Discussion fermée
Vieux 25/01/2012, 13h37   #1
24gsm
Avatar de 24gsm
24gsm is on a distinguished road
Question clarion affiche (( security))
salut a tous
voila jais un clarion d'origine peugeot 405 . il marque security sur the lcd panel
alors je lais laisser 1 heure en marche mais rien tjr security . jais essayer d'appuyer sur la touche ((band )) et le laisser allumer pandans 1 heure, tjr pareille
esquille ya un moyen pour le débloquer .
ps . jais le code de cette auto radio
www.unlock-sl3.com
24gsm est déconnecté
Vieux 25/01/2012, 13h50   #2
cedrsan
Avatar de cedrsan
Pouvoir de réputation: 183
cedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond repute
apparement 1H c'est pas assez
Voila ce que ca dit chez Clarion :
Code:
Entering the wrong code will cause the systems
blocking device to activate and depending on which model
 you have, the display screen will remain blank or say "Security"
 In order for you to enter the correct code, you must leave your
radio's power turned on for up to 24hrs. The time delay will vary
 depending on how many times you've tried to enter a code after
 making the original mistake. "Code - In" or 4 zeros will eventually
flash in the display, providing you don't tamper with your radio during
the interim code clearance time. Once displayed enter the correct number
cedrsan est déconnecté
Vieux 25/01/2012, 15h29   #3
24gsm
Avatar de 24gsm
problemme resolu
âpre avoir tous essayer . jais décider a la fin ouvrière auto radio . élever le 93c46
faire une modification du dump . car jais trouver sur hex editor que le nombre d'erreur et 4.
jais tous remis a 0 et reprogrammer le 93c46 le monter . et oups code in . in front panel
all will be ok
thanks to all.
www.unlock-sl3.com
Discussion fermée
Compteur Audi A6 qui Affiche fuse mecanodiag Tableau de bord (Dashboard) 26 21/10/2013 11h41
Problème compteur s'affiche zero xsara Picasso taxi300 PSA Group Peugeot, Citroën 0 28/01/2011 19h36
tableau affiche 800000 prodiag Tableau de bord (Dashboard) 13 10/09/2009 16h24
Fuseau horaire GMT +1. Il est actuellement 00h58.
