| Section for english users English talking about cars, problems and solutions ... |
Pouvoir de réputation: 16 ![]() ![]() ![]() ![]() ![]() |
hi i have a bmw e 46 1999 320d wich i have this code i dont know what i could be i have only this error 47 synchronization of speed sensor do i have to turn the engine to timing points and reconect the cranckshaft sensor or what any idea ??????????
Pouvoir de réputation: 16 ![]() ![]() ![]() ![]() |
hello i didn't understand what is the problem exactly, the car doesn't start or just a simple fault?
otherwise the speed sensor is attached to the abs module |
hi,
you have a timing problem between speed sensor tea cranckshaft check whether your tour minute hand moves when you turn the starter if you have a cut sensor !!! do not forget thanks |
when i try to start the car the rpm mounts untill 0.3 it goes i think but would not start the car so :S
Did you touch to the pomp? If yes this fault means that the pomp is not "caler" , sorry I dont know this word in english but it s quite the same thing that when a timing belt is not in the good place between up and down part of the engine
i have sent it to auvegne electro diesel to calee(timing)i have 1 year guaranty i just want to know if that is or i found this on a web that it explains my problem so i will do this with diss if no luck then electro diesel
| Fiat 312 mp3 Black AUX2+ code error | kadi0209 | Autoradio et Navigateur GPS | 0 | 14/04/2015 21h56 |
| Repairing Toyota error code P1300/13 | Shadab | Toyota, Lexus | 2 | 01/11/2014 21h50 |
| write error xprog m hc08 start error | alexisraynaud | Immobilizer dumps/solutions | 5 | 12/08/2014 12h42 |
| Error fatal : Unknown error during init | djkikou | Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel | 7 | 06/02/2014 10h07 |
