Vieux 14/08/2018, 17h13   #1
enteran
Avatar de enteran
enteran has a spectacular aura aboutenteran has a spectacular aura about
Par défaut Online activation of software on EASYDIAG 3.0 without buying brands
This scanner has recently appeared on sale and it has several improvements, compared to the old ones. It works much faster. Inside its main circuits with protective diodes. Works with voltage up to 18 volts.
The best and most effective way to activate car brands is online activation!
The program interface is in English. More than 200 car brands in different languages.
Only ONLINE activation reveals all the functionality of 431 PRO on EASYDIAG 3.0, including special functions.
After carrying out the diagnostics, the report can be printed or sent to e-mail.
The software update takes place online, the program checks for updates of brands, downloads and installs them.
The full program can reach about 6 Gb in the memory of the device.
Here you can buy the scanner itself: http://shopeasy.by/cashback/view/pcr...adf53c00cNDGTF
Instructions, read all to the end and carefully. If something is not clear, read it again. I tried to write answers to all the questions that arise.
To register devices 97699,97709 (EasyDiag 3.0, Golo Master 3.0) it is necessary to replace the original BOOT on BOOT from XDIAG.
---- 1. This eliminates all problems with unstable device operation.
---- 2. This allows you to register the device without buying a brand. (By serial number)
To change the name of the programmer ST-LINK, aliexpress costs about 2$ http://shopeasy.by/cashback/view/pcr...6c873c00NwzGbS
Instruction in English
The file can be obtained from the link:
https://yadi.sk/i/iK6U1Lxe3Z6TJa
https://yadi.sk/d/7L89kcU23a9X3R
https://yadi.sk/d/Gwe7mKE43Yzdcg
https://yadi.sk/d/uOMQWwEw3aCQPq
https://yadi.sk/i/oILXolO93a7qZM
Evaluate your abilities correctly.
FROM YOU NEED ONLY SERIAL NUMBER ADAPTER.
I will give the firmware and login and password for downloading stamps from the program.
Choose the option that suits you.
Currently there are 2 ways to activate the devices:
1. Online activation and access to the server with stamps for a year, with the ability to download updates from MY program, as in the original version (after a year, all the stamps remain with you and continue to work, simply you will not be able to update later). Everything works as in the PRO version ... adaptation, training and so on. Works with one, your adapter, others can not be used with your program. You can install and use on 3 devices!
2. Online activation and access to the server with stamps for three days, you can download all brands within three days from MY program, without the possibility of up****** them within a year. Downloaded and used, those versions of brands that were on the download day from the update server. Work will be without restrictions. All as in the PRO version ... adaptation, training and so on. Works with one, your adapter, others can not be used with your program. You can install and use on 3 devices!
After that, I immediately accept all the data and activate it. And while you are putting the program for work and uploading stamps
To enter I will give my login and password.
I can make 1 mark on the test for free.
On Audi stamps and Volkswagen at Launch in expensive scanners there is a function of guided diagnostics, it turns out this scanner can use it as well.
Audi and Volkswagenare downloaded by default without this function.
In order to download it to the version selection menu, you need to select the version with the prefix + GFun
In the update with a single button in the brand name there is such a prefix, there you need to press the red triangle and scroll up or select the desired version of the brand.
DiagBaseServiceAp (this application is needed for encoding) is downloaded simultaneously with the marks in the Downloads folder, it needs to be installed from there manually
After downloading everything, we make a backup (a copy of your software for the ability to restore it).
After you download all the marks on the device, do not forget to save the folder "XDIAGPRO". It can be stored on your computer and on the cloud, so as not to lose. And also it is necessary to save the application itself
If something happens to the phone / tablet, you can easily restore all activation using this folder.
To restore to another device, you need to insert the saved folder "XDIAGPRO" there and over install my application
To transfer stamps to a flash card, you can use third-party programs.
email [email protected]
Type de fichier : jpg 6f47c404k1f7-1920.jpg (60,1 Ko, 118 affichages)
enteran est déconnecté   Réponse avec citation
The Following 21 Users Say Thank You to enteran For This Useful Post:
alinjadii (25/10/2018), autodesign 67 (17/04/2019), autoscan (09/09/2018), brahimlamgarbi (18/10/2018), bzkmatrix (02/10/2021), diago2001 (04/11/2018), ElTurco (18/11/2022), izouf (09/10/2018), lutti68 (25/08/2020), micka45 (18/10/2018), nasisamy (04/09/2021), pipet (05/08/2019), rapou30 (16/02/2019), reda75 (15/10/2019), saadousfar (21/07/2020), selouan (14/08/2018), thomas (25/10/2018), xdols (14/08/2018), yoyomartin2003 (20/08/2018), zagor (10/12/2018)
Vieux 03/09/2018, 21h36   #2
enteran
Avatar de enteran
I can make software on EasyDiag For Android, EasyDiag For IOS, EasyDiag 2.0, IDIAG, DIAGUNIII, ICarScan, GOLO, DBScar, Pro WITHOUT PURCHASE stamps from Launch. It is necessary to flash the adapter through the programmer ST-link. Write to me in private messages.
https://yadi.sk/d/SnE-fGuD3aEHRm
The Following 7 Users Say Thank You to enteran For This Useful Post:
bzkmatrix (02/10/2021), ElTurco (18/11/2022), izouf (09/10/2018), micka45 (18/10/2018), REDZONE31 (03/09/2018), saadousfar (21/07/2020), yoyomartin2003 (04/09/2018)
Vieux 09/10/2018, 09h10   #3
enteran
Avatar de enteran
Latest updates on the server
04.10.2018 SPRINTER V21.12 Turkish, Russian, Portuguese, Korean, Italian, Taiwan, French, Spanish, German, China, Arabic, English
04.10.2018 FERRARI V10.60 Swedish, Serbian, Russian, Korean, Danish, China, Arabic, English
04.10.2018 MASERATI V10.50 Swedish, Serbian, Russian, Korean, Danish, China, Arabic, English
04.10.2018 ASTON MARTIN V10.31 Russian, China, English
04.10.2018 GM (China) V50.30 English
01.10.2018 ISUZU, ISUZU (Thailand) V16.50 Russian, Portuguese, Korean, Italian, Taiwan, French, Spanish, German, China, English
01.10.2018 LANDROVER, JAGUAR V33.45 Turkish, Russian, Portuguese, Polish, Dutch, Korean, Japan, Italian, Taiwan, French, Spanish, German, China, Arabic, English
30.09.2018 FIAT, ALFA ROMEO, LANCIA, ABARTH, NJFIAT V35.20 Turkish, Swedish, Serbian, Russian, Portuguese, Polish, Dutch, Korean, Japan, Italian, Taiwan, Greek, French, Spanish, German, Danish, China, Arabic, English
30.09.2018 SKODA V28.01 Turkish, Swedish, Serbian, Russian, Portuguese, Polish, Hungarian, Dutch, Korean, Japan, Italian, Croatian, Taiwan, Greek, French, Finnish, Spanish, German, Danish, Czech, China, Arabic, English
30.09.2018 DAEWOO V27.00 Turkish
The Following User Says Thank You to enteran For This Useful Post:
Vieux 17/10/2018, 19h19   #4
enteran
Avatar de enteran
DANGER! NEW PROTECTION EASYDIAG 3.0
https://yadi.sk/d/pGQTk2bKrrJz1A
---------- Post added at 08:17 PM ---------- Previous post was at 08:09 PM ----------
Envoyé par enteran Voir le message
Inside the board are glued to the case. When opened, the adhesive removes the parts from the boards. It is necessary to enlighten the body with a bright light. See where the glue is. Heat the body, it will help. You can cut the area with glue. Black resin on the contacts for programming is removed when heated.
---------- Post added at 08:19 PM ---------- Previous post was at 08:17 PM ----------
[QUOTE=enteran;641149]DANGER! NEW PROTECTION EASYDIAG 3.0
https://yadi.sk/d/pGQTk2bKrrJz1A[COLOR="Silver"]
REDZONE31 (18/10/2018)
Vieux 18/10/2018, 03h32   #5
brahimlamgarbi
Avatar de brahimlamgarbi
Pouvoir de réputation: 37
Salut enteran.
J éspere à toi bon courage.surtout je vois que c est trés important chez moi cette manupilation pour etre le easydiag 3.0 disponible avec un activation onligne de votre server.
Bon continuatio
The Following User Says Thank You to brahimlamgarbi For This Useful Post:
enteran (21/10/2018)
Vieux 18/10/2018, 07h39   #6
Topal
Avatar de Topal
Topal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to all
Salut, les Gars
Mara07 n'a pas le meme matos ? il me semble que oui
Pat
Topal est déconnecté   Réponse avec citation
Vieux 24/10/2018, 17h27   #7
enteran
Avatar de enteran
23.10.2018 MITSUBISHI V32.80 Turkish, Swedish, Russian, Portuguese, Polish, Korean, Japan, Italian, Taiwan, Greek, French, Persian, Spanish, German, Czech, China, Arabic, English
23.10.2018 CITROEN, FUKANG V41.50 Turkish, Swedish, Serbian, Russian, Portuguese, Polish, Dutch, Korean, Japan, Italian, Hungarian, Croatian, Taiwan, Greek, French, Finnish, Persian, Spanish, German, Danish, Czech, China, Arabic, English
23.10.2018 MAZDA, ZHONGGUOMAZDA V41.40 Turkish, Swedish, Russian, Romanian, Portuguese, Polish, Dutch, Korean, Japan, Italian, Hungarian, Taiwan, Greek, French, Finnish, Persian, Spanish, German, Danish, Czech, China, Arabic, English
23.10.2018 LANDROVER, JAGUAR V33.46 Turkish, Russian, Portuguese, Polish, Dutch, Korean, Japan, Italian, Taiwan, French, Spanish, German, China, Arabic, English
22.10.2018 CHRYSLER, DODGE, JEEP V32.30 Turkish, Russian, Portuguese, Korean, Italian, Taiwan, French, Spanish, German, China, Arabic, English
22.10.2018 GM, CHEVROLET, CADILLAC, BUICK V47.00 Turkish, Russian, Portuguese, Korean, Japan, Italian, Taiwan, French
22.10.2018 GM, CHEVROLET, CADILLAC, BUICK V47.00 Spanish, German, China, Arabic, English
22.10.2018 VOLKSWAGEN, BENTLEY, BUGATTI, LAMBORGHINI V28.46 Turkish, Swedish, Serbian, Russian, Portuguese, Polish, Dutch, Korean, Japan, Italian, Hungarian, Croatian, Taiwan, Greek, French, Finnish, Spanish, German, Danish, Czech, China, Arabic, English
The Following 2 Users Say Thank You to enteran For This Useful Post:
vortex (25/10/2018), yoyomartin2003 (24/10/2018)
Vieux 25/10/2018, 15h58   #8
enteran
Avatar de enteran
25.10.2018 DAIHATSU V20.29 Portuguese, Korean, Japan, Italian, Taiwan, French, China, Arabic, English
25.10.2018 SAAB V22.98 Serbian, Russian, Portuguese, Korean, Italian, Croatian, Taiwan, French, Spanish, German, China, Arabic, English
25.10.2018 OPEL, GMSA, VAUXHALL V42.00 Turkish, Serbian, Russian, Portuguese, Polish, Korean, Italian, Croatian, Taiwan, Greek, French, Spanish, German, China, Arabic, English
25.10.2018 RENAULT, DACIA, SAMSUNG V42.86 Turkish, Swedish, Serbian, Russian, Romanian, Portuguese, Polish, Dutch, Korean, Italian, Taiwan, Greek, French, Finnish, Persian, Spanish, German, Danish, China, Arabic, English
23.10.2018 VOLVO V44.00 Turkish, Swedish, Russian, Portuguese, Dutch, Korean, Japan, Italian, Taiwan, French, Finnish, Spanish, German, China, Arabic, English
vortex (29/10/2018)
Vieux 29/10/2018, 13h50   #9
enteran
Avatar de enteran
29.10.2018 RESETSAS V10.65 Russian, Korean, China, English
29.10.2018 RESETTPMS V10.65 Russian, Korean, China, English
28.10.2018 RESETOIL V10.65 China, Russian, Korean, English
28.10.2018 RESETBRAKE V10.60 China, Russian, Korean, English
28.10.2018 RESETBLEED V10.60 China, Russian, Korean, English
28.10.2018 HONDA, ACURA, DFHONDA, GZHONDA V46.91 Swedish, Russian, Korean, Hungarian, Finnish, Persian, Czech, China, Arabic, English
28.10.2018 PORSCHE V23.20 Russian, Korean, China, Arabic, English
28.10.2018 NISSAN, INFINITI, DONGFENGNISSAN, VENUCIA V44.00 Russian, Korean, Persian, China, Arabic, English
28.10.2018 KIA V44.40 Serbian, Russian, Romanian, Korean, Hungarian, Persian, Czech, China, Arabic, English
28.10.2018 HAIMA V12.60 China, English
28.10.2018 MERCEDES-BENZ, MAYBACH V49.02 Swedish, Serbian, Russian, Korean, Hungarian, Finnish, Persian, Danish, Czech, China, Arabic, English
28.10.2018 CHANGHE V20.14 Russian, China, English
28.10.2018 BEIJING (BAIC) V10.90 China, English
28.10.2018 DAEWOO V27.01 Turkish, Russian, Portuguese, Polish, Korean, Italian, Taiwan, Greek, French, Persian, Spanish, German, China, Arabic, English
28.10.2018 DEMO V15.10 Russian, Persian, Korean, China, Arabic, English
28.10.2018 EOBD2 V22.62 Swedish, Serbian, Russian, Romanian, Korean, Hungarian, Croatian, Finnish, Persian
28.10.2018 EOBD2 V22.62 Danish, Czech, China, Arabic, English
28.10.2018 TOYOTA, LEXUS, TJTOYOTA
vortex (29/10/2018)
Vieux 31/10/2018, 07h53   #10
enteran
Avatar de enteran
30.10.2018 HD FOTONAUMAN V13.90 Chinese (Traditional), Chinese (Simplified), English
30.10.2018 HD ALLISON V10.40 English
30.10.2018 HD ABS V11.05 Chinese (Traditional), Chinese (Simplified), English
30.10.2018 HD FAWJIEFANG V13.50 Chinese (Traditional), Chinese (Simplified), English
30.10.2018 HD DFL V10.85 Chinese (Traditional), Chinese (Simplified), English
30.10.2018 HD DAF V11.80 Italian, Chinese (Traditional), French, German, Chinese (Simplified), English
30.10.2018 HD DACHAI V10.53 Chinese (Traditional), Chinese (Simplified), English
30.10.2018 HD CUMMINS V15.57 Korean, Chinese (Traditional), French, Spanish, German, Chinese (Simplified), English
Vieux 04/11/2018, 20h22   #11
Temorh
Avatar de Temorh
Temorh is an unknown quantity at this point
Thats good, i see also the video in youtube where you should act carefully with the device, what i didnt get here, is from where i get the password and the Id
Temorh est déconnecté   Réponse avec citation
Vieux 06/11/2018, 20h17   #12
enteran
Avatar de enteran
Envoyé par Temorh Voir le message
Login and password from the program in a personal message
autoscan (29/11/2018)
Vieux 02/12/2018, 11h31   #13
enteran
Avatar de enteran
01.12.2018 SEAT V28.05 Portuguese, Polish, Dutch, Korean, Japan, Italian, Hungarian, Croatian, Chinese (Traditional), Greek, French, Finnish, Spanish, German, Danish, Czech, Chinese (Simplified), Arabic, English
01.12.2018 SKODA V28.10 Turkish, Swedish, Serbian, Russian, Portuguese, Polish, Dutch, Korean, Japan, Italian, Hungarian, Croatian, Chinese (Traditional), Greek, French, Finnish, Spanish, German, Danish, Czech, Chinese (Simplified), Arabic, English
01.12.2018 PEUGEOT, DFPEUGEOT V43.50 Turkish, Swedish, Serbian, Russian, Portuguese, Polish, Dutch, Korean, Japan, Italian, Hungarian, Croatian, Chinese (Traditional), Greek, French, Finnish, Persian, Spanish, German, Danish, Czech, Chinese (Simplified), Arabic, English
01.12.2018 ROVER V23.21 Serbian, Russian, Portuguese, Italian, Chinese (Traditional), French, Spanish, German, Chinese (Simplified), Arabic, English
01.12.2018 SAAB V22.99 Serbian, Russian, Portuguese, Korean, Italian, Croatian, Chinese (Traditional), French, Spanish, German, Chinese (Simplified), Arabic, English
01.12.2018 SSANGYONG V19.00 Russian, Portuguese, Korean, Italian, Chinese (Traditional), French, Spanish, German, Chinese (Simplified), Arabic, English
01.12.2018 USAFORD, EUROFORD, LINCOLN, CHANGANFORD V47.35 Turkish, Swedish, Russian, Romanian, Portuguese, Polish, Dutch, Korean, Japan, Italian, Hungarian, Chinese (Traditional), Greek, French, Finnish, Spanish, German, Czech, Chinese (Simplified), Arabic, English
01.12.2018 NISSAN, INFINITI, DONGFENGNISSAN, VENUCIA V44.01 Turkish, Russian, Portuguese, Polish, Korean, Japan, Italian, Chinese (Traditional), Greek, French, Persian, Spanish, German, Chinese (Simplified), Arabic, English
01.12.2018 SEAT V28.05 Turkish, Swedish, Serbian, Russian
vortex (09/12/2018)
Vieux 03/12/2018, 18h32   #14
enteran
Avatar de enteran
02.12.2018 RESETIMMO V10.65 Russian, Korean, Chinese (Simplified), English
02.12.2018 RESETINJEC V10.65 Russian, Korean, Chinese (Simplified), English
02.12.2018 RESETBLEED V10.65 Russian, Korean, Chinese (Simplified), English
02.12.2018 RESETDPF V10.65 Russian, Korean, Chinese (Simplified), English
02.12.2018 RESETBMS V10.65 Russian, Korean, Chinese (Simplified), English
02.12.2018 RESETBRAKE V10.65 Korean, Chinese (Simplified), Russian, English
vortex (09/12/2018)
Vieux 09/12/2018, 11h56   #15
enteran
Avatar de enteran
08.12.2018 CHERY V56.40 Russian, Chinese (Simplified), Arabic, English
08.12.2018 MAHINDRA (Indian) V12.73 English
08.12.2018 MARUTI (Indian) V16.40 English
08.12.2018 GM (China) V50.40 Chinese (Simplified), English
08.12.2018 ASTON MARTIN V10.40 Russian, Chinese (Simplified), English
08.12.2018 LDV (Maxus) V10.05 Chinese (Simplified), English
08.12.2018 QOROS V10.10 Chinese (Simplified), English
vortex (09/12/2018)
easydiag 2.0 brahim chafa3 HexTool.Net 3 28/03/2021 00h41
Easydiag salemsim Launch X431 6 15/09/2017 18h56
dbscar ou easydiag salemsim Launch X431 1 26/08/2017 19h44
Fuseau horaire GMT +1. Il est actuellement 06h11.
