Vieux 19/02/2016, 21h21   #1
tarik_electronic
Avatar de tarik_electronic
Pouvoir de réputation: 40
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
Par défaut Nissan Consult-III Plus v54.11 (2016)
https://mega.nz/#!HhU0RASL!H9FZrYdQs...5ZcRY8G5Gwp6yo
oublié pas le petit " thanks "
tarik_electronic est déconnecté   Réponse avec citation
The Following 10 Users Say Thank You to tarik_electronic For This Useful Post:
autodiagauto (24/09/2020), bip bip (20/04/2026), ElTurco (04/09/2019), Hitch_tiziicoca (03/01/2021), JEAN PHIBRE (22/09/2020), lassad (03/09/2020), shfayzar (02/04/2019), tomawak (21/07/2018), VALISE-DIAG30 (30/10/2020), yakoub (07/05/2016)
Vieux 19/02/2016, 22h10   #2
salut , marche pas sur mon pc ! seven pro 64 !
le manuel ne supporte pas votre PC
bon weekend
ElTurco (26/09/2020)
Vieux 19/02/2016, 22h27   #3
tarik_electronic
bon weekend
Salut jphp
Essayer
Type de fichier : rar setup.rar (200,7 Ko, 91 affichages)
The Following 2 Users Say Thank You to tarik_electronic For This Useful Post:
bip bip (20/04/2026), ElTurco (26/09/2020)
Vieux 19/02/2016, 22h28   #4
tarik_electronic
vous pouvez essayer sans setup.inx modifiée
dans cet regedit
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE \ SOFTWARE \ NISSAN]
"CheckCF18" = "1"
[HKEY_LOCAL_MACHINE \ SOFTWARE \ NISSAN \ CheckCF18]
"PassCheck" = "1"
[HKEY_LOCAL_MACHINE \ SOFTWARE \ NISSAN \ CheckOperationPC]
"ExecutionStatus" = "232212"
The Following User Says Thank You to tarik_electronic For This Useful Post:
Vieux 19/02/2016, 22h30   #5
Envoyé par tarik_electronic Voir le message
Salut jphp
Essayer
fichier INX inconnu !
Vieux 24/02/2016, 22h36   #6
hsf2014
Avatar de hsf2014
Pouvoir de réputation: 22
bonsoir , viens d essayer mais ne marche pas sur windows10 = message des le debut de l install : ce pc n est pas supporté ....etc . une solution ?
The Following User Says Thank You to hsf2014 For This Useful Post:
Vieux 25/02/2016, 21h19   #7
tarik_electronic
Bonsoir
C pour :Windows XP; Windows Vista; Windows 7; Windows 8
Vieux 03/03/2016, 19h27   #8
samb4064
Avatar de samb4064
Pouvoir de réputation: 42
Par défaut Nissan consulte III
Salem tarik,
Peux tu me dire si ma sende VI alliance reunault peux marché avec le consult III et si oui quelle manip a faire stp ?
Vieux 13/03/2016, 22h10   #9
nowen
Avatar de nowen
Pouvoir de réputation: 66
Bonjour tarik_electronic,
est ce que ta version est activée et donc fonctionne direct ??
ou il faut l'activer ?? si oui comment ??
Vieux 14/03/2016, 19h10   #10
nowen
Avatar de nowen
c'est ok j'ai réussi l'installation sur seven 32 Bits.
pour répondre à samb4064, j'ai essayé avec la sonde alliance VI et elle ne s'installe pas.
je me suis renseigné et pour la sonde alliance VI c'est le "consult III" tout court et donc pour le "consult III Plus" c'est une sonde VI2 comme celle là:
j'ai testé avec cette sonde c'est ok pour la version de tarik_electronic
merci à lui
Vieux 14/03/2016, 19h39   #11
samb4064
Avatar de samb4064
Par défaut Consult3
Merci frero pour ces renseignement très très presieuses,
Vieux 04/04/2016, 23h04   #12
kevin22
Avatar de kevin22
kevin22 is just really nicekevin22 is just really nicekevin22 is just really nicekevin22 is just really nice
Merci, pour ce soft et j'espère pouvoir faire un diag sur Nissan priméra !
ce qui n'est pas aisé avec la version précéente...
kevin22 est déconnecté   Réponse avec citation
Vieux 28/05/2016, 20h17   #13
louloupopar
Avatar de louloupopar
louloupopar is on a distinguished road
Bonjour je voudrai acheter les valises pour faire les nissan, si j'ai bien compris il me faut consult3 plus sonde alliance et consult3+ plus sonde vi2, ou puis-je les acheter de bonne qualité et pas trop chère .
louloupopar est déconnecté   Réponse avec citation
Vieux 28/08/2020, 02h31   #14
Mdx57
Banned
Avatar de Mdx57
Mdx57 is an unknown quantity at this point
Allez tous vous faire enculer avec votre forum de merde pas moyen de chopper les liens de merde pour une inscription c'est la misère et en plus de cela vous cassez les couilles pour mettre un avatar à la con
Une fois toutes C joyeuseté accompli pas moyen de choper le lien car l'administrateur ne nous autorisé pas blablabla
VA TE FAIRE ENCULER AU BOUT D'UN MOMENT
bon allez exister vous bande de suce bite adios
Mdx57 est déconnecté   Réponse avec citation
Vieux 28/08/2020, 02h43   #15
gary01
Avatar de gary01
Pouvoir de réputation: 104
Envoyé par Mdx57 Voir le message
Faut lire le reglement t’aurais compris que t’allais pas avoir ton lien.
nissan consult fufounet Renault clip, DDT2000, Nissan consult 46 01/05/2016 13h35
nissan consult 2 dede83 Vente, Achat, Echange 0 10/01/2016 16h13
nissan consult 3 plus otrac79 Renault clip, DDT2000, Nissan consult 1 03/12/2015 13h29
cherche nissan consult 3 foulques Renault clip, DDT2000, Nissan consult 2 27/03/2014 05h40
Difference d'interface Nissan Consult III MCNexo94 Renault, Dacia, Nissan 3 14/12/2012 22h16
Fuseau horaire GMT +1. Il est actuellement 08h54.
