Précédent   Tlemcen Car electronics > Categorie principale > Café du forum > Section for english users
Section for english users English talking about cars, problems and solutions ...
Vieux 08/06/2016, 16h44   #1
ANDIR
Avatar de ANDIR
ANDIR is an unknown quantity at this point
Par défaut Renault Espace Wiring
Hi
I had an Espace 1.9dci 120hp for some time, found and bought a fully equiped 2.2dci from the scrapyard.
I started moving parts from the 2.2 to the old one
- Sun roof
- steering wheel with cruise control
- windshield with heliomatic diming mirror and rainsensor
- rear parking sensors
- electric adjustable seats
and others
for these to work i took the whole interior apart and replaced the old wiring with the new one
- the car wouldn't start with the now card reader (also changed the steering column with the blocker, and the inside ECUs)
so i swithed back the ECU an the steering column and the card reader.
it started fine
except my dash is like a christmas tree
Can't connect TEXA diagnostic toll to it (waiting for a Renault Can CLIP to arrive...)
ABS, ESP, Parking, Airbag lights are on, the car runs ok
Cruise Control activeted itself and works (this should not work if ECU cant reed wheele speed sensors...)
Anything would help...
ANDIR est déconnecté   Réponse avec citation
Vieux 08/06/2016, 17h17   #2
ANDIR
Avatar de ANDIR
Sorry forgot to mention
the 2.2dci was an A/T
did not use enginebay ECU and A/T shifter
when i used the new ECUs andpressed START red LED was blinkin
perhaps it was because the A/T shifter was not present and it did not read it in the P position
also with the new wiring the headlamps don't work (the 2.2 had xenon, did not change the headlamp wiring yet and so the old ones are still on)
renault espace 4 raed83300 Mécanique générale 2 17/04/2016 21h43
Renault espace IV faniose Outil de programmation 16 17/04/2015 20h19
renault espace 4 passion-auto programmation & synchronisation de clé 1 26/12/2014 21h03
Renault espace iii gsx650 Renault clip, DDT2000, Nissan consult 9 18/07/2013 00h08
renault espace de 98 td memati Renault, Dacia, Nissan 2 31/07/2011 22h34
Fuseau horaire GMT +1. Il est actuellement 23h54.
