Vieux 04/02/2015, 15h48   #1
djspike
Avatar de djspike
djspike is a name known to alldjspike is a name known to alldjspike is a name known to alldjspike is a name known to alldjspike is a name known to alldjspike is a name known to all
Par défaut pin code UCH senic megane
bonjour, quelqu'un peut me donner le code pin depuis ce dump?
c'est une megane senic de 1998 diesel
Type de fichier : bin senic uhc.bin (256 octets, 43 affichages)
djspike est déconnecté   Réponse avec citation
Vieux 04/02/2015, 16h08   #2
bbert90
Avatar de bbert90
Pouvoir de réputation: 23
bbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to behold
salut c est quoi comme uch
et comme eproom
ton dump a pas un problem ?
bbert90 est déconnecté   Réponse avec citation
The Following User Says Thank You to bbert90 For This Useful Post:
djspike (04/02/2015)
Vieux 04/02/2015, 16h32   #3
aza
Avatar de aza
aza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud of
salut djspike
+ de détails SVP , .....type de moteur...ECU...
salutations l'ami
aza est déconnecté   Réponse avec citation
The Following User Says Thank You to aza For This Useful Post:
Vieux 04/02/2015, 16h58   #4
djspike
Avatar de djspike
c'est un uch simens 7703297786J, j'ai lu la MCU qui se trouve a l’intérieur ( MCU68HC5B32 (0D60J))
Vieux 04/02/2015, 17h01   #5
djspike
Avatar de djspike
Envoyé par aza Voir le message
salut djspike
salutations l'ami
ECU = bosch 1plug
type de moteur = jaono5
Vieux 04/02/2015, 17h32   #6
hydrofrein
Avatar de hydrofrein
hydrofrein is a jewel in the roughhydrofrein is a jewel in the roughhydrofrein is a jewel in the rough
salut djskipe je trouve code 86156218 a confirmer poste résulta !
noublis pas Thanks !
hydrofrein est déconnecté   Réponse avec citation
The Following User Says Thank You to hydrofrein For This Useful Post:
Vieux 04/02/2015, 17h53   #7
S-keys
Avatar de S-keys
Pouvoir de réputation: 141
slt je confirme le code avec ecu tool pin 86156218
Vieux 28/02/2015, 17h25   #8
djspike
Avatar de djspike
quel transpondeur qui va avec ce UCH?
MAnuel de reparation laguna;megane II;senic II izouf Renault, Dacia, Nissan 4 09/10/2022 13h26
code radio renault senic extradiag Autoradio et Navigateur GPS 2 17/04/2014 21h59
supprimer anti demarrage megane senic 98 dti hadil Renault, Dacia, Nissan 12 05/07/2013 09h30
Megane senic dti 2001 stofa-25 Renault, Dacia, Nissan 6 06/01/2012 00h17
Fuseau horaire GMT +1. Il est actuellement 10h31.
