Vieux 30/11/2016, 21h45   #1
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut Lexia & PP2000 updates (Up-to DiagBox v8.37)
The software provided and the procedures proposed are intended for personal, educational and experimental use to install DiagBox 8.xx related updates. I hold no responsibility for any illegal or improper usage. Carry out this procedure at your own risk.
I present 2 compilations "APP_Update_817-837.EXE" and "APP_Update_835-837.EXE" (links in the attachment). Those executables are intended to update Lexia and PP2000 from version 8.17+ or 8.35 respectively, to the latest 8.37 and will bring Lexia v500.74 and PP2000 v600.79 to latest fixes or support level.
APP_Update_817-837.EXE update should be attempted if you have a working DiagBox v8.17 / v7.81 installation or higher, or if you have a working "APP-835.7z" implementation.
APP_Update_835-837.EXE update should be attempted if you have a working "APP-835.7z" implementation.
Procedure:
1- Ensure you have a backup copy of the file "C:\AWRoot\bin\fi\APPDIAG.SYS" before you start.
2- Download and execute the appropriate file for your own setup. The process will copy all necessary files to the updt folder, it will then automatically kill all associated processes to enable overwriting without conflicts.
3- Run DiagBox to start the update process and wait until DiagBox is operational. Close DiagBox and restart your computer to ensure all processes are running.
Done..! you may run DiagBox as usual..
Have fun!
Lexia language is set to English and PP2000 to french, if you wish to change them, edit the DICO.TXT file in the EXE folders of LEXIA or OUTILREP (PP2000) and replace "GB" with "FR" or vise versa.
P.S. DiagBox has been running on Firmware 4.3.4 since 7.66/8.02.
Regards, Simple.
Type de fichier : txt APP-Update_817+835-817.txt (1,3 Ko, 416 affichages)
Simple est déconnecté   Réponse avec citation
The Following 12 Users Say Thank You to Simple For This Useful Post:
AKDAN (14/01/2018), autodiagauto (29/11/2018), bzkmatrix (02/03/2019), ElTurco (29/11/2018), JOE (07/12/2016), kevin22 (11/08/2017), meraakk (08/01/2022), PRODIAG75 (15/01/2022), prt93 (28/12/2019), rickymix (16/09/2017), Roturbo (03/06/2018), supernaturel.sportman (06/12/2017)
Vieux 01/12/2016, 22h29   #2
maitresox
Avatar de maitresox
Pouvoir de réputation: 69
maitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond repute
Si je comprends bien, vous ne mettez à jour que PP2000 et LEXIA ?
Pour infos les Maj de 8.17 vers 8.36 font 1,35 Go sur un disque dur soit 373 Mo bien comprimée.
Quelqu'un peux t-il poster une image de son diagbox 8.37 ? Vous n'avez pas la nouvelle interface de diagbox ?
Maitresox
maitresox est déconnecté   Réponse avec citation
The Following User Says Thank You to maitresox For This Useful Post:
JOE (07/12/2016)
Vieux 02/12/2016, 00h17   #3
Simple
Avatar de Simple
Hi maitresox,
First, I am sure I can talk on behalf of many on this forum when I say your contribution is welcome, and I am sure that people would like see more, especially new DiagBox releases.
You are correct about the huge size of the original update, but much of it serves the changes to the new interface and fixes integration of DiagBox with both Lexia and PP2000, not much to fix the tools themselves. You are also aware that Lexia and PP2000 engines are in the APP folder, this is reflected by the version number when you start the tool.
I don't know who is in the Auto business and who is a casual user (like me) in this forum. I am not claiming this is an update for all DiagBox, and I don't know if it will fix peoples' issues, but I offered what I can contribute in good will, hoping it will benefit someone somewhere.
My interest in this area comes from owning a Citroen C8, I bought the VCI in October 2014 to control costs and I only use it 3 or 4 times a year..
Once again, I do this for love, not for living..
Simple.
Vieux 02/12/2016, 19h19   #4
maitresox
Avatar de maitresox
Salut Simple,
Bien sur, ce que tu fais est déjà appréciable.
Je n'ai pas le temps de retravailler sur les Maj après 8.17
Lorsque j'aurai du temps, j'essaierai de refaire les maj à partir de 8.17 sur ma version 8.02 All ready patched. Je ne peux rien promettre.
Vieux 02/12/2016, 19h30   #5
Simple
Avatar de Simple
Hi maitresox,
Thank you, and I don't need to tell you that the guys in this forum love you and appreciate your work..
Good luck, Simple.
The Following User Says Thank You to Simple For This Useful Post:
Vieux 03/12/2016, 13h13   #6
DIAGAUTO33
Avatar de DIAGAUTO33
DIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant future
Salut les gars,
Je confirme simple, ton update fonctionne très bien. Lexia et pp2000 sont à jour du coup.
Plus qu'à trouver pour diagbox...
Envoyé de mon ASUS_Z00AD en utilisant Tapatalk
DIAGAUTO33 est déconnecté   Réponse avec citation
Vieux 03/12/2016, 18h48   #7
fedge
Avatar de fedge
Salut.
Il y a quelque chose qui m' échappe .Il y aurait encore des mises a jour pour lexia et pp2000??Quel est l' intérêt puisque ils sont remplacés, depuis quelques années par diagbox.Je dois passer a coté de quelque chose.
Vieux 03/12/2016, 19h23   #8
adiago
Avatar de adiago
Pouvoir de réputation: 35
Envoyé par fedge Voir le message
Salut.
je confirme à chaque mise à jour diagbox,des corrections sont effectuées pour PP2000 et lexia3 .la 307 phase 1 par exemple passe toujours par PP2000 dans diagbox .
Vieux 04/12/2016, 09h37   #9
maitresox
Avatar de maitresox
Effectivement, il y a encore des correctifs sur les anciennes générations de véhicules.
Par exemple, j'ai vu dans la 8.37 une correction d'intitulé d'un défaut sur sid 801 de 2001.
Mais il y a quelques interactions entre diagbox et LEXIA/PP2000.
The Following 2 Users Say Thank You to maitresox For This Useful Post:
adiago (04/12/2016), DIAGAUTO33 (04/12/2016)
Vieux 04/12/2016, 10h09   #10
adiago
Avatar de adiago
Il y avait bien un problème avec la v8.36 voir sur le correctif v8.37:
http://public.servicebox.peugeot.com..._FR/index.html
Vieux 04/12/2016, 14h33   #11
maitresox
Avatar de maitresox
Ils font des correctifs des correctifs !
Vieux 04/12/2016, 15h55   #12
Simple
Avatar de Simple
Update 8.36 is 90MB, and 8.37 is 65MB and the APP part is identical in both releases. However, it is listed on the PSA sites!! But if you are on version 8.31 (for example) and request an update, 8.36 is no longer listed!!!! The list will have 8.32, 8.33, 8.35, 8.37… update 8.36 is no longer available for download since last week.
The question here, if 8.37 is a fix for 8.36, then why is 8.36 is pulled out? It should still be available for download then the fix is applied, and if 8.37 is a replacement for 8.36, then it obviously does not have all the new functionality and fixes that 8.36 included.
Hence, I believe a new release (8.38 or something) should be available soon to implement the rest of the new functionality and fixes… The weirdest thing is the disconnect between updates availability and the listing on PSA sites !!??..
Vieux 11/12/2016, 09h28   #13
maitresox
Avatar de maitresox
Mise à jour 8.38 Dispo
Par contre je pense que l'on va être obligé d'utiliser WIN 7 32 bits car sur XP les MAJ ne passent plus !
adiago (11/12/2016), pouettedu76 (11/12/2016)
Vieux 11/12/2016, 19h37   #14
mirek
Avatar de mirek
mirek is an unknown quantity at this point
hello please help
-diagbox 8.17 instaled
-install diag update 8.17-8.37 - install ok
-run diagbox info version 8.17
thanks
mirek est déconnecté   Réponse avec citation
Vieux 11/12/2016, 20h57   #15
Simple
Avatar de Simple
@mirek,
I am not sure I understand your message, it seems you have installed and updated successfully, but your issue is that DiagBox is reporting 8.17, instead of 8.37!!
If this is your issue then it is OK, this is the way it should work.
Please go through this:
http://www.tlemcen-electronic.com/fo...ad.php?t=60970
Lexia & PP2000 (from DiagBox 8.35) Simple LEXIA, PP2000, DiagBox 63 25/11/2018 22h25
Quoi faire avec le xs evolution sous diagbox , pp2000, lexia ishams2002 LEXIA, PP2000, DiagBox 7 14/11/2014 19h56
cherche logiciels diagbox, lexia et pp2000 originale beka1975 LEXIA, PP2000, DiagBox 1 20/11/2013 23h06
Peugeot/Citroen DIAGBOX PP2000 LEXIA bloker LEXIA, PP2000, DiagBox 7 30/10/2013 07h27
Fuseau horaire GMT +1. Il est actuellement 10h51.
