Vieux 07/12/2018, 10h42   #1
CSYSTEME
Avatar de CSYSTEME
CSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant future
Par défaut syncro ford cmax 1.6
j'ais besoin de faire une syncro ecu dasch pour un cmax .
je joint les dumps eeprom et dasch
je vous remercie d'avance
cordialement
Type de fichier : rar cmax.rar (1,5 Ko, 12 affichages)
The Following User Says Thank You to CSYSTEME For This Useful Post:
television (07/12/2018)
Vieux 07/12/2018, 11h42   #2
television
Avatar de television
television has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond repute
salut je te fait sa dans l apremidi
cdl
x17officiel kess ktag v54, delphi officiel ,multidiag,ms908pro officiel,flex oficiel.vente fichiers
television est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to television For This Useful Post:
CSYSTEME (07/12/2018), vortex (07/12/2018)
Vieux 07/12/2018, 11h51   #3
ggvaniou
Avatar de ggvaniou
Pouvoir de réputation: 88
Slt les amis
Voilà ton fichier resynchronisé.
https://mega.nz/#!2slkVYYS!E4Orb-_Ex9beOJZqZXsQ_5MVRszei1Lqv-c45fn0fro
ggvaniou est connecté maintenant   Réponse avec citation
The Following 5 Users Say Thank You to ggvaniou For This Useful Post:
abdel93 (07/12/2018), CSYSTEME (07/12/2018), REDZONE31 (07/12/2018), television (07/12/2018), vortex (07/12/2018)
Vieux 07/12/2018, 12h06   #4
television
Slt les amis
https://mega.nz/#!2slkVYYS!E4Orb-_Ex...1Lqv-c45fn0fro
salut tu lui a fait ok merci
CSYSTEME (07/12/2018), ggvaniou (07/12/2018)
Vieux 07/12/2018, 12h22   #5
CSYSTEME
Avatar de CSYSTEME
fichier recu et ecriture eeprom ok ,je teste le fonctionnement dans l apres midi ,je vous tient au courant .
cordialement
The Following 3 Users Say Thank You to CSYSTEME For This Useful Post:
abdel93 (07/12/2018), ggvaniou (07/12/2018), television (07/12/2018)
Vieux 08/12/2018, 10h30   #6
ggvaniou
Avatar de ggvaniou
Salut l'es amis
Alors ca donne quoi ce fichier?
television (08/12/2018)
Vieux 10/12/2018, 16h56   #7
CSYSTEME
Avatar de CSYSTEME
retour d'infos ,le vehicule demarre pas ,voyant rouge fixe ,
code erreur ,antidemarrage ,les codes ne corresponde pas .
cordialement
Vieux 10/12/2018, 18h07   #8
ggvaniou
Avatar de ggvaniou
Tu as quoi comme dtc?
CSYSTEME (10/12/2018)
Vieux 10/12/2018, 18h27   #9
CSYSTEME
Avatar de CSYSTEME
re
le vehicule n'est pas a l'atelier ,il me semble que c'est p1620 ,je me rapelle plus
j'ais pas note comme un c**
le diag dis bien que les codes ne corresponde pas
est ce que tu peut verifier si l'eeprom n'est pas corrompu ?
cordialement
Vieux 10/12/2018, 18h51   #10
ggvaniou
Avatar de ggvaniou
Ton eprom est corrompu.
Il faut refaire la synchro sur un full non corrompu.
Vieux 10/12/2018, 19h05   #11
CSYSTEME
Avatar de CSYSTEME
re
j'ais un full bdm correct ,
ci joint
cordialement
Type de fichier : rar 0281012486 ford focus 1.6 2004.rar (784,6 Ko, 4 affichages)
Syncro dash écu Ford fiesta [email protected] Réparation & Programmation 2 20/12/2017 18h00
ford fiesta avec sid802 + dash syncro Drogo programmation & synchronisation de clé 4 02/02/2017 13h02
Problème ford cmax 1.6 raed83300 Boite de vitesse 5 06/09/2016 23h34
fap ford cmax INVICTUS Chiptuning 25 12/08/2016 22h53
tbd ford Cmax BVA en BVM ricou 81 Tableau de bord (Dashboard) 17 18/07/2016 09h53
Fuseau horaire GMT +1. Il est actuellement 09h40.
