Discussion fermée
Vieux 03/03/2016, 16h03   #1
diagnosis29
Avatar de diagnosis29
Pouvoir de réputation: 184
Par défaut Renault can/k-line tool
Vends
RENAULT CAN/K-LINE TOOL
Neuf = 560€ livré - avec facture
Livré avec Version logiciel V2.49
EDC15C3 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EDC15C13 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 31H - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 32[N] (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 34 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 35 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3132 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3134 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SID301 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code, Clear IMPACT DETECTED, Read stored mileage
SIM32 - Read/Write EEPROM, Read/Write FLASH from HD64F7055, Clear Immo Code
SAFIR / SAFIR2 / SFR200 (35 / 55 pin connector) - Read TMS374 EEPROM, Clear Immo Code (car runs without immobilizer code)
IAW 6R.20 - Read/Write TMS370 EEPROM
IAW 6R.30 - Read TMS370 EEPROM, Clear Immo Code (car runs without immobilizer code)
VALEO BII for ESPACE III - Read/Write (9)08AZ60 EEPROM, Read/Write mileage, Clear for Replacement, Read transponder data, Emergency Startup
VALEO IMMOBILIZER for LAGUNA I Ph2 (1998-2000) - Read transponder data, Configure, Reset to VIRGIN
INSTRUMENT CLUSTER for ESPACE III (1998-2002) - Reset odometer, Erase RF remote programming by instrument cluster connector
SIEMENS IMMOBILIZER for ESPACE III Ph1 (1996-1998) - Read/Write 68HC05B16 EEPROM, read transponder data
SIEMENS UCH for MEGANE/SCENIC ('98-'02) - Read/Write 705B32 EEPROM, Read/Write configuration, Learn Keys
LAGUNA II, ESPACE IV, VELSATIS, LAGUNA II Ph2, ESPACE IV Ph2, VELSATIS Ph2 - KeyCard Programming, Change VIN
MEGANE II, SCENIC II, MEGANE II Ph2, SCENIC II Ph2 - KeyCard Programming, Change VIN, Reset UCH to VIRGIN
INSTRUMENT CLUSTER for SCENIC II ('04-'08) - Wake-Up by CAN-BUS for repair or to check mileage, Change language and units, Change VIN
CLIO II Ph2, KANGOO, TRAFIC, MASTER, VIVARO, MOVANO (-'07) - Read/Write EEPROM 93C66, Key Learning, Change VIN
KANGOO I, TRAFIC, MASTER, VIVARO, MOVANO ('07-) - Key Learning, Change VIN
KANGOO II (2007-2012) - Key Programming, Change VIN
MODUS / CLIO III ELECTRIC POWER ASSISTED STEERING (TRW DAE/PAS) - Clear Immo Code, Change VIN by OBDII
MEGANE/SCENIC III ELECTRIC POWER ASSISTED STEERING (NSK DAE/PAS) - Clear Immo Code, Change VIN by OBDII
LAGUNA III (2007-2015) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
LATITUDE (2010+) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
CLIO III / MODUS - Key Programming, Change VIN, Learn ECM in protected mode
CLIO III - Card Programming, Change VIN, Reset UCH to VIRGIN
MASTER III (2010-) - Key Programming, Change VIN
TWINGO (2007-2013) - Key Programming, Change VIN
TWINGO (2001-2006), LOGAN (2004-2008), SANDERO I, THALIA, SYMBOL - Key Programming, Change VIN
LOGAN, SANDERO, THALIA, SYMBOL (2008-2012), Duster (2010-2012) - Key Programming, Change VIN (NEW!)
MEGANE III / SCENIC III (2009-2015) - Card Programming, Change VIN, Reset BCM to VIRGIN
Dernière modification par diagnosis29 ; 03/03/2016 à 17h51.
diagnosis29 est déconnecté
Vieux 03/03/2016, 19h19   #2
foulques
Avatar de foulques
foulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud of
elle est sortie la version 2.49?
foulques est déconnecté
Vieux 03/03/2016, 19h35   #3
samb4064
Avatar de samb4064
Pouvoir de réputation: 42
Par défaut V2.49
Envoyé par foulques Voir le message
Salut foulques,
Tu sur de ton coup je viens de jeter un coup d'œil il sont toujours à la version v 2.48 pourtant ??
samb4064 est déconnecté
Vieux 03/03/2016, 19h37   #4
foulques
Avatar de foulques
C est pour ça que je pose la question
Envoyé de mon GOA en utilisant Tapatalk
Vieux 03/03/2016, 19h50   #5
diagnosis29
salut ,
Oui j'ai la V2.49 , il n'y a pas de nouvelles fonctions , juste optimisation
a++
Vieux 04/03/2016, 12h36   #6
diagnosis29
Vendu ........
Vieux 04/03/2016, 13h05   #7
Amine-TE
Fondateur
Avatar de Amine-TE
Pouvoir de réputation: 1335
Envoyé par diagnosis29 Voir le message
Vendu ........
C'est sûre
🚀 MOD-FILES.COM
Amine-TE est déconnecté
Discussion fermée
Renault CAN/K-line ECU Tool madinina84 Réparation & Programmation 19 30/11/2023 15h00
recherche Renault CAN/K-line ECU Tool Gt13turbo Vente, Achat, Echange 3 26/10/2015 15h23
recherche Renault CAN/K-line ECU Tool Gt13turbo Vente, Achat, Echange 1 16/10/2015 21h25
Renault can/k-line tool opc Vente, Achat, Echange 9 26/07/2014 22h18
New Maj pp2000 et lexia on line or off line ramaz PSA Group Peugeot, Citroën 10 19/11/2011 09h30
Fuseau horaire GMT +1. Il est actuellement 03h38.
