Vieux 11/02/2020, 19h03   #1
Nicolas13007
Avatar de Nicolas13007
Nicolas13007 is a name known to allNicolas13007 is a name known to allNicolas13007 is a name known to allNicolas13007 is a name known to allNicolas13007 is a name known to allNicolas13007 is a name known to all
Par défaut Tutoriel immo off Ducato,Boxer,Jumper sans voyant sans U1600 thanks & reputation
Bonjour les amis voila un tutoriel immo off jumper ,boxer , Ducato tous moteurs , tous calculateurs
de 2000 a 2006 a faire soi meme avec Hexcomp et avec dtc 1600 off et sans voyant moteur allume ,,total immo
eeprom+flash avec calculation de checksum a la fin
pass apres merci et réputation
Hello friends today i made for you a tutorial immo off Jumper , Boxer ,Ducato EDC 15C7,, 2.0 hdi, 2.2hdi,2.8hdi ALL TYPES from 2000 to 2006 all ecu numbers, DTC 1600 off also
Thanks and reputation friends
Type de fichier : zip edc 15c7 (3).zip (167 octets, 2 affichages)
Dernière modification par Nicolas13007 ; 04/06/2021 à 08h06.
Nicolas13007 est déconnecté   Réponse avec citation
The Following 23 Users Say Thank You to Nicolas13007 For This Useful Post:
Aflou-diag (11/02/2020), autodiagauto (11/02/2020), aza (12/02/2020), boul27 (14/02/2020), Boutbout (11/02/2020), citrus (12/02/2020), dsidxmsm (14/10/2022), fedge (12/02/2020), foulques (11/02/2020), k.emra (12/02/2020), momoh-93 (11/02/2020), Pelican (12/02/2020), pp08 (12/02/2020), reda75 (12/02/2020), redou28 (11/02/2020), repcles (12/02/2020), Samir44 (12/02/2020), techtronic1 (12/02/2020), VISVAL (11/02/2020), Y.B tec (11/02/2020), yann3 (11/02/2020), YUMBO (11/02/2020), zenata (11/02/2020)
Vieux 11/02/2020, 22h48   #2
Pelican
Avatar de Pelican
dtc off et voyant moteur éteint ?
Merci pour le partage
Vieux 11/02/2020, 23h56   #3
Aflou-diag
Avatar de Aflou-diag
Aflou-diag is a splendid one to beholdAflou-diag is a splendid one to beholdAflou-diag is a splendid one to beholdAflou-diag is a splendid one to beholdAflou-diag is a splendid one to beholdAflou-diag is a splendid one to beholdAflou-diag is a splendid one to behold
SALUT
Merci pour ce partage l'ami
MERCI T-E
Aflou-diag est déconnecté   Réponse avec citation
Cherche quelqu'un pour faire faisceau sur table fiat ducato jumper boxer tony60 Café du forum 8 30/05/2024 00h41
Free pour tous membres 15airbag softwares+virgin no pass juste merci et reputation Nicolas13007 Airbag 0 31/01/2020 16h22
Recherche adaptateur psa boxer ou jumper ctophe33 Vente, Achat, Echange 0 14/08/2017 12h02
PSA EDC15C7 (2plugs) Boxer, Jumper mecanodiag93 Programmateur de composant (flasher) 20 20/06/2016 18h36
Code pin BSI Jumper ou Boxer Magnetti Marelli matt1781 Transponder, code pin 11 01/11/2015 18h50
Fuseau horaire GMT +1. Il est actuellement 15h28.
