Précédent   Tlemcen Car electronics > Outils & Diag > Diagnostic automobile > Logiciel & autres documentations général
Vieux 24/07/2017, 04h05   #1
Builes
Avatar de Builes
Builes is on a distinguished road
Par défaut Bmw Etk v07.2017 Multilingual
Catalog of spare parts from the manufacturer. The search is carried out both by the spare part number, and by car model or by VIN car.
Extras. Information: IMPORTANT!
When installing, turn off TORRENT !!!!!!
Installing from a DVD or virtual disk!
To update the program:
Run the ETK Admin application and select "Data" - "Download published data ..." in the menu, where you specify the path to the disk where the image from this distribution is mounted.
For a new installation:
1 The name of the computer (not the user, namely the computer !!!) should be in the Latin alphabet. (Latin alphabet)
2 Ports must be set to 1027 and 1028 at installation, in the lower fields will already be 2024 and 2025. Application policy on the "correct" ports has changed. It is better to try to leave those that the installer itself will offer.
3 Do not fill out the server addresses.
4 The RR directory is set if you enter the oxford12 password. Password for ZINORO - shenyang15
5 The market is chosen by Eastern Europe.
6 The firm and the ID of the business partner 1 and 1 (in both fields).
If the shortcut to the directory of accessories has disappeared or has not appeared:
Copy the label of the main directory "ETK Lokal" and in the shortcut properties add in the field the object after ETK.exe app = zub
Note: Site don't include What News
Year / Release Date: 07/2017
Version: 3.1.50
Developer: BMW AG
Language: Multilingual (Russian is present)
Tabletka: not required
How to check the VIN of a car / motorcycle BMW MINI ROLLS-ROYCE without this catalog
If you only need to check the car for the validity of the VIN (serial number), production date and equipment, then there is no point in setting this directory. For this it is easier to use online services of the type
pass = thanks and reputation
Type de fichier : rar link.rar (314 octets, 13 affichages)
tuning Stage 1/2, dpf, egr, dtc,immo, airbag clear crash...100% working solutions winols!!!
Builes est déconnecté   Réponse avec citation
DAF Davie 5.6.1 APP 84.00 PRSubset 16.51.F3 Multilingual mod-files.com DAF 2 20/03/2024 11h55
Mercedes-Benz EPC/ 04.2017 WIS/ASRA 04.2017 FULL en torrent odis Mercedes Benz 6 18/12/2017 19h37
Les cartographies (RT6) 2017-1 du 04/2017 sont maintenant disponibles. dany6999 Autoradio et Navigateur GPS 1 12/08/2017 18h31
ODIS 4.0+ PostSetup 30.0.10 (Multilingual) mod-files.com VAS5054, VCDS, ODIS 22 06/08/2017 21h25
BMW KSD [02.2017] Multilingual mod-files.com BMW, Mini, Rolls-Royce 0 01/03/2017 14h32
Fuseau horaire GMT +1. Il est actuellement 02h30.
