Vieux 17/06/2011, 17h14   #1
Mezz
Avatar de Mezz
Mezz is an unknown quantity at this point
Par défaut Renault Scenic
Hello
I need help about A/C of Renault Scenic,the problem is MODUL for fan,inside him there is one power transistor with signature N434AG,but i can t find any information about him and which part is for replacement,so could anybody help me please???
Many thanks....
Bruno
Mezz est déconnecté   Réponse avec citation
Vieux 26/06/2011, 20h28   #2
Mezz
Avatar de Mezz
Hello
No that s not true,because this transistor what i have is TO-252 case and you what you give me is TO-3 case,so that is not replacement.....
but many thanks...anyway....
Bruno
Vieux 28/06/2011, 22h17   #3
ziregue
Représentant T-E
Avatar de ziregue
ziregue is a splendid one to beholdziregue is a splendid one to beholdziregue is a splendid one to beholdziregue is a splendid one to beholdziregue is a splendid one to beholdziregue is a splendid one to beholdziregue is a splendid one to behold
Par défaut Replacement part
GOOD EVENING MEZZ
I had the same problem but were a transistor 75344G
in case TO-247
replacement part
IRF 3205
MOSFET canal N Grille Drain Source
TO-247 TO-220AB
drain current 75A
drain current (pulsed – 2kHZ) ~300A 390A
power dissipation 285W 200W
ziregue est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to ziregue For This Useful Post:
Mezz (28/06/2011), nany (11/12/2011)
cherche carte vierge pour renault scenic crnizmaj Vente, Achat, Echange 2 17/06/2011 21h03
Code pin renault scenic Dti kam306 Transponder, code pin 10 31/12/2009 18h31
Code Pin Renault Scenic sawadogo2 Transponder, code pin 3 27/09/2009 21h45
code autoradio renault scenic hocine2 Autoradio et Navigateur GPS 2 29/03/2009 19h19
Fuseau horaire GMT +1. Il est actuellement 03h18.
