Vieux 03/05/2017, 13h13   #1
mexicain
Avatar de mexicain
mexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to behold
Par défaut Renault Ecutool CAN/Kline
salut je vend un Renault Ecutool CAN/Kline neuf dans l'emballage 680e fdp inclus
EDC15C3 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EDC15C13 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 31H - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 32[N] (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 34 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 35 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3132 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3134 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SID301 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code, Clear IMPACT DETECTED, Read stored mileage
SIM32 - Read/Write EEPROM, Read/Write FLASH from HD64F7055, Clear Immo Code
SAFIR / SAFIR2 / SFR200 (35 / 55 pin connector) - Read TMS374 EEPROM, Clear Immo Code (car runs without immobilizer code)
IAW 6R.20 - Read/Write TMS370 EEPROM
IAW 6R.30 - Read TMS370 EEPROM, Clear Immo Code (car runs without immobilizer code)
VALEO BII for ESPACE III - Read/Write (9)08AZ60 EEPROM, Read/Write mileage, Clear for Replacement, Read transponder data, Emergency Startup
VALEO IMMOBILIZER for LAGUNA I Ph2 (1998-2000) - Read transponder data, Configure, Reset to VIRGIN
INSTRUMENT CLUSTER for ESPACE III (1998-2002) - Reset odometer, Erase RF remote programming by instrument cluster connector
SIEMENS IMMOBILIZER for ESPACE III Ph1 (1996-1998) - Read/Write 68HC05B16 EEPROM, read transponder data
SIEMENS UCH for MEGANE/SCENIC ('98-'02) - Read/Write 705B32 EEPROM, Read/Write configuration, Learn Keys
LAGUNA II, ESPACE IV, VELSATIS, LAGUNA II Ph2, ESPACE IV Ph2, VELSATIS Ph2 - KeyCard Programming, Change VIN (! IMPROVED !)
MEGANE II, SCENIC II, MEGANE II Ph2, SCENIC II Ph2 - KeyCard Programming, Change VIN, Reset UCH to VIRGIN
INSTRUMENT CLUSTER for SCENIC II ('04-'08) - Wake-Up by CAN-BUS for repair or to check mileage, Change language and units, Change VIN
CLIO II Ph2, KANGOO, TRAFIC, MASTER, VIVARO, MOVANO (-'07) - Read/Write EEPROM 93C66, Key Learning, Change VIN
KANGOO I, TRAFIC, MASTER, VIVARO, MOVANO ('07-) - Key Learning, Change VIN
KANGOO II (2007-2012) - Key Programming, Change VIN
MODUS / CLIO III ELECTRIC POWER ASSISTED STEERING (TRW DAE/PAS) - Clear Immo Code, Change VIN by OBDII, erase DF002 from 24C16 dump, repair CRC
MEGANE/SCENIC III ELECTRIC POWER ASSISTED STEERING (NSK DAE/PAS) - Clear Immo Code, Change VIN by OBDII
TWINGO III ELECTRIC POWER ASSISTED STEERING (JTEKT DAE/PAS) - Clear Immo Code, Change VIN by OBDII
LAGUNA III (2007-2015) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
LATITUDE (2010+) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
CLIO III / MODUS - Key Programming, Change VIN, Learn ECM in protected mode
CLIO III - Card Programming, Change VIN, Reset UCH to VIRGIN
MASTER III (2010-) - Key Programming, Change VIN
WIND (2010-2013) - Key Programming, Change VIN, Learn ECM
TWINGO II (2007-2013) - Key Programming, Change VIN, Learn ECM
TWINGO (2001-2006), LOGAN (2004-2008), SANDERO I, THALIA, SYMBOL - Key Programming, Change VIN
LOGAN, SANDERO, THALIA, SYMBOL (2008-2012), Duster (2010-2012) - Key Programming, Change VIN
MEGANE III / SCENIC III (2009-2015) - Card Programming, Change VIN, Reset BCM to VIRGIN
KOLEOS (2008+) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN (NEW !)
EDC17 / MED17 TRICORE EEPROM DUMP CRC - Reset EEPROM dump to VIRGIN, repair block checksums
MEGANE III / SCENIC III / FLUENCE / LATITUDE AIRBAG (CONTINENTAL) - Erase CRASH DATA by OBDII / direct connection (NEW !)
LAGUNA III AIRBAG (AUTOLIV RC5) - Erase CRASH DATA by OBDII / direct connection (NEW !)
TWINGO II (X44) / KANGOO II (X61) AIRBAG (CONTINENTAL) - Erase CRASH DATA by OBDII / direct connection (NEW !)
MASTER III / MOVANO-B / CLIO III Ph2 / MODUS Ph2 AIRBAG (AUTOLIV) - Erase CRASH DATA by OBDII / direct connection (NEW !)
AIRBAG MODULE WITH SPC560 MCU (CONTINENTAL) - Erase CRASH DATA by OBDII / direct connection (NEW !)
MEGANE II / SCENIC II AIRBAG (AUTOLIV ACU4) - Erase CRASH DATA by OBDII / direct connection (NEW !)
Need more information?
Type de fichier : jpg ecutoolMODIF.JPG (81,6 Ko, 79 affichages)
Dernière modification par mexicain ; 05/05/2017 à 20h45.
mexicain est déconnecté   Réponse avec citation
The Following User Says Thank You to mexicain For This Useful Post:
pouettedu76 (18/09/2017)
Vieux 03/05/2017, 14h33   #2
ecutech
Avatar de ecutech
Deja tu ten separe ?
Vieux 03/05/2017, 16h08   #3
subzero
Banned
Avatar de subzero
subzero is a jewel in the roughsubzero is a jewel in the roughsubzero is a jewel in the rough
Envoyé par autoparts31 Voir le message
t'en veux un de plus pour ta collection ?
subzero est déconnecté   Réponse avec citation
Vieux 03/05/2017, 16h23   #4
ecutech
Avatar de ecutech
Envoyé par subzero Voir le message
Mdr non je pense que 3 c'est deja bien :D :D
Vieux 05/05/2017, 12h50   #5
mexicain
Avatar de mexicain
upupupupupup
Vieux 05/05/2017, 14h13   #6
mexicain
Avatar de mexicain
SALUT NON T FOU c'est un très bon outil j'en ai plusieurs c'est tout.
Vieux 05/05/2017, 21h43   #7
kamelartiste
Avatar de kamelartiste
kamelartiste will become famous soon enough
Vendeur tres serieux
pas de thanks----- pas d'aide
kamelartiste est déconnecté   Réponse avec citation
Vieux 26/07/2017, 23h56   #8
roulad
Avatar de roulad
roulad is an unknown quantity at this point
Bonsoir interesé par ton ecutool, si toujours dispo
roulad est déconnecté   Réponse avec citation
Vieux 27/07/2017, 00h05   #9
mexicain
Avatar de mexicain
Envoyé par roulad Voir le message
salut desoler vendu
Renault Ecutool CAN/Kline Dispo diagnosis29 Vente, Achat, Echange 30 01/06/2017 03h43
Renault Ecu tool CAN/Kline BILAUTO Autres 10 17/02/2017 21h05
comment installer renault ecutool repcles programmation & synchronisation de clé 6 08/11/2016 20h43
renault ecutool rachid78 Outil de programmation 20 02/07/2016 00h32
renault ecutool tintin421 Vente, Achat, Echange 5 09/12/2015 19h24
Fuseau horaire GMT +1. Il est actuellement 08h28.
