Vieux 20/08/2020, 15h57   #1
MOUS25
Avatar de MOUS25
MOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud of
Par défaut programmeur usb CH341A
Salut Salam
Y a t il quelqu un qui a le logiciel qui fait ce programmeur l idéal avec driver je l ai reçu sans cd
Merci de vos retours...
MOUS25 est déconnecté   Réponse avec citation
Vieux 20/08/2020, 16h13   #2
zebulons
Avatar de zebulons
zebulons is a glorious beacon of lightzebulons is a glorious beacon of lightzebulons is a glorious beacon of lightzebulons is a glorious beacon of lightzebulons is a glorious beacon of lightzebulons is a glorious beacon of light
https://www.kazmielecom.com/2018/07/27/ch341a-usb-mini-programmer-software-free-download.html
---------- Post added at 16h13 ---------- Previous post was at 16h07 ----------
Envoyé par zebulons Voir le message
Ta plusieurs version et les drivers aussi.normalement les drivers il s installe en même temps que le programme ta pas besoin de les télécharger séparément .
zebulons est déconnecté   Réponse avec citation
The Following 6 Users Say Thank You to zebulons For This Useful Post:
autodiagauto (12/07/2021), benslimen1972 (13/09/2020), ElTurco (20/08/2020), marikette (18/06/2022), MOUS25 (20/08/2020), rapou30 (19/10/2020)
Vieux 20/08/2020, 16h17   #3
MOUS25
Avatar de MOUS25
Merci je vais tester ça
Vieux 20/08/2020, 17h53   #4
ElTurco
Avatar de ElTurco
ElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond repute
Selem frère Mous25
J'ai galéré pour effectuer une lecture écriture pour Eeprom (25xxx ou 95xxx) donc pour t'éviter cette galère voici quelques astuces.
Le programmeur CH341A alimente l'eeprom à programmer en 3.3V de base ce qui empêche la lecture ou écriture sur les séries d'eeprom 25xx et 95xx qui on besoin de 5v pour être ok.
Il te suffit de rajouter un cavalier sur le 5V et 3.3V du programmeur ainsi tu pourras effectuer lecture/écriture sans problème et pour stabiliser les 5V tu pourras aussi soudé un condo 1000uf 16V entre l'entrée 5V et GND de l'entrée USB.
Good job fréro.
"Ne pas faire aux autres ce que l'on ne veux pas que les autres te face"
ElTurco est déconnecté   Réponse avec citation
The Following 8 Users Say Thank You to ElTurco For This Useful Post:
autodiagauto (12/07/2021), fenril68 (20/08/2020), jah83 (20/10/2020), Kup14 (06/09/2024), MaghrebGenius (21/08/2020), MOUS25 (20/08/2020), rapou30 (19/10/2020), soustourou (20/08/2020)
Vieux 20/08/2020, 18h03   #5
MOUS25
Avatar de MOUS25
Merci de l info ,fallait il plutôt dévier le shunt?
Vieux 20/08/2020, 18h13   #6
djamel30
Avatar de djamel30
djamel30 will become famous soon enough
voila logiciel+driver
Type de fichier : rar ch431program.rar (1,26 Mo, 164 affichages)
djamel30 est déconnecté   Réponse avec citation
The Following 10 Users Say Thank You to djamel30 For This Useful Post:
adlen22 (19/10/2021), ElTurco (21/08/2020), Jonathanv8 (29/11/2025), Kup14 (06/09/2024), marikette (18/06/2022), MOUS25 (20/08/2020), rapou30 (19/10/2020), Sarroura (27/10/2024), tourtcheuX (21/05/2025), Ycnandroid (06/06/2021)
Vieux 20/08/2020, 22h05   #7
MOUS25
Avatar de MOUS25
Salut les amis je l ai installè ,il est reconnu et fonctionnel...
The Following 2 Users Say Thank You to MOUS25 For This Useful Post:
ElTurco (21/08/2020), rapou30 (19/10/2020)
Vieux 19/10/2020, 23h39   #8
rapou30
Avatar de rapou30
rapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud of
Bonsoir , une petite vidéo explicative.
https://www.youtube.com/watch?v=hPKckby54uA
Le piment c'est comme l'autoroute , ca se paye a la sortie
rapou30 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to rapou30 For This Useful Post:
autodiagauto (12/07/2021), tourtcheuX (23/05/2025)
Vieux 06/06/2021, 23h27   #9
Ycnandroid
Avatar de Ycnandroid
Ycnandroid is an unknown quantity at this point
Envoyé par ElTurco Voir le message
Selem frère Mous25
Good job fréro.
Merci pour l'asstuce mon frère,j'ai pas comprender que signifie '' cavalier'' une shunte ???
Ycnandroid est déconnecté   Réponse avec citation
The Following User Says Thank You to Ycnandroid For This Useful Post:
mcmomo (12/07/2021)
Vieux 12/07/2021, 11h23   #10
fuzz
Avatar de fuzz
Pouvoir de réputation: 7
fuzz has a spectacular aura aboutfuzz has a spectacular aura about
On peut utiliser Asprogrammer avec le CH341a.
Beaucoup plus de puce peut etre lis.
Version que j'ai 2.1.0.13
fuzz est déconnecté   Réponse avec citation
The Following User Says Thank You to fuzz For This Useful Post:
Vieux 12/07/2021, 18h03   #11
fildefer85
Avatar de fildefer85
fildefer85 will become famous soon enoughfildefer85 will become famous soon enough
Envoyé par fuzz Voir le message
Tu as beaucoup de retard, la version Asprogrammer 2.1.0.13 est a éviter car elle comporte de nombreux bugs.
Il faut utiliser Neoprogrammer (2.2.0.8) du meme auteur TTAV134.
Voir le post > ici < pour le téléchargement.
fildefer85 est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to fildefer85 For This Useful Post:
adlen22 (19/10/2021), fuzz (13/07/2021), rapou30 (18/02/2022)
Vieux 14/02/2022, 17h14   #12
rapou30
Avatar de rapou30
Bonjour , je remonte un peu le sujet pour ceux qui veulent lire une E2P 93XXX .
Avec une petite modif ca fonctionne tres bien. Je viens de tester. Comme ce n'est pas de moi je vous poste le lien de la vidéo de l'auteur. Merci a lui
https://www.youtube.com/watch?v=MpQW...B3nicaVargasTV
Bollide (12/05/2023), zebulons (14/02/2022)
Vieux 18/02/2022, 09h33   #13
Meteo07
Avatar de Meteo07
Pouvoir de réputation: 5
Meteo07 is on a distinguished road
Ce programmateur avec neoprogrammer, le mod c'est une tuerie, les bsi se clonent au poil ;) je n'ai fait qu'un johnson pour l"heure avec ce programmateur et svci pour la flash: impeccable.
Meteo07 est déconnecté   Réponse avec citation
The Following User Says Thank You to Meteo07 For This Useful Post:
Vieux 23/03/2022, 09h46   #14
Meteo07
Avatar de Meteo07
j'ai cloné un sid801a hier donc eeprom 95c56 avec le mod et neoprogrammer, immo off au poil !
pour le prix ca vaut vraiment le detour, je recommande ce programmeur !
The Following 2 Users Say Thank You to Meteo07 For This Useful Post:
flowave (12/10/2024), rapou30 (24/03/2022)
Vieux 12/05/2023, 20h53   #15
Bollide
Avatar de Bollide
Bollide is a glorious beacon of lightBollide is a glorious beacon of lightBollide is a glorious beacon of lightBollide is a glorious beacon of lightBollide is a glorious beacon of lightBollide is a glorious beacon of light
Envoyé par rapou30 Voir le message
Salut, MERCI pour l'info et le partage MERCI ça a fonctionné très bien pour moi
Programmeur ipa MOUS25 Programmateur de composant (flasher) 2 06/08/2020 18h31
SBB programmeur de clé v.33 vortex programmation & synchronisation de clé 2 10/10/2015 13h53
Programmeur de clé Sbb dagomnet programmation & synchronisation de clé 2 31/03/2015 15h12
programmeur GQ-4X karera 1 Vente, Achat, Echange 2 25/02/2015 09h22
Programmeur de cle psa francois Outil de programmation 26 25/11/2011 13h50
Fuseau horaire GMT +1. Il est actuellement 01h44.
