Vieux 07/11/2017, 00h15   #1
tarik_electronic
Avatar de tarik_electronic
Pouvoir de réputation: 40
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
Par défaut Immo off edc16c3
Slm
Je cherche immo off pour ecu edc16c3 100% sans mode dégrade
Merci T-E
tarik_electronic est déconnecté   Réponse avec citation
Vieux 07/11/2017, 01h42   #2
prinzo57
Avatar de prinzo57
Pouvoir de réputation: 43
poste ton fichier je te le fait.....
The Following 2 Users Say Thank You to prinzo57 For This Useful Post:
akasa67 (08/11/2017), pouettedu76 (07/11/2017)
Vieux 07/11/2017, 16h57   #3
AOUN
Avatar de AOUN
AOUN has a spectacular aura aboutAOUN has a spectacular aura about
Virgin won't help. Key working but sometimes cannot start. Customer's request need remove...
The below is instruction. It's not mine but from other forum so it is definetely works. Don't have lexia yet so cannot check.
Preparation with PP2000:
0. Go to replacement parts->injection->injectors-> print screen the injector codes
0.5 Go to engine ecu->configuration -> print screen the configuration
The cooking recipe:
1. Read eeprom with BDM (2kb size!)
2. Make virgin with ImmoDec 3.2
3. Disable immo on the virgin file with Immo tool v1.5
4. Load the eeprom file with BDM
5. With PP2000 go to ecu->confiuguration (notice all settings are virgin), do the correct configuration
6. Go to replacement parts->Injection->injectors , register the injector codes
If I helped, please, use magic buttons reputation+thanks
AOUN est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to AOUN For This Useful Post:
amine08 (22/03/2018), eescham (14/11/2017)
Vieux 07/11/2017, 17h25   #4
Kennfeld
Avatar de Kennfeld
Envoyé par AOUN Voir le message
The cooking recipe:
ce n'est pas ce q u'il demande :'(
en une frac tion de seconde tout le dump est décodable
et possible d e immo off dans l a meme fraction de seconde avec vérification serveur du checksum de chaque bloc de donné s!!!
Vieux 10/11/2017, 21h17   #5
Kennfeld
Avatar de Kennfeld
il faut absoluement partir du fichier eeprom org de la voiture sinon vous faites de la merde !!!
les options regulateur de vitesse type de boite abs esp et bien d'autre risquent d'etre desactivés sinon ! la config sera donc pourrie avec plein de voyants alors que si vous faites d'apres le fichier de la voiture aucun voyant !!!
immo off edc16c3- 206 dump974 Immobilizer dumps/solutions 16 13/04/2021 01h18
Immo off edc16C3 Verdun Immobilizer dumps/solutions 15 11/11/2014 09h13
immo off edc16C3 formator2 Immobilizer dumps/solutions 1 12/06/2014 18h59
Immo off edc16c3 206 1.4L HDI spider man2 Immobilizer dumps/solutions 3 21/05/2014 23h40
immo off edC16C3 auto perf Immobilizer dumps/solutions 9 03/02/2014 16h59
Fuseau horaire GMT +1. Il est actuellement 18h25.
