Vieux 29/01/2016, 14h50   #1
soustourou
Avatar de soustourou
soustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud of
Par défaut lire bsi valeo
bonjour a tous je voudrais lire cette bsi d'une xsara picasso 2.0 hdi
sur l'etiquette blanche
REF PSA 96 325 268 80
REF DAV A11896
REF SYLEA 133 272
REF VALEO 730 025 12
99/320/A
BSI BOITE B6
HARD PR4
SOFT V6 91
merci a vous tous
On a souvent besoin d'un plus petit que soi
soustourou est déconnecté   Réponse avec citation
Vieux 29/01/2016, 15h21   #2
doud77
Avatar de doud77
SAlut,
voici http://www.tlemcen-electronic.com/fo...ad.php?t=17771
Vieux 29/01/2016, 15h21   #3
tarik_electronic
Avatar de tarik_electronic
Pouvoir de réputation: 40
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
Il faut lire le mcu
oublié pas le petit " thanks "
tarik_electronic est déconnecté   Réponse avec citation
Vieux 29/01/2016, 15h24   #4
tarik_electronic
Le pinout et dans le nyo4
C un NEC
Vieux 29/01/2016, 16h35   #5
soustourou
mais c"est pas le meme pcb
Vieux 29/01/2016, 19h01   #6
ECU diag
Avatar de ECU diag
Pouvoir de réputation: 65
Slt poste une photo du pcb
Vieux 29/01/2016, 20h36   #7
soustourou
voici les jpeg merci
Type de fichier : jpg IMG_20160129_203106.jpg (94,5 Ko, 49 affichages)
Type de fichier : jpg IMG_20160129_203130.jpg (86,2 Ko, 29 affichages)
Type de fichier : jpg IMG_20160129_203046.jpg (84,4 Ko, 26 affichages)
Vieux 29/01/2016, 21h17   #8
S-keys
Avatar de S-keys
Pouvoir de réputation: 141
pourquoi tu veut le lire ami ?
Vieux 29/01/2016, 21h25   #9
ECU diag
Avatar de ECU diag
Et si t'ouvrais de l'autre je pense que ce sera mieux pour voir le processeur nec
Vieux 29/01/2016, 21h29   #10
ECU diag
Avatar de ECU diag
C'est de l'autre côté que sa se passe
Vieux 29/01/2016, 22h09   #11
soustourou
merci au fait je voulais le virginiser pour refaire car j'ai des problemes de centralisation je me suis dit que peut etre c'est le bsi qui deconne donc j'ai pris le meme a la casse et je voudrais remplacer le mien
Vieux 29/01/2016, 23h42   #12
S-keys
Avatar de S-keys
j'ai jamais trouvé vierge sur NEC !!!
Vieux 30/01/2016, 05h49   #13
soustourou
donc pas possible a ton avis je peux directement le telecoder sans le virginiser ?
Vieux 30/01/2016, 19h46   #14
sosauto
Avatar de sosauto
sosauto has a reputation beyond reputesosauto has a reputation beyond reputesosauto has a reputation beyond reputesosauto has a reputation beyond reputesosauto has a reputation beyond reputesosauto has a reputation beyond reputesosauto has a reputation beyond reputesosauto has a reputation beyond reputesosauto has a reputation beyond reputesosauto has a reputation beyond reputesosauto has a reputation beyond repute
moi sur ce type de bsi mcu nec quand j'ai un souci je ramène un bsi occase ,je dessoude le mcu et je le ressoude sur le bsi occase ,pas besoin de reprogrammer ca marche au premier coup
bon courage
SoSaUtO
sosauto est déconnecté   Réponse avec citation
The Following User Says Thank You to sosauto For This Useful Post:
soustourou (27/10/2018)
pin out BSI Valeo J02-00 nizar Programmateur de composant (flasher) 23 13/07/2024 20h52
Comment lire Bsi Valéo C3 ? r1lef Réparation & Programmation 17 15/09/2016 20h52
pin out BSI Valeo J02-00 nizar Programmateur de composant (flasher) 0 28/03/2015 18h00
valeo V34.1 Firas Immobilizer dumps/solutions 3 15/10/2014 14h03
BSI 207 Valeo Auto-Diag Immobilizer dumps/solutions 2 05/08/2014 03h34
Fuseau horaire GMT +1. Il est actuellement 11h29.
