| Vente, Achat, Echange achat, vente ou echange de matériel, logiciel ...ect passez par ici. |
Pouvoir de réputation: 18 ![]() ![]() ![]() ![]() |
Miniprog TL866CS USB
--------------------------------------- The chip supporting range: ◆All kinds 26 27 28 29 37 39 49 50 Parallel ROM, EPROM, EEPROM High-speed and wide-support It can support TSOP32 TSOP40 TSOP48 chip to 64MBits and the programming speed is 5-10 times as fast as the similar. ◆24 25 35 45 85 93 95 Series EEPROM It can widely support series chips and the 8-16 PIN 25 series chips can be supported to 64MBits capacity. ◆ Hundreds of the 51 series microcontroller* ◆ AVR microcontroller, including ATMEGA series, ATtiny series, AT90XXX series microcontroller AVR microcontroller can complete a one-to-one soft encryption by RC calibrating bytes.* It can support high-speed parallel programming and at the same time all AVR ATMEGAxxx chips can be supported SPI series download programming by using ICSP interface. TQFP64, TQFP100PIN AMEGAxxx chips can be supported. ◆Microchip PIC10 PIC12 PIC16 PIC18 Series microcontrollers: As for PIC series chips, it can support more than 300 models and more than 900 types of packages. It is one of the most comprehensive programmer of supporting PIC chips. For all kinds of PIC chips, it can program with optimization and high speed strictly according to the manufacturer manual. For the majority of chips, it can support ISCP in-circuit programming and at the same time it can program by using programming socket.* ◆ GAL programmable logic device programming It can support the common PLD device. ◆ SRAM Test It can support common 24 61 62 DS12 series SRAM test, respectively data line testing, the address line testing, memory cell incremental testing and unit testing. ◆ superb performance in 54/74F/LS/HC CMOS4000 series IC comprehensive function test: This is the first development programmer that can test common logic IC. This test can locate the logic gate errors and get any possible input combinations of IC. Programmable chips12700 +, the upgrade process will add more chip support. At present, it can support more than 12700 chips and the types will gradually increase in the future upgrade. |
| programmateur cas 4 | BilChip | Vente, Achat, Echange | 17 | 16/11/2015 08h29 |
| programmateur en usb | toupie | Electronique | 14 | 23/09/2013 01h07 |
| programmateur Universel Galep5 neuf a vendre | nany | Vente, Achat, Echange | 1 | 27/05/2012 12h06 |
