Vieux 13/01/2018, 00h49   #526
lioneldu77
Avatar de lioneldu77
lioneldu77 has a spectacular aura aboutlioneldu77 has a spectacular aura about
normalement oui.sur eprom ecu
lioneldu77 est déconnecté   Réponse avec citation
The Following User Says Thank You to lioneldu77 For This Useful Post:
prinzo57 (13/01/2018)
Vieux 13/01/2018, 20h44   #527
repcles
Avatar de repcles
repcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to beholdrepcles is a splendid one to behold
slt a tous , opel corsa c an 2001, lecture pin ok apprentissage des cles ok.
The Following 6 Users Say Thank You to repcles For This Useful Post:
chipshop (14/01/2018), ggvaniou (16/01/2018), Macan (24/09/2021), mbn30 (13/01/2018), prinzo57 (13/01/2018), REDZONE31 (17/01/2018)
Vieux 14/01/2018, 01h24   #528
DIAGSYSTEM25
Avatar de DIAGSYSTEM25
Pouvoir de réputation: 44
Bsi jc lecture pin ok prog pin ok prog vin ok
Prog km ok sur table tout sa
The Following 3 Users Say Thank You to DIAGSYSTEM25 For This Useful Post:
klif26 (14/01/2018), mbn30 (14/01/2018), REDZONE31 (17/01/2018)
Vieux 16/01/2018, 10h18   #529
kdo75
Avatar de kdo75
kdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud of
cherche un lien pour un bon FVDI 2014 si quelqu un a sa
kdo75 est déconnecté   Réponse avec citation
The Following User Says Thank You to kdo75 For This Useful Post:
marcusbilly (16/01/2018)
Vieux 16/01/2018, 22h01   #530
klif26
Avatar de klif26
klif26 is a glorious beacon of lightklif26 is a glorious beacon of lightklif26 is a glorious beacon of lightklif26 is a glorious beacon of lightklif26 is a glorious beacon of lightklif26 is a glorious beacon of light
Salut a tous
J ai un problème avec mon fvdi je me suis procurer un bsi JC fait le branchement suivant le schéma de selim merci a lui et quand je lance lecture bsi ou pin le temps s écoule et a la fin il me met
Impossible exécuter la commande écriture flash
Merci d avance
---------- Post added at 22h01 ---------- Previous post was at 22h00 ----------
Salut a tous
Merci d avance
klif26 est déconnecté   Réponse avec citation
Vieux 17/01/2018, 10h12   #531
klif26
Avatar de klif26
Salut a tous
Personne a rencontrer cette erreur
En identification pas de problème mais en lecture rien
Merci d avance
Vieux 20/01/2018, 19h57   #532
raed83300
Avatar de raed83300
Envoyé par klif26 Voir le message
Salut a tous
Merci d avance
Bsi jc evo?????
Envoyé de mon SM-G920F en utilisant Tapatalk
The Following User Says Thank You to raed83300 For This Useful Post:
klif26 (20/01/2018)
Vieux 20/01/2018, 20h46   #533
Kennfeld
Avatar de Kennfeld
Envoyé par everson29 Voir le message
Je viens de faire un off edc16u1 touran tdi 105 de 2004
Ca n'est pas passé
Pour info Mon instrument est hs
Ca devrait fonctionner ?
avec mon vrai ça n'avait pas fonctionné non plus
Winols BSL BDM IOT Officiel OLS505 disponible > 01/04/2021 en monoposte moins cher !
Vieux 20/01/2018, 23h18   #534
klif26
Avatar de klif26
Salut a tous
merci raed
je te joint la photo du bsi que j ai essayer de lire
si c est un evo étonnant que mon fvdi n a pas planter
Type de fichier : jpg 20180120_231235.jpg (90,9 Ko, 65 affichages)
The Following 2 Users Say Thank You to klif26 For This Useful Post:
prinzo57 (21/01/2018), raed83300 (27/01/2018)
Vieux 27/01/2018, 23h18   #535
raed83300
Avatar de raed83300
Salut ya til une personne qui a adapter un calculateur de boite Mercedes c180 de 2014 ref sur pj
Vieux 27/01/2018, 23h45   #536
pouettedu76
Avatar de pouettedu76
Pouvoir de réputation: 77
Salut a tous
merci raed
Salut Klif26 si tu la lus avec fvdi c'est du 1000% qu'il ta planter la flash
Salut Read83300 non je ne l'ai pas fait mes franchement fait attention comme meme si c'est juste pour tester vas y si c'est celle d'un client ou de quelqu'un d'autre je ne tenterais meme pas comme sa pas de blocage bon courage comme meme si tu tente le coup en esperent que sa passe croise les doigts lol @+
The Following 2 Users Say Thank You to pouettedu76 For This Useful Post:
klif26 (28/01/2018), raed83300 (27/01/2018)
Vieux 27/01/2018, 23h48   #537
raed83300
Avatar de raed83300
C'est un neuf encore vierge et la voiture ne demarre pas je pensé récupérer le codage de l'ancienne pour adapter la nouvelle
The Following 3 Users Say Thank You to raed83300 For This Useful Post:
klif26 (28/01/2018), pouettedu76 (27/01/2018), tony60 (27/01/2018)
Vieux 28/01/2018, 01h24   #538
jah83
Avatar de jah83
Pouvoir de réputation: 245
Tu n as pas le star ? Encore que je suis même pas sur que ce soit pas du online
The Following 3 Users Say Thank You to jah83 For This Useful Post:
klif26 (28/01/2018), pouettedu76 (28/01/2018), raed83300 (28/01/2018)
Vieux 21/02/2018, 16h24   #539
prinzo57
Avatar de prinzo57
Pouvoir de réputation: 43
slt a tous
qui a réussi a réparé l'erreur SBC mercedes w211 j'ai pas l'ongle qui est prévue pour le faire dans la partie spéciale fonction de fvdi 2014.
Vieux 21/02/2018, 21h04   #540
REDZONE31
Avatar de REDZONE31
Pouvoir de réputation: 82
Envoyé par prinzo57 Voir le message
slt a tous
slt prinzo j'ai déjà effectuer cette manipe mais pas avec fvdi j'ai utilisé une autre interface et 100% WORK
The Following 3 Users Say Thank You to REDZONE31 For This Useful Post:
chipshop (22/02/2018), klif26 (21/02/2018), prinzo57 (21/02/2018)
Qu'avez vous reussis a faire avec carprog ? qu'avez vous pas reussis a faire avec ? pouettedu76 Transponder, code pin 36 29/04/2022 20h32
pensez vous avec un fvdi de chez fly en fulle je puisse faire de la programmation mustauto programmation & synchronisation de clé 30 31/12/2015 18h38
Faire clé série 1 qui n'a plus de clé avec FVDI ? r1lef Outil de programmation 12 09/12/2014 22h29
si vous avez le temps ... aide immo off AZICO Immobilizer dumps/solutions 2 08/09/2014 21h05
Fuseau horaire GMT +1. Il est actuellement 03h04.
