Vieux 04/10/2018, 19h22   #16
CHIKODIAG
Avatar de CHIKODIAG
CHIKODIAG is a jewel in the roughCHIKODIAG is a jewel in the roughCHIKODIAG is a jewel in the roughCHIKODIAG is a jewel in the rough
HI full bdm.......
good luck
Type de fichier : rar Renault-Espace IV.rar (1,50 Mo, 28 affichages)
CHIKODIAG est déconnecté   Réponse avec citation
The Following User Says Thank You to CHIKODIAG For This Useful Post:
Topal (05/10/2018)
Vieux 05/10/2018, 06h28   #17
Topal
Avatar de Topal
Topal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to all
Hello, Chikodiag
i try next week i report
many thanks
Pat
Topal est déconnecté   Réponse avec citation
Vieux 09/10/2018, 07h03   #18
television
Avatar de television
television has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond repute
salut pas de nouvelle !!
cdl
x17officiel kess ktag v54, delphi officiel ,multidiag,ms908pro officiel,flex oficiel.vente fichiers
television est déconnecté   Réponse avec citation
Vieux 12/10/2018, 22h31   #19
television
sa serais bien un retour !!!!!!!!!!!!!!!!
cdl
The Following User Says Thank You to television For This Useful Post:
electronico (13/10/2018)
Vieux 14/10/2018, 21h04   #20
television
bonsoir
encore une fois de plus pas de retour , désespérant !!!! ont dit que les pros de donne pas de coup main ............. normal pas de retour ....
sa devient normal ou pas ............
cdl
Vieux 14/10/2018, 21h09   #21
Topal
Avatar de Topal
attends, t'enflamme pas tu sais tres bien que je fait toujours un retour, mais pour le moment je n'ai helas pas eu le temps de m'en occuper serieusement
ce que je peu juste te dire c'est que le premier dump n'a pas fonctionné
tu m'aurais demandé au lieu de m'engueulé et je t'aurais donné la meme reponse
je vous dirais que je retournerais sur le vehicule(cette demaine)
Pat
The Following 2 Users Say Thank You to Topal For This Useful Post:
skeuf (14/10/2018), television (14/10/2018)
Vieux 14/10/2018, 21h39   #22
television
ok merci ,mais tu sait souvent pas de retour ...il suffisait que donne une réponse au poste précédent . mais je m enflamme pas .
tien nous a courant et loin de moi de t'engueuler, je ne me permettrait pas .
cdl
Dernière modification par television ; 14/10/2018 à 21h48.
The Following 2 Users Say Thank You to television For This Useful Post:
skeuf (14/10/2018), Topal (15/10/2018)
Vieux 16/10/2018, 14h26   #23
Topal
Avatar de Topal
bon voila j'ai enfin eu le temps de mis remettre mais helas les nouvelles ne sont pas bonnes aucun dumps ne m'a permis de faire un vierge reellement, car pour l'immo ca oui le vierge etait ok mais impossible de changer le vin meme avec renolink et impossible de recoder les codes injecteurs
je vais reprendre un ECU et le rendre vierge car je crois que celui-ci a vraiment pris un pete
encore merci
Pat
The Following User Says Thank You to Topal For This Useful Post:
television (17/10/2018)
Vieux 16/04/2022, 13h14   #24
floux
Avatar de floux
floux is an unknown quantity at this point
Je suis dans le même cas que toi j'ai acheter un autre ecu pour faire un double, je souhaite le rendre vierge, comment tu as solutionné ton soucis ducoup?
Si tu as une astuce ou un fichier vierge qui a fonctionné je suis preneur.
floux
floux est déconnecté   Réponse avec citation
Vieux 17/04/2022, 08h24   #25
Topal
Avatar de Topal
Envoyé par floux Voir le message
floux
oui j'ai solutionné en remplacent l'ECU car celui d'origine etait hs puis avec RET j'ai rendu l'eeprom Vierge et pour etre sur, j'ai verifier le CHK
et apres ca j'ai pu recoder le nouvel ECU
Pat
Dtc off edc16cp33 9AZERTY123 Chiptuning 62 14/01/2026 14h40
edc16cp33 karera 1 Chiptuning 4 30/06/2018 16h03
Dpf edc16cp33 hamada Chiptuning 10 22/12/2015 15h17
Eeprom Espace 4 rimk95 Automobile en général 4 05/07/2014 13h04
Patte cassée sur eeprom 93c46 immobox espace 3 de 1998 Meziane93 Immobilizer dumps/solutions 8 15/03/2014 19h42
Fuseau horaire GMT +1. Il est actuellement 00h43.
