicham075 (20/12/2023), jeanalitre (09/06/2025), karimus (02/06/2022), Kev159 (26/03/2025), laurentk (25/12/2022), leon69 (18/06/2023), LEX85 (26/07/2022), matt978 (21/01/2025), MecaTech (08/04/2025), mecatronique (27/04/2022), mnaouar (04/06/2023), mxxauto (22/10/2022), Népal62 (01/10/2022), NewSmart (01/06/2022), PixL (09/03/2022), raptor95 (02/06/2022), sandromadruga (03/08/2022), Selim70 (07/12/2022), sigli (14/09/2022), stounolog (12/03/2024), SWALK (19/02/2023), taha2013 (05/02/2025), Yassu18 (12/06/2022), Yolit (04/06/2023), zenata (17/09/2022) |
Pouvoir de réputation: 11 ![]() |
merci pour le partage je pensais que le C3 était vouait a aller a la déchèterie car je suis sur une vielle version de Xentry 2012 et j'ai également le 2014 qui semblait être la dernière version compatible avec le C3 ! Est ce qu'il faut une configuration spécifique pour l'ordinateur ? ( i3, i5 ou i7 ) ou le D630 core 2duo 4go SSD suffirait ? merci beaucoup bonne fin de soirée
Le partage d'une passion commune : l'automobile |
#4 | |
As for the image, it is better to use at least i3 + 4-6 Ram + 480 SSD for it
#5 | |
Merci beaucoup pour votre réponse, ducout je pense dans les mois a venir acheter un C6 Passer une bonne journée
Welcome my friend !
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | MecaTech (08/04/2025) |
Xentry OpenShell 06.2022 HHT (+C3) WIS EPC Vediamo Monaco (Acronis L+UEFI) - Mega
Added new image Xentry OpenShell 09.2022 HHT (+C3) WIS EPC Starfinder Vediamo Monaco (Acronis L+UEFI)
Added new image Xentry OpenShell 12.2022 HHT (+C3) WIS EPC Starfinder Vediamo Monaco (Acronis L+UEFI)
| The Following 4 Users Say Thank You to Aleksey-MS For This Useful Post: |
#10 |
je peux accéder au lien partager par les collègue merci |
#11 |
Added Xentry OpenShell 03.2023 HHT (+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis L+UEFI)
| The Following 5 Users Say Thank You to Aleksey-MS For This Useful Post: | alyot62 (13/04/2023), jeanalitre (09/06/2025), MecaTech (08/04/2025), mnaouar (04/06/2023), NewSmart (18/07/2023) |
#12 |
Added Xentry OpenShell 06.2023 XUS HHT DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis)
#13 | |
Pour nouvelle version il faut désinstaller l'ancienne ou c'est une mise a jour ? Merci
#14 |
Added Xentry OpenShell 09.2023 HHT (+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis L+UEFI)
#15 |
The link was updated
| The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post: | jeanalitre (09/06/2025), MecaTech (08/04/2025) |
| Xentry OpenShell 09.2020 HHT DAS SCN WIS EPC STARFINDER VEDIAMO MONACO Image Acronis | PATAROUCI | Mercedes Benz | 9 | 20/11/2022 00h27 |
| Xentry Passthru OpenShell 2021.12 | boukrama | MBStar, Xentry, DAS | 13 | 11/07/2022 21h59 |
| Xentry Passthru 09.2021 (Mega) | Ossion | MBStar, Xentry, DAS | 14 | 26/02/2022 07h02 |
| Xentry Passthru OpenShell 2021.06 | boukrama | MBStar, Xentry, DAS | 1 | 09/06/2021 19h51 |
| ODX & CBF 03/2017 pour vediamo et dts monaco | car83 | Mercedes Benz | 0 | 31/01/2020 15h18 |
