Vieux 03/02/2016, 14h52   #1
3atman
Avatar de 3atman
3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of
Par défaut Capteur, pression de suralimentation pour MERCEDES-BENZ Vito
OBD Code P0105refers to
The MAP (Manifold Absolute Pressure) sensor is part of the fuel management system. It reacts to changes in engine manifold pressure. The PCM (Powertrain Control Module) monitors the MAP sensor continually to properly run the engine. Changes in engine load require changes in the amount of fuel injected, and timing of the ignition system, etc. An engine under load has more manifold pressure(or less vacuum) than an engine that is coasting. As the load changes, the MAP sensor voltage signal to the PCM changes accordingly. To check the MAP sensor operation, though, the PCM watches other sensors to verify that the MAP sensor is working properly. For example, the PCM compares the TPS (Throttle Position Sensor) signal to the MAP signal to verify the MAP signal isn't "sticking". If the PCM doesn't see a MAP sensor change immediately follow a change in the throttle pedal sensor, it knows there is a problem with the MAP sensor and sets P0105. Or, if the PCM notices that the TPS indicates the engine is under load, but the MAP signal indicates that the engine is "coasting" it, again, knows there is a problem with the MAP sensor or TPS and sets P0105.
Type de fichier : jpg f0261230189.jpg (15,1 Ko, 6 affichages)
Type de fichier : jpg 0905350.jpg (20,4 Ko, 4 affichages)
3atman est déconnecté   Réponse avec citation
Vieux 03/02/2016, 16h59   #2
3atman
Avatar de 3atman
chof hada ok
Type de fichier : jpg $(KGrHqZ,!lgFH57O61I5BSG)cNl(1g--60_35.JPG (10,1 Ko, 7 affichages)
Vieux 03/02/2016, 20h39   #3
kalachama
Avatar de kalachama
kalachama is a jewel in the roughkalachama is a jewel in the roughkalachama is a jewel in the roughkalachama is a jewel in the rough
Envoyé par 3atman Voir le message
chof hada ok
hadi c'est une electrovanne de regulation de turbo ou vanne egr
tout qu'il reste bien propable,il y'a que la verite
kalachama est déconnecté   Réponse avec citation
Vieux 03/02/2016, 20h41   #4
kalachama
Avatar de kalachama
ou hada c'est le capteur de suralimentation d'air qui va ver le turbo
Vieux 03/02/2016, 22h34   #5
adjee
Avatar de adjee
adjee is on a distinguished road
merci mais moi le problème c'est que le vito il a un turbo électrique avec géométrie variable..... le problème c'est que le vito il perd la puissance et quand je mets le diag il me mets erreur P0105 capteur de pression erreur de plausibilité permanent
adjee est déconnecté   Réponse avec citation
Probleme pression suralimentation non atteinte (resolu) doud77 VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 105 01/12/2015 08h25
schema electrovanne pression suralimentation audi ake nas33 VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 11 18/08/2015 14h57
pression suralimentation clio 1.5dci 65cv didodaka Renault, Dacia, Nissan 3 17/03/2014 20h37
demande de immo off pour Mercedes-Benz g-class 4x4 v6 2.9 l turbo diesel mohcin2 Immobilizer dumps/solutions 0 27/04/2013 07h58
Fuseau horaire GMT +1. Il est actuellement 14h33.
