Vieux 24/10/2016, 15h02   #1
television
Avatar de television
television has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond repute
Par défaut copie carte sd ktag
bonjour les amis
j arrive pas faire une copie de la carte sd ktag ,quand je veut la lire ,il m indique carte sd non formater,alors quelle fonctionne sur le ktag
avec vous une idée
cordialement
Dernière modification par television ; 24/10/2016 à 15h30.
television est déconnecté   Réponse avec citation
Vieux 24/10/2016, 16h03   #2
Med1387
Avatar de Med1387
Med1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant future
moi ca m'arrive souvent que ma sd fonctionne dans mon tel et pas sur le pc moi j'essaie plusieurs fois de la connecter sinon j'utilise un programme de disque dur comme MiniTool Partition mais il y en a plien d'autre ou essaie sur un autre pc
Med1387 est déconnecté   Réponse avec citation
Vieux 24/10/2016, 16h05   #3
abdel59100
Avatar de abdel59100
abdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond repute
salut televison
on peut pas faire une copie comme ça facilement l'ami
WinOls.Solutions Manuels
Stage1 Stage2 E85
https://abperformance.fr/
abdel59100 est déconnecté   Réponse avec citation
Vieux 24/10/2016, 16h24   #4
television
alors comment faire !!!
cdl
Vieux 24/10/2016, 17h24   #5
INVICTUS
Avatar de INVICTUS
Pouvoir de réputation: 96
salut il te faut les fichier originaux initial et changer ta carte sd
Vieux 24/10/2016, 17h38   #6
television
Envoyé par AS2KER Voir le message
je m explique ,j ai un ktag ne fonctionne pas ,et un autre fonctionne,quand je prend la carte sd du ktag qui fonctionne ,et que je l introduit dans l autre ...il fonctionne a nouveau donc sa vient de ma carte sd,mais impossible extraire le contenue de celle qui fonction ,pour aller la recopier dans l autre qui et defectueuse ,jesperre avoir ete trés claire !!!!!!!!!!!!! dans mon texte
en inverssant les carte sd les 2 interfaces fonctionne en ktag et transdata
cordialement
Dernière modification par television ; 24/10/2016 à 17h44.
Vieux 24/10/2016, 17h41   #7
INVICTUS
Avatar de INVICTUS
je tes dit ce qui faut faire .......................fichier +changement sd card ..................
Vieux 24/10/2016, 17h45   #8
television
salut AS2KER ,j ai plus ton tel car mon portable a lacher ,peut tu m apeler
Vieux 24/10/2016, 17h49   #9
kmtech
Avatar de kmtech
Pouvoir de réputation: 67
En fait c'est pas si compliqué... Utilise "HDD Raw Copy Tool" ça te fera une copie parfaite de ta carte sd sans aucun problème, pas besoin que la partition monte.
kmtech est déconnecté   Réponse avec citation
Vieux 24/10/2016, 17h56   #10
television
bonjour merci
au fait ta envoyer mon colis
cdl
Vieux 25/10/2016, 09h42   #11
television
Envoyé par kmtech Voir le message
merci kmtech sa fonctionne nickel
cordialement
Vieux 14/11/2016, 19h36   #12
allpatchi
Avatar de allpatchi
allpatchi is a splendid one to beholdallpatchi is a splendid one to beholdallpatchi is a splendid one to beholdallpatchi is a splendid one to beholdallpatchi is a splendid one to beholdallpatchi is a splendid one to beholdallpatchi is a splendid one to behold
bonsoir je voudrai savoir si tu as régler le problème je cherche les fichier de la carte sd
Un petit thank's fait toujours plaisir et ça ne mange pas de pain
allpatchi est déconnecté   Réponse avec citation
Vieux 15/11/2016, 06h05   #13
television
Envoyé par allpatchi Voir le message
bjr
oui j ai fait une copie d une autre carte sd et sa fonctionne
cdl
Comment faire une copie d'une carte clé pour une Renautl Megane? papenzzo Renault clip, DDT2000, Nissan consult 24 06/11/2016 23h51
Y'a t il une différence entre programmer une carte (clé) et faire une copie de carte? papenzzo Renault clip, DDT2000, Nissan consult 1 20/12/2015 09h36
copie cle twingo 2 ph 1 walteck programmation & synchronisation de clé 2 23/06/2015 23h32
copie integral ecu rosaire974 Fichiers d'origine, carto, dump, fullbackup 7 27/12/2014 14h50
Fuseau horaire GMT +1. Il est actuellement 18h42.
