Vieux 02/01/2020, 22h14   #1
hugopinho
Avatar de hugopinho
hugopinho is on a distinguished road
Par défaut Renault Master 0 281 011 940 immo off
Hi friends
I have a Renault Master, 2.5 dci, 100 cv, 2003
I need immo off for the ECU please
BOSCH 0 281 011 940
95P08 eeprom
Best Regards
hugopinho
Type de fichier : rar orig.rar (355 octets, 23 affichages)
hugopinho est déconnecté   Réponse avec citation
Vieux 02/01/2020, 22h16   #2
Pouvoir de réputation: 279
Slt l ami voilà ce qui faut faire
https://youtu.be/pNqBTzp7MVc
hugopinho (05/01/2020), prinzo57 (03/01/2020), progdebutant (03/01/2020)
Vieux 05/01/2020, 23h23   #3
hugopinho
Avatar de hugopinho
Hi
I've already seen the tutorial https://youtu.be/pNqBTzp7MVc and understood all the steps. my question is if the switch is needed and if it has to be turned on every time the car is started.
it is not enough to cut the plug
anyone can help me
Regards
hugopinho
The Following User Says Thank You to hugopinho For This Useful Post:
duroi (10/03/2024)
Vieux 05/01/2020, 23h38   #4
You can do the off on the table and shunt the can on the uch, you don't need the button every time.
Musta0704 (05/01/2020), prinzo57 (05/01/2020)
Vieux 06/01/2020, 00h01   #5
cristi_ony
Avatar de cristi_ony
cristi_ony is an unknown quantity at this point
you r ecu is edc 15c3?
cristi_ony est déconnecté   Réponse avec citation
Vieux 06/01/2020, 00h09   #6
techtronic1
Avatar de techtronic1
Envoyé par cristi_ony Voir le message
Her ecu is edc15c13
akasa67 (06/01/2020)
Vieux 06/01/2020, 00h15   #7
cristi_ony
The problem on these is usually the key read 93c46 in immo unit and use gambit or zed bull to produce transponder from dump
Vieux 06/01/2020, 00h17   #8
Slt tu et a l ouest le calculateur et bien un edc15c13 et non edc15c3 il a un uch et non un immobox donc rien à voir cordialement.
Vieux 06/01/2020, 00h25   #9
cristi_ony
Immo off on this renault master was done
I made 95P08 virgin and solder renault emulator inside the ecu,cut the immo line wire conector A (the small one) pin G2, put the ecu back on the car, ignition on for 30sec.,then off for 30seconds (repead this 5 times),then start the car
---------- Post added at 11:25 PM ---------- Previous post was at 11:18 PM ----------
read 93c66 memory from uch and use RenaultPinExtractor to find the code and rewrite the keys
Vieux 06/01/2020, 00h34   #10
cristi_ony
virgin file and photo emulator
Type de fichier : zip Renault master 2.5dci 95P08 Virgin.zip (568,4 Ko, 62 affichages)
Vieux 06/01/2020, 00h54   #11
Tu lui a mise une couverture sur l émulateur lol non sa n'a rien à voir lui et en can....
Vieux 10/03/2024, 05h36   #12
xboss94
Avatar de xboss94
xboss94 is on a distinguished road
Bonjour j'ai exactement le même soucis sur un master 2.5 EDC15C13 la solution avec émulateur by JULIE on doit systématiquement toucher les câbles avant démarrage ou seulement la première fois pour l'apprentissage du vin dans l'émulateur ? Aucune idée de comment sa fonctionne leur systéme de devoir couper la linhe CAN L et CAN H
xboss94 est déconnecté   Réponse avec citation
Vieux 10/03/2024, 11h32   #13
yann3
Avatar de yann3
Pouvoir de réputation: 76
il faut mettre un switch sur canL
Ca arrive regulierement de falloir couper le canpour demarrer
http://www.armoreprog.fr
Vieux 10/03/2024, 13h42   #14
bassh
Avatar de bassh
bassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud ofbassh has much to be proud of
Interrupteur obligatoire oui. La joie des Renault en immo.
immo off renault master dasauto Immobilizer dumps/solutions 11 14/04/2018 11h12
IMMO OFF renault master DIAGSYSTEM25 Immobilizer dumps/solutions 12 12/08/2015 16h53
Immo renault master CSYSTEME Immobilizer dumps/solutions 0 05/09/2012 16h02
immo off Renault Master DCI 1.9 slv Immobilizer dumps/solutions 9 08/11/2009 01h07
renault master 2006 immo off mehdifree Immobilizer dumps/solutions 2 22/07/2009 16h27
Fuseau horaire GMT +1. Il est actuellement 05h48.
