Vieux 02/09/2017, 16h43   #1
omarino
Avatar de omarino
omarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to all
Par défaut audi A3 2l année 2007
j'ai une audi A3 année 2007 qui ne veut pas démarrer (le démarreur ne tourne pas). batterie et démarreur neufs.
j'ai fait in diag avec vcds, et voila les modules avec les codes défauts
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DH HW: 03G 906 018 DH
Component: R4 2.0l PPD1.2 G 4346
Revision: --H42--- Serial number: AUX7Z0G0FNF0H0
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 6ED328337962DE6E76F-803B
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006786
Shop #: WSC 06314 000 00000
VCID: 73E539471240F386991-8026
1 Fault Found:
01309 - Power Steering Control Module (J500)
008 - Implausible Signal
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
Shop #: WSC 40050 146 51661
VCID: 4189A38F187C1116DBD-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
2 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
01301 - Control Module for Voice Recognition (J507)
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 3300106C1302C3
Coding: 7D3F574A07002102
VCID: 2F6DF537BEE897663D9-807A
1 Fault Found:
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 111
Mileage: 224526 km
Time Indication: 0
Date: 2017.09.02
Time: 14:28:45
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No SW: 8P0 920 931 HW: 8P0 920 931
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: AUX7Z0G0FNF0H0
Shop #: WSC 00000 000 00000
VCID: F0EFB64BE356489EE43-80A5
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3467FA5B57CEB4BE40B-8061
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 H
Component: KSG H08 0070
Coding: 9880202002186D098505488F0077
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Component: Tuer-SG 020 0090
Coding: 0000248
2 Faults Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit
00940 - Mirror Adjust Motor; Passenger Side (V150)
vue les nombre de defaults je ne sais pas qui me bloque.
Merci de votre aide
cdlt
omarino est déconnecté   Réponse avec citation
Vieux 02/09/2017, 18h13   #2
kitty-hawk
Avatar de kitty-hawk
Pouvoir de réputation: 47
Envoyé par omarino Voir le message
1 Fault Found:
014 - Defective
Hello,
Je ne sais pas pourquoi elle ne démarre pas mais il y a de forte chance qu'il y ai un trafic de compteur/kombiné d'instrument sur cette Audi....
The Following 2 Users Say Thank You to kitty-hawk For This Useful Post:
omarino (02/09/2017), tony60 (02/09/2017)
Vieux 02/09/2017, 19h10   #3
omarino
Avatar de omarino
salut kitty-hawak
franchement, je ne sais pas si le kilométrage est trafiqué, j'ai poser la question au client, et il'm as dit non!!!!.
le démarreur ne tourne même pas.
je ne sais pas si le relai de démarreur qui hs???
Vieux 02/09/2017, 19h24   #4
kitty-hawk
Tu aurais le code moteur de cette Audi?
The Following User Says Thank You to kitty-hawk For This Useful Post:
Vieux 02/09/2017, 19h58   #5
golfio77
Avatar de golfio77
golfio77 is a glorious beacon of lightgolfio77 is a glorious beacon of lightgolfio77 is a glorious beacon of lightgolfio77 is a glorious beacon of lightgolfio77 is a glorious beacon of light
Salut l'ami,
Pour ma part je ne vois aucun défaut qui empercherai le démarrage ...
As-tu une bonne masse moteur?
Le démarreur fonctionne-t-il en direct? As-tu verifier tes arrivées 12v?
A++
golfio77 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to golfio77 For This Useful Post:
kitty-hawk (02/09/2017), omarino (02/09/2017)
Vieux 02/09/2017, 20h13   #6
kitty-hawk
Envoyé par golfio77 Voir le message
Salut l'ami,
A++
C'est vrai, ces défauts ne devraient pas couper le démarreur ou empecher le démarrage mais, les codes défauts sentent la bidouille.......
Quelles explications t'as donné ton client?
Vieux 02/09/2017, 20h20   #7
omarino
Avatar de omarino
salut les amis
le code moteur est LZ9Y
la masse entre le chassie et la batterie est bonne.
même en tirant la voiture ne veux pas démarrer.
le démarreur a juste deux moi.
je n'ai pas encore vérifier l'arriver des 12 V au niveau de démarreur.
Vieux 02/09/2017, 20h21   #8
golfio77
Avatar de golfio77
Envoyé par kitty-hawk Voir le message
Il y en as qui sont dus a un changement de volant...mais il est claire qu'il y a bidouille...ou mauvais remontage...
The Following User Says Thank You to golfio77 For This Useful Post:
Vieux 02/09/2017, 20h21   #9
tony60
Avatar de tony60
Pouvoir de réputation: 102
16346 ... Eprom corrumpu le vin a du sauter pin avec ta mi la doigt sur le problèmes
The Following 3 Users Say Thank You to tony60 For This Useful Post:
golfio77 (03/09/2017), kitty-hawk (03/09/2017), omarino (02/09/2017)
Vieux 02/09/2017, 20h28   #10
omarino
Avatar de omarino
quand je lui poser la question, il m'a dit qu'il n’as pas trafiqué le compteur.
et après, moi je ne connais pas l’historique de la voiture.
---------- Post added at 20h28 ---------- Previous post was at 20h24 ----------
alors c est koi la solution???
Vieux 02/09/2017, 20h30   #11
tony60
Avatar de tony60
Pour moi.. Poste dump compteur on sera vite fixer
Anti dem et dans le compteur
Vieux 02/09/2017, 20h32   #12
golfio77
Avatar de golfio77
en tous cas il est claire qu'elle a eu un mauvais flash...
Vieux 02/09/2017, 20h55   #13
omarino
Avatar de omarino
voua avez raison, je viens d'appeler le client, il me confirme que la voiture été deffapé mécaniquement+électroniquement mais elle marché jusqu’au mnt.
je ne sais pas si le table de dtc a été enlevé pendant le deffapage (ecusafe...).
je me suis douté car quand j'ai débranche le debimétre, j'avais pas de défaut qui remonté sur le diag!!!!
Vieux 02/09/2017, 21h01   #14
S-keys
Avatar de S-keys
Pouvoir de réputation: 141
dit omarino , tu as controlé quoi exactement ??
avec semple diag posté ici , tu pense trouvé la solution ?
est ce modele qui doit emrayer pour lancer le demarreur ?
The Following 4 Users Say Thank You to S-keys For This Useful Post:
golfio77 (03/09/2017), kitty-hawk (03/09/2017), omarino (02/09/2017), prt93 (20/09/2017)
Vieux 02/09/2017, 21h28   #15
omarino
Avatar de omarino
Envoyé par selim95 Voir le message
salut selim
j'ai contrôle toutes les fusibles intérieures extérieure+les masses
partner classique 1.9 année 2007 jardini PSA Group Peugeot, Citroën 2 02/09/2017 20h52
VOLVO S40 année 2007 1L6D quelle ecu ???? nono93 Fichiers d'origine, carto, dump, fullbackup 0 09/01/2017 17h17
full bdm C3 1.4 HDI ANNEE 2006/2007 sosauto Fichiers d'origine, carto, dump, fullbackup 20 19/01/2015 21h46
motoventalateur 207 année 2007 jardini PSA Group Peugeot, Citroën 12 01/12/2014 21h16
Bsi 24c128 2007 annee 2009 geniehex Tableau de bord (Dashboard) 30 06/12/2013 16h55
Fuseau horaire GMT +1. Il est actuellement 05h24.
