J'ai un 2008 207cc qui vient avec une coupure ouverte de démarrage parfois quand je m conduis La botte n'est pas ouverte Veuillez indiquer l'emplacement du capteur pour ce Merci |
Hello
can you explain the problem in English , because I don't understand with the translator thanks |
Hi
The 207 CC has a open boot fault coming up sometimes when driving The boot is not open where is this sensor which is givin this fault ? |
![]() Date d'inscription: février 2017
Pouvoir de réputation: 12 ![]() ![]() ![]() |
Hi,
I think the switch is in the boot lock itself (internal component) |
Hello
I don't think it's a sensor problem. Car rolls when this happens and you do not give a default code. Do you have games at the level of the contact key? Can you do the test with only the car key and not all your key ? I have already seen a false contact with a key too heavy. A + |
Hi
No fault code is detected using Diagbox The boot open message happens sometimes when driving and then goes away The car is a 207 CC I can open the boot with the remote key and close it but the fault is still happening randomly |
| DEMANDE CLEAR POUR 207CC - autoliv 609221000 - 9664066680 | suez13008 | Airbag | 3 | 13/10/2015 17h32 |
| Peugeot 207cc | Mezz | PSA Group Peugeot, Citroën | 2 | 23/10/2012 21h35 |
| calage chaine de distrebution 207cc | stofa-25 | Mécanique générale | 6 | 28/12/2011 16h37 |
| probleme ralenti sur une 207CC moteur 1.6 | Amine-TE | PSA Group Peugeot, Citroën | 20 | 26/12/2011 21h01 |
