Vieux 03/09/2014, 19h15   #1
Khaleal
Avatar de Khaleal
Khaleal is an unknown quantity at this point
Par défaut SAGEM S3000 virging
Hi,
My car started having issues and it was diagnosed with a faulty ECU. Renault dealer wants 600GBP in order to change the ECU! The car is Renault Megane II 1.6 16v 2005 K4M760 Engine.
It was pretty easy to find cheap secondhand ECUs with same part number (Renault Engine ECU S3000 21584288-2A 8200321263 8200387138) on eBay.
But I'm aware it won't work with my car out of the box and it need to be decoded and set to virgin (self-programming) state.
I decided to try virging the secondhand ECU myself so it work with my car..
What equipment/software should I have? I searched the web and found some information about MPPS.. But anyway.. I'm a newbie.. Your advice is appreciated :)
I already own a Renault CAN CLIP capable of programming/reprogramming..
Khaleal est déconnecté   Réponse avec citation
The Following User Says Thank You to Khaleal For This Useful Post:
samb4064 (03/09/2014)
Vieux 03/09/2014, 21h55   #2
samb4064
Avatar de samb4064
Par défaut S3000
good evening
we need to get the eeprom from the old injection computer and put it in the new is all.
ps: you forgot to put an avatar?
The Following User Says Thank You to samb4064 For This Useful Post:
talal ssy (25/08/2026)
Vieux 03/09/2014, 21h59   #3
Khaleal
Avatar de Khaleal
Envoyé par samb4064 Voir le message
good evening
Thank you for your reply.
Which eeprom? Can you get a picture or instructions of how to find it? As I can see the board of the ECU has many chips..
Vieux 03/09/2014, 22h05   #4
Khaleal
Avatar de Khaleal
This is the board of the ECU
BTW, I've read somewhere that the data from the original ECU can be read (Using eeprom programmer) and then transferred to the new - secondhand - ECU without the need to desolder and resolder the chips.. I'd be glade if you can provide more information about this.
Vieux 03/09/2014, 22h30   #5
samb4064
Avatar de samb4064
Par défaut s3000
eeprom 95160 is below the alluminum cover rear of the computer fixed by 4 screws very easy to change
Khaleal (03/09/2014)
Vieux 03/09/2014, 22h36   #6
samb4064
Avatar de samb4064
Par défaut s3000
hello
the other side has opposed eeprom 8 fingers 95160.
The Following 2 Users Say Thank You to samb4064 For This Useful Post:
Khaleal (03/09/2014), talal ssy (25/08/2026)
Vieux 03/09/2014, 22h39   #7
Khaleal
Avatar de Khaleal
Is there any side effects of moving my current 95160 chip to the secondhand ECU and running the car with it?
Is there any way of moving data from the current ECU to the new secondhand one without the need to desolder and resolder it again? If yes, what equipment should I need? I would be glade if you provide more information :)
Vieux 03/09/2014, 23h22   #8
samb4064
Avatar de samb4064
Par défaut s3000
clip this possible with 8-Pin SOIC and could corrupt the file unsolders Reseal no problem I have already done several times s3000 no trasfère s only given the immobilizer and vf.
Vieux 03/09/2014, 23h31   #9
Khaleal
Avatar de Khaleal
I didn't understand correctly.. Did you mean that the soldering process is safer than eeprom programming? I'm trying to use the programming method so I don't make damage to my original eeprom chip while desoldering and resoldering..
BTW, What do you think about CarProg kit? Is it suitable for the mission I'm trying to accomplish? It has a SOIC8 Clip Cable..
http://www.ebay.co.uk/itm/Carprog-V6...item3ce1b1502c
If you have any suggestions about different programming kit I'd appreciate that..
Vieux 04/09/2014, 11h52   #10
samb4064
Avatar de samb4064
Par défaut s3000
Hello there
if you dessode your eeprom you will have no problem on your original file it works inchaallah a100%
and the CARPROG it is set apart it's a Chinese clone
I work with original
http://www.codecard.lt/carprog/carpr.../prod_344.html
Khaleal (06/09/2014), talal ssy (25/08/2026)
sagem s3000 maniacx65 Immobilizer dumps/solutions 0 14/01/2012 00h39
Sagem S3000 medcapot Renault, Dacia, Nissan 8 27/07/2011 16h39
Sagem S3000 Mezz Immobilizer dumps/solutions 2 16/02/2011 08h17
Sagem S3000 dump unlocked Immobilizer dumps/solutions 6 19/03/2009 17h53
Fuseau horaire GMT +1. Il est actuellement 15h27.
